Question about Mitsubishi HS-U270 VHS VCR
Good Evening I have an old Mitsubishi HS-M1000(B) and am trying via a SCART lead to plug it into my TV. I have the areal lead plugged from the TV to the VCR player and then another from the VCR player to the areal plug in the wall. The SCART is plugged from the TV to the VCR. The picture on both the playing Video and the TV channel when the Video is stopped are black and white. Do you know why this could be? Thank you Samantha
nfandres
  • 168 Answers
SOURCE: How do you connect the VCR Mitsubishi HS-U446 to record a TV show?
Usually the standard color coding for those connections are yellow, red and white. Yellow for video, red and white for audio left and right if it is stereo. Also pay attention on the the label of your vcr if it is input or output. You need need to connect it from output of your vcr to the input of your tv set. TV have also the same color coding. By the way the cable you use for this purpose is what we called RCA, which is also color coded. good luck!
Posted on Feb 26, 2007
  • 275 Answers
SOURCE: Can tune mitsubishi HS-651V video player/recorder to watch TV.
Hi Jaco, Have you fed in your Antenna / cable into the Rear of the VCR? And if your VCR has a Input selection switch, just check input to Tuner. You will get Blue screen if input selction is not Tuner but Camera / External source. If this does not solve your problem, then there is no Input selection happening.
Posted on Apr 06, 2007
dodgecharger
  • 254 Answers
SOURCE: VCR eats tape when rewinding
A couple of possibilities: 1. Braking problems: When VCR goes from FFWD, REW, Play to stop, there are a pair of "brake pads" engaged to stop the reels, and prevent tape spillage out into the machine. These pads, often rubber like, are on levers which contact one side of each reel. If you take the cover off the VCR, and look down where the tape is loaded, you will like see these brake assemblies. If the rubber pad is missing, or lever pivot points gummied up, then this is your issue. 2. Take up reel isn't being engaged to take up the tape on tape eject. When a tape is loaded into the machine, tape is pulled from the cartridge and threaded into play ready position. When eject mode is engaged, the tape must be pulled back into the cartridge, or you will have tape hanging out the front end of the cartridge, and may get caught on the VCR internals, or at least be mangled by the cartridge door. The often issue here is likely the idler assembly pivot point is sticky. This idler pivots, moving from the take-up reel (right reel) to the supply reel reel (left one), depending on what mode is selected. FFWD & play to the right, left for REW. If this idler is gummed up at it's pivot point, movement will be sluggish at best, and might not be engaging the right reel quickly enough to pull tape in before tape eject. This idler is sitting right between the reels down where the tape sits. A little light oil on the pivot point may be enough to loosen it up. Otherwise it might need to be removed and the old grease removed, and a drop or two of light oil applied.
Posted on Jul 10, 2007
SOURCE: Mitsubishi HS-U447 VCR in Lock or "Loc" mode
There is a reset for this problem and it worked for my VCR. This was a last resort without the manuel.
Only someone with electronics experience should do this.
Posted on Nov 26, 2007
Hopefully you still the VCR. Your's is stuck in "CHILDLOCK" mode. To release the lock you have to have the remote and press the DISPLAY for 8 to 10 seconds.
The purpose of the CHILDLOCK is to prevent others from using your VCR. If you want to set the VCR back on Lock you again press the DISPLAY for 8 to 10 seconds.
This solution is from the owner manual for HS-U448, so I figure your model is the same.
Posted on Jan 18, 2008
Directions for plugging your 4head hi fi stereo ito your tv
You don't really say what make or model is the TV or VCR. However if you have a TV with a scart socket you can get a scart lead and connect the VCR via that. If the VCR has two scarts connect it via AV1 sometimes black whereas the other might be blue. If the TV has more than one you will have to try each one, unless it says VCR on the scart socket, till you get the best picture.
Dec 09, 2011 | Televison & Video
Ive just brought a freeview box but cant get any sound
Assuming you are plugging Freeview box to TV direct via a scart lead
It may be that the scart lead that you are using does not have its audio pins connected. Make sure you have a lead with all pins wired
Feb 25, 2011 | Televison & Video
I have a Digihome DV940B freeview receiver, and wish to set it up with a tv and video how and where do I put the areal and scart leads
This depends on how you want to use your kit, and how many scart plugs you have in your TV and VCR.
