Just got tesco black ink cart for sx415 and now its saying all other carts unrecognized!? help
Mix-it-up
  • 832 Answers
SOURCE: MFC 640CW not refilling with new ink cart.
Unplug printer from power. Wait a minute. Take all carts out. Plug machine to power. mfc demands carts. Reinsert carts (have a look if they all filled with ink!!). If asked press 2 (No change) despite you use a new cart press 1 Yes cart changed.
Should work!
Posted on Nov 03, 2007
Mix-it-up
  • 832 Answers
SOURCE: Brother MFC440CN
Did you use generic ink carts? If yes ink has stained the led control. Try to clean it by help of a towel. In some cases this will help. If not, the led control needs replacing!
Another solution:
Did you answer the question given by printer when changing the cart?
You might take all carts out, unplug machine from power outlet. replug to power. wait until machine demands carts. Place cart in and answer question.
Posted on Feb 22, 2008
Mix-it-up
  • 832 Answers
SOURCE: LCD show "NO CARTRIDGE" after installing new ink cartridges...
next move: give to back due to guarantee. there is nothing what you can do!
Posted on Apr 08, 2008
yooperbud
  • 8637 Answers
SOURCE: HP 7680 BLACK INK CART NOT RECONIZED
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
  • 1584 Answers
SOURCE: Canon ip4300; new printhead and PGBK ink cart but it won't print
Perform Print head clean should do the trick. May have to repeat.
Posted on Dec 03, 2009
Hallo I have a problem with my EPSON sx415. I bought new analog ink cartridges (not genuine). I puted it in my printer and tryied to print. But paper was white. So I decided to clean printers head with...
you will have to spend more money my friend! the epson ink is called durabrite, the cheaper cart you got is water based, the head should have been flushed before hand to remove the durabrite ink, what has happened is the 2 types of ink have mixed in the head and set. the only way to fix this is to remove the head from printer and have it ultrasonic cleaned, i had the same problem and tryed cleaning products with no affect! the only wat is to get it ultrasonic cleaned, or if you have the epson carts, put them back in and try and get it exchanged if still under a year old. as a new head is about the same price of the printer, however argos has the printer on offer at this min for only £39.99 which is cheaper than ink. oh yea, the reason that the printer is now not seeing the carts is that doing back to back cleans emptys a new set of carts after only 5 or 6 head cleans so your new ink is now useless, sorry for the bad news.
Dec 24, 2010 | Epson Office Equipment & Supplies
Printer won't recognize ink cartridge
you can try by cleaning the copper contacts on the cart .. and if it works fine with the old cart i.e if it doesnt gives any error with the old ones then possibly the problem might be with the new cart..
Oct 23, 2009 | HP PSC 950 All-In-One InkJet Printer
Error message reads: left cartridge incorrect.
hello there :
this error refers to the black ink cart not being detected .
possible the new cart has a some fault on it ., u can confirm it by checkin for any defetc , leak on the cart itself or test the printer with another black cart , (if u hav one ).
*if the old black cart is still detected by the printer though the ink is low ...then jus call dell tech support ., with the order # for ur purchase and the cart replaced .
each dell cart u buy has 2 yrs warranty on them .so use them
hav a gooday !
Jul 19, 2009 | Dell 924 All-in-One InkJet Printer
Canon MX850 willnotprint from Large Black Ink Cartridge - PGI-5BK
Ink Carts do act finicky at times. Especially Canon carts.
In many cases, the ink carts have a small fuse built into the back of the cartridge that opens up if the cart has been removed for any reason. Replacement Carts come with the fused portion reset, thus when you insert it into the printer, it works great. If the cart is FULL, it still may not be observed as full or new by the Printer itself. Best way is to use a new cart, not necessarily a Canon Brand. Use an inexpensive company like
https://www.carrotink.com/canon-pgi-5-cli-8-combo-10-pack-ink.html
Feb 15, 2018 | Canon PIXMA MX850 Multifunction Printer
Brother MFC440CN
Another solution:
Feb 22, 2008 | Brother MultiFunction Center MFC-440CN...
Ink problems....
Take all carts out of the machine. Have a look into the cart holder. Is there ink swapping beneath the white plastic? (You might shake the machine ;-)
If yes, the cart holder leaks and needs replacement.
If not (your lucky!) it could be that the automatic cleaning procedure which starts when a cart is changed has soaked the carts empty.
Do set machine with date and time and NEVER unplug NOR use a power switch which breaks the power supply.
Do use constant power and switch off machine by pressing stand-by-fax-button!
Everytime when machine comes to (new) power contact it runs an extensive ink cleaning procedure. thats why your carts are always near empty....
The stand-by will prevent this and machine does some cleaning procedures which consumes only a few drops(!) of ink!
The display asks you if you have changed the carts. Do answer this question by pressing 1 for YES or 2 for NO.
This will reset the built-in inkcountermanagement to the correct settings
Jan 22, 2008 | Brother MFC 210C All-In-One InkJet Printer
PRINTER SAYS NO CARTRIDGE CARTRIDGES HAVE BEEN CHANGED
Unplug machine from power outlet. take all carts out. leave cover open. wait 5 min. plug machine to power and close cover. machine will demand carts. reinsert carts and answer question given on display.
If you still have trouble this might be due to the generic carts which have not the right construction. use original carts.
Dec 17, 2007 | Brother MFC 420CN All-In-One InkJet...
Does not accept black ink cartridges
Did you use generic ink? These generic carts are different (no seal to prevent staining). This carts stain the led control circuit board which has to be replaced by a new one (the spare part is only avaiable as the whole ink cart holder incl. led board and tubes).
There is no way to do a short fix, sorry!
Nov 28, 2007 | Brother MFC 240C All-In-One InkJet Printer
Edweard
Take all carts out. Close cover. Unplug machine from power. Wait a minute. Plug in machine to power. Machine demands carts. Insert new (!) cart as demanded from machine. In case when asked push 1 for YES: cart changed.
BTW:
Always print until machine stopps printing. Display says NO INK XY. After replacing the cart machine will print the rest data out of its memory.
NEVER change cart when machine says low ink (This is only a hint to buy a new cart!). At this point the cart has about one third of ink left!
Nov 01, 2007 | Brother MFC 420CN All-In-One InkJet...
k24674
jasbo
jasbo
Marvin
Marvin
