Question about RCA RS2044 Shelf System
My RCA RS2044 won't turn on. The switch clicks but no power. Have checked the outlet and plugged it in another outlet but no power. Is there a repair shop in Springfield, IL?
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: I don't know how to use my RCA # RS2044 Stereo
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/RCA-RS2044-manual/id/402dj679/t/2/
Posted on Jun 01, 2011
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
Tv won't turn on
Check for input power in outlet. Try connecting the TV to a different power outlet you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | RCA L22HD31 22 in. LCD HDTV
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
Rca phd 50500
If no power, check your power plugs and wall outlet if its working. If not might have to open it, and check fuse and Power Supply Unit. Revert if anything.
Dec 28, 2011 | RCA Televison & Video
Rca f36650yx01 will not turn on
I feel foolish asking this but have you plugged it in? If you have it plugged in are you trying to turn it on with the remote? Have you tried to turn it on by pressing the on switch on the tv? Does the outlet work?
There could be any number of reasons for this. If the outlet has power (you can check this with any electrical device you have, plug it in and turn it on). So if the outlet has power AND the remote has fresh batteries AND the tv is plugged in to the outlet but still will not turn on even after pressing the switch on the tv...then you may have a blown fuse on the power input line into the tv. Take the tv to your local repair shop and ask them to look, if the fuse is blown they'll replace it and voila, your tv is fixed!
Please do not try to do this yourself, there is over 10,000 volts available at the flyback transformer even with the tv not plugged in.
Sep 07, 2009 | RCA F36650 36" TV
Aux wire?
Your query > ..."wire...to hook...mp3 player ...RCA RS2044 stereo..."
You need to connect the headset out of your MP3 player using a special cable to theInterfaces/Ports: AUX-in of the RCA RS2044.
One of the many technical name for the special cable is RCA Male Stereo to male baby phone stereo, the common name is MP3 to RCA and it is similar to the function and look of a Cygnett Groove Transit - MP3 Phone to R...
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 29, 2007 | RCA RS2044 Shelf System
Volume problem
no it always does that to me to it cannot be fixed
Oct 24, 2006 | RCA RS2044 Shelf System
RCA RS2044 Shelf System Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