If you have 2 scarts in your tv;
Aerial coax goes to digihome aerial in. Aerial out from digihome to aerial in of vcr. Tune vcr into Digihome.
Scart plug from digihome to tv.
Scart plug from vcr to tv.
You can then record what you have selected on your digihome box.
In my humble opinion, it's worth splashing out on a pvr; you have more functionality such as being able to record 1 program and watch another.
Regards
Zahc
May 05, 2010 | Televison & Video
When i plug my new tv into the sky box via a scart, the tv picture is distorted and a major buzzing noise is coming from the tv. sky have checked and said the box is fine. when u connect to another tv it...
Have you tried another scart lead? Also tried all of the tv scart sockets? Don't try and cure this by using an expensive upmarket scart lead, you'll just be wasting your money. The cheapest leads work just as well when the function correctly.
You could also try reversing your current lead by swapping the tv end to the Sky box and vice-versa, as there are many leads which cause feedback issues, and also a lot of "cut" leads (designed to prevent feedback looping) which must be fitted the correct way around. A "cut" lead is one where the wire to pin 19 at the tv end and to pin 20 at the video/Sky box end has been cut.
Note that scart leads MUST be fitted with the tv and Sky box switched off to avoid damage. Most people (including professional installers) regularly ignore this precaution though.
If all else fails then take the tv back and exchange it under the Sale of Goods Act; it's certainly not uncommon for new tv's to have faulty scart sockets.
If I've solved your problem then please take a moment to rate my answer. If not, then please report back with the make and model of TV and I'll try a more specific answer.
Jan 14, 2010 | Televison & Video
When the display is via HDMI Games won't load, the screen will alter as if loading the game then it will flicker and go black.... But it plays Blu Ray Movies fine...? I then have to restart the system and...
It's a bit of a pain as you'll have to re-establish your initial internet setup ( this is where keeping old passwords, etc, comes in handy ! ), but the only solution that will work is by resetting your PS3 to ' first time use ' ( not back to factory condition though ).
This may be an unwanted slog but if you've accidently changed the settings and can't remember how or why at least you'll know the initial sttings should work.
If you don't want to do this, try going to the screen settings and adjust one at a time ( loading a game in between ), also if you have a scart lead fitted ( as well as the HDMI lead ) make sure it's in the audio out and not in ' video ' ( the audio out will be a circuit between an audio scart socket on your tv and the red and white leads going back to your audio output device : active subwoofer, etc , the yellow lead plugs into the scart lead from the console via a plug point adaptor which goes straight into the scart on the tv set ).
AV Multi Out should not have to be performed as the leads out devices are the only ones which should be pressed to set.
Hope this helps.
Jul 24, 2009 | Sony Playstation 3 (PS3) Console
Connecting sky box to to non scart reysis tv,via scart plug cable
This lead is usually coloured yellow and looks like the red and white leads you use to connect the tv speaker OUT sockets to an amplifier or external speakers. The input on the tv should be coded yellow also.
Jul 18, 2009 | Relisys RLT-1500 15" LCD Monitor
C21T7BA TV will not power up.
check the internal mains fuse usually connected to the mains lead via the on/off switch .good luck farr64
May 02, 2009 | Mitsubishi VS-60607 TV
Why is my bush tv black and white when i watch a dvd
you are using the svhs scart if it has another scart swap the plug over
Dec 08, 2008 | Televison & Video
I have an LG LCD TV (LG 37LG5000 37IN). I also have an older DVD Home Theatre System (SONY DAV-DZ100). It seems that the surround system works well with DVDs but I cannot get the sound to work with DIGITAL...
It works fine if you plug the surround system SCART lead into the AV2 input. I believe this is a 'smart' scart plug (same as SONY but it is not mentioned as in the literature). The AV1 is only good for inputs NOT outputs as well.
Oct 04, 2008 | Televison & Video
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
Mitsubishi HS-U270 VHS VCR Logo
94 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
