Question about Samsung UN40C6300 TV
What is the code for programming the rogers remote to work for the LED 6300
Try to turn on via remote or button on set. Only a green flash on front. Nothing else. Can I fix it?
About 435,000 results (0.80 seconds) Search Results
    3 Ways to Program an RCA Universal Remote - wikiHow
    www.wikihow.com > ... > TV and Home Audio > Television
    wikiHow... Universal Remote. Are you tired of juggling three or four different remotes just to control your home theater setup? ... Log in via ... Turn on the device you want to control. ... Press and hold the button on the remote that corresponds with the device.... You will need to try another method in this article to program the remote.
    How to Program an RCA RCR312W Remote: 15 Steps ...
    wikiHowHow to Program an RCA RCR312W Remote. ... Log in via ... Press the PLAY buttonevery five seconds until the component turns off. ... If component does not respond or has limited functionality, codes in a different block list can be tried until you find the code that allows the remote to .... Set Up a Home Theater System.
    Your remote reprogramming woes solved - Rogers RedBoard
    redboard.rogers.com/.../your-remote-reprogram...
    Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... You can always contact us via our Facebook page or tweet us ... Hi my TV is anRCA model # RLDED3258A-B I have tried 73 codes from Universal .... I have tried toset up my tv and home theatre with the Rogers remote but no luck...
    RCA TV: input channel/s-video - ecoustics.com
Jan 19, 2016 | RCA Audio Players & Recorders
Need a remote code for fluid tv using rogers remote
Hi MiMi I attempted to search for the Code for your TV under several of the Rogers remotes and was unable to find one. You can do a general search for a code on any of them following some minor instructions. Navigate to link , choose the remote that looks like yours and then to the left will be choice to search all possible codes. Hope this helps. Good luck Rogers Cable Remote Support
Nov 04, 2014 | Televison & Video
Www urcsupport com
Use the auto code search function of the remote.
Apr 20, 2017 | Televison & Video
Hi I am trying to program my Hitachi Plasma with a rogers provided universal remote. 5 button. I can program the TV but i cannot program the digital cable box. What am I doing wrong? Please help...
the sat and cable boxes are like DIY items , just use a known set top box like dreambox e.t.c. ,i have a problem with my Logitech remote and pace HD sat receiver,evrey 2 -3 the sat receiver changes remote codes :) and its very annoing, but ill switch to a LED tv with integrated sat so for know acceptable i have a tip for you regarding receiver -change mylar and ceramic caps to film ones
Mar 23, 2011 | Yamaha RX-V750 Receiver
6300 Cellular Phone: i need a nokia 6300 restriction code...
you can unlock it here http://www.superunlockcodes.com/nokia-6300/rs12wp9/
1 - Switch on your Nokia 6300 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6300.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6300 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6300 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
May 16, 2010 | Nokia 6300 Cellular Phone
Unlock codes for Canada..Rogers Wirless network
0620261216 Boss try these It will work i know..
cheers!!
Jan 26, 2009 | Nokia 6300 Cellular Phone
Unlock nokia 6300
Hi, jobinthompu your IMEI: 358052017980938
mastercode:
540201404x
The mastercode can be entered instead of standard security code.
please do not forget to rate this solution if it works.
Dec 11, 2008 | Nokia 6300 Cellular Phone
Need codes for electrohome lcd tv so i can program it with my rogers hd box
i'm thinking you want to control your tv with the rogers hd box remote.
here is the link please click on the Remote Control Code-Finder
link on it and find your remote.
http://www.rogershelp.com/DigitalCable-Ontario/category.php?id=YY-24
Apr 15, 2008 | Televison & Video
Code for universal remote
This must be a duplicate post. And because I'm not sure which one you'll check I'll just post the answer here too... Diamond vision is a little pickey with handing out their code access. And Rogers doesn't have a whole lot about accessing components like DVD players. But try this: 1. Turn on DVD player 2. Press the AUX button at the top of the remote 3. Press and hold the SETUP button until the LED light blinks twice. 4. Press 9-1-1 in sequence, the LED will blink twice again. 5.Aim the remote at the DVD player and slowly alternate pressing POWER and AUX. Stop when DVD turns off. 6. Press SETUP to lock the code in memory. It may take several minutes of alternating between POWER and AUX to find the appropriate code - be patient... If after ten minutes you haven't got it try programming it as a VCR - steps 1 through 6 above and substitute VCR for AUX.. Good Luck Bill
Jun 10, 2007 | Yahoo Diamond Vision DVDC803-04 DVD Player
Code for remote / Diamond Vision DVD Player model: DVD807-04
I found the code! It is 0736. The company is now called AudioLogic.
Samsung UN40C6300 TV Logo
Jerry Greenberg
Jerry Greenberg
