Question about Kitchen Ranges
I am looking for a manual for a 1950's globe gravity feed meat slicer. The model no is 260
SOURCE: Globe Meat Slicer Model # 500
Fiber gear on blade hub stripped. deep socket required to remove hub. DON'T CUT YOURSELF!! remove motor, used food safe solvent to clean grease out of housing. Fiber gear held on with snap ring. Replace gear, repack housing, put hub and motor back and start slicing. Routinely check to make sure gear is lubed.
Posted on Dec 24, 2008
SOURCE: Globe commercial Meat slicer
Hi, I have working on meat slicer my whole life and can help you.
What normally happens is this. The bearings in the knife hub (this is the unit that the knife attaches to and spins) is starting to fail.
The gear on the knife hub is made out of a fiberous material and the worm gear on the motor is made out of metal, so when the bearings start to fail and cause resitance in the hub, the metal motor gear starts to eat the fiber gear on the hub and eventually wears a big chuck out of it. Then the motor spins free and doesn't make contact with the hub gear.
How you can check if this is the problem is this. You need to keep the power switch on machine in the off position and turn the blade a 1/4 of a revolution. Then turn the machine on, what should happen is that the blade will spin some and stop again.
The proper fix for the machine would be to rebuilt the knife bearing unit and replace the hub gear, motor gear and hardware.
In regards to the Chefmate. This is a design flaw of Globe and I told them about this when the machine first came out! The know is on a steel shaft that goes thru the aluminum body. The steel shaft starts to corode and also rust, then it freeze in the frame. What has to be done is this. This assembly needs to taken about sanded, lubed and put back together. The best way to permently fix this is have a machine shop machine the frame out and install a Oilite Bushing, these are impregnated with oil and it will never lock up again.
Where are you located? Let me know if I can answer any other questions for you.
If you have any other questions, you can call me on my cell 201-274-6274 or e-mail me at njrealestate@earthlink.net. Thank you
Best regards,
Scott
Posted on Dec 27, 2008
  • 580 Answers
SOURCE: Where can I get a user manual for a Rival electric
Here is a link for manual for all Rival Appliances online and downloadable http://www.rivalproducts.com/help.aspx?helpNav=5
Posted on Aug 07, 2009
SOURCE: Have a used food/meat slicer model#1101E/3
yeah right, for $12.99 I'll give you one answer Ha!
Posted on Oct 09, 2009
SOURCE: rival model 1030v/4 slicer
The slide tray has a plastic guide riveted to the bottom it. The guide has two tabs and an adjustment screw in the middle. One fof the tabs is broken off. Is that guide available for purchase so I can remove the old one and rivet the new one in its place? Model 1030v /4 989a slicer
Posted on Sep 01, 2010
How to remove berkel slicer blade
my berkel slicer model 818 the motor runs and the automatic table will slid but the blade does not torn
Jun 01, 2012 | Berkel 827E Gravity Feed Deli Meat Slicer
I need motor parts or a replcement motor for my globe gravity feed slicer
I would get it rebuilt, most or all electric motor places will do it
Aug 20, 2010 | Berkel 827E Gravity Feed Deli Meat Slicer
Manual on meat slicer
You can download the instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Jul 26, 2010 | Berkel 827E Gravity Feed Deli Meat Slicer
Guard
I'm not certain this is the same model I'm thinking of, but I think there may be a knob on the back side (behind the blade) which clamps down on a shaft coming off the blade guard. Loosen the know and the guard should pull straight off. Maybe I'm thinking of a different model slicer, but the photo looks correct.
May 19, 2010 | Berkel 827E Gravity Feed Deli Meat Slicer
Looking for insstruction manual
e-mail onesharpstore@comcast.net give us the slicer model you want a parts manual for and we will see if we can help you
Mar 19, 2009 | Berkel 827E Gravity Feed Deli Meat Slicer
Globe Meat Slicer Model # 500 motor runs blade not turning
Oct 30, 2008 | Berkel 827E Gravity Feed Deli Meat Slicer
Kitchen Ranges Logo
70 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
