SOURCE: Door on refrigerator won't close and stay closed.
You will need to replace the gasket. The gasket seems to have failed and that is where the magnet is. You can try to clean the magnet surface and the door surface with rubbing alcohol but you are most likely going to need to replace the gasket
SOURCE: GE side by side. Freezer cold, fridge kinda cool
i had a similar problem, i found that the small mast on the motor turning the fan was just spinning and the fan was spinning just a little bit because it sits on there. I took the plastic fan off and put tape around the mast of the fan motor and placed the fan back on so it sat on there tightly. The fan blew cold air again because it was able to **** up the cold from the coils again, compared to when it was very loose.
SOURCE: When we close the refrigerator door (side-by-side
There is something not fully in place holding the door from closing completely. It doesn't take much. You should be able to feel slight resistance when opening if it is seated properly. The cavities are connected so when you close the door fast the air pressure moves from one to the other and pops the door open.
Eric
SOURCE: Recently I have noticed that the seal on the
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
That is not that hard to fix and you can easily buy the parts yourself
online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
