Question about LG Dishwashers
LG dishwasher LD1415T cuts out after 5 minutes,suspect PCB?
    Top Expert:
  • LG Master
  • 80,668 Answers
The printed circuit is the cause of that I am sure, to replace it you must take the door apart as the board is sandwiched in between remove the screws that hold the door apart and carefully remove the connector from the old board DO NOT PULL ON THE WIRES ONLY ON THE CONNECTORS BODY, expect to pay about $125 for the part.
Posted on Mar 24, 2011
The last few times I've run my dishwasher, my dishes have had a white film on them. We do have hard water, but this problem hasn't occurred before. On the dishwasher there is also hard water stains. Any...
hi my bosch dishwasher sgs6312gb start up and fills up then after 5 minutes cuts out on the front panel . if you leave it turned on later on it starts up . no sure what the prob is x
Jan 16, 2011 | LG 24 in. LDS 5811ST Stainless Steel...
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
My LG dishwasher stops running 5 mins in
The LE code means there is a problem with the washer motor. ( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.
Remedy: Correct wiring connections. Replace the cause of restriction. Replace the washing motor. Replace the PCB.
May 02, 2009 | LG Dishwashers
2H accures in digital read out. NO Cycles start, just a humming
Do you own an LG LDF6810ST dishwasher? If not, please reply with the manufacturer name, model and serial number.
Are you saying that the display that normally shows the time is displaying an code of 2H? On an LG, that means 2 Hours, (120 minutes) and is not an error code.
On an LG with a symptom like this, I would arrage to replace the main processor card (PCB). You would be getting an error message if the motor (wash or drain) had failed.
Mar 30, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG Dishwasher Mode LDS5811
Try checking the wiring in the door for breaks and repair by cutting and splicing with electrical tape. This site has the Service Manual: http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
Nov 17, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
Red light on no picture will work fine after several minutes
There is a list of things you need to check, but offhand I'd say that the 5 volt line is low and probably right on the"edge", which is why it works sometimes and not others take a look at this list:
Cause #1
1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for
12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check
for an open F9A09 on the Power PCB, if it is open replace F9A09 part #
283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out)
Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if
low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the
Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three
times and then the unit shuts down with a red lamp LED (lamp error). Replace the
Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch
to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light
Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the
Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low)
after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB
(ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the
Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-
volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light
I would say try #3 first, the two caps on the pwer supply board. A couple of warnings: as always, unplug the unit before servicing. The power supply is located on the left side, if you behind the unit. It is in a shielded box and the shield has VERY SHARP EDGES so use care when you try to open it or you will slice your fingers.
Please be sure to rate this solution. Thanks!
Nov 08, 2008 | Mitsubishi WD-57731 57" Projection HDTV
LG LD-14AW2 (03 error)
agreed O3 is not a LG error code. OE is more likely and if so it could be the main pcb faulty, a blocked drain pump or a blocked spigot under the sink where the drain hose connects onto.
take care.
May 11, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
Intermittent fault; stops and starts throughout the cycle
http://www.reviewcentre.com/review11826.html
check this out. I suspect loose connection on relay pin at back of pcb. Try tapping near the buttons and see if you can re-start it even for a second. This is how i isolated problem to the pcbs in the control unit. I have the loose pin with solder blown off - I just need a new soldering iron to fix it. If you not able to tackle yourself, qer.biz will do it for you, or replace with a reconditioned board for reasonable charge.
Jan 03, 2008 | Bosch 18 in. SRS43E02 Slim-Line Built-in...
Water not heating
probably not, believe it or not. If they actually designed a trace to fail under load, then they could not predict when it may happen. Yes, things get more load-some over long use and demand more current, but the pcb trace was probably not intentionally too small. Let's say it was designed too small. So at first startup it carries 9.5 Amps. The next factory unit draws 9.8 amps. the next unit, wait a minute, draws 10 amps and blew the trace before it got shipped. I think this under-design was a simple oversight, but one that should have demanded a product recall from Zanussi that would send a tech to every unit to install a pcb with a beefier trace. Email Zanussi and complain! Just curious...can you measure how wide is this pcb trace? It should be about 1/4 inch wide.
Sep 19, 2007 | Zanussi 24 in. ZSF6160 Free-standing...
Dishwashers Logo
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
