Question about Logitech Keyboard & Mouse
How do I turn number keypad on/off - Logitech Keyboard & Mouse
  • 79 Answers
Press the num lock button, it is located on the upper right hand corner of the number pad.
Posted on Mar 24, 2011
  • jody1622 Dec 21, 2013
    Oh, for heaven's sake, that was so simple! Thank you!!
I want my keypad numbers to beep when dialing
Go to general setup in the menu & turn on the keypad beep.
Sep 04, 2014 | Brother MFC-8220 Fax
I'm trying to turn on the number pad on my acer 5738-6444
Press the num Lock button which is above the number 7 and turn on the num Lock to use the Number Keypad on the keypad
Jul 11, 2010 | Acer Aspire 5500 5570-2609 Laptop
Whenever I hit a number key it turns on and off the num lock (when num lock i off on keyboard). I use the keypad to play games and this just minimizes the game and shows me a messgae about num lock be...
This keypad is meant for mass number data, not as a joystick replacement I'm afraid.
Did you install any software that came with it? If so, try removing it Normally you don't have on-screen NumLock messages, so this must be something extra.
It clearly wants to be used for number entry. Perhaps it has some switch to change it's behavior, either physical, or in software?
Mar 12, 2010 | Targus USB Ultra Mini Keypad Keyboard...
My function key is on and i cant figure out how to turn it off
To use the embedded keypad
After pressing Fn+F8 to activate the numeric keypad, you must press the Lock key
(in the top row of the keyboard) to turn number lock on or off.
When number lock is on:
• Keys change to the numeric or arithmetic designations printed on the right side of the
keys in the numeric keypad area.
• The Num Lock status indicator is lit.
• To turn off the embedded keypad, press Fn+F8 again.
For further reference of usage of Function keys, check the HP manual:
http://h10032.www1.hp.com/ctg/Manual/lpi05379.pdf
Page number: 30/141
Regards,
Nags
Jan 19, 2010 | HP Pavilion N5415 Notebook
Is there any way of turning on the backlight on the numeric keypad on the u600?
From your main menu go into "Settings". Select.
Scroll down to number 5 "Light settings. Select.
Scroll down to number 3 "Keypad light". Select.
It will probably be set to "Night time" 05:00 PM.
Use your direction pad to change it to "Any time" Save.
The keypad backlight will be on all the time.
Aug 17, 2009 | Samsung SGH-U600 Cellular Phone
Need to change keypad code, but lost instruction manual
The key code transmitter for your unit should be 53776 multi key panel:
you must have access to the operator to reset. The programming keys are as noted below:
1. Open the Touch C.ode Transmitter cover to access the keypad.
Decide on a 4-digit code number using numbers from
0 to 9. You can use a number more than once. (For
example, 4, 0, 4, 1).
2o Press the 'SR' code button on the opener panel. The
indicator light atongside the push button will turn ON.
3_ STAND AWAY FROM THE DOOR. Press the selected code
numbers on the keypad and then press the ENTER key.
The indicator light on the opener panel wiil turn OFF and
the door witl begin to move, The opener receiver has been ._
programmed with your code selection. (_
NOTE 1" If the indicator light turns OFF before the code _ . "_ _'
digits and ENTER key are pressed, repeat Steps 2 and 3. _._t,_-_ J t_
NOTE 2' During programming, be sure the,k/_ca_i_n push :---'-"_"
button (if your opener has that feature) is OFF and the
Infrared Sensor (if you have installed that accessory) is
free of obstruction. THE DOOR WILL NOT MOVE AND THE
INDICATOR LIGHT WILL NOT TURN OFF in either case.
To change your code at any time, repeat Steps 1, 2 and 3.
Hope this helps
Apr 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
How do I use Dell inspiron 1300 keypad?
If you are referring to the Number keypad.
Tap the "Num lock" key and you will see a light flashing.
Make sure the light is on when you stop.
Now try the keypad.
Mar 15, 2008 | Computers & Internet
Keypad tones - D900i
Change the dialing font style to Normal and then set off keypad tones on setting menu.
Oct 07, 2007 | Samsung SGH-D900 Cellular Phone
Logitech Keyboard & Mouse Logo
362 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
