I have a paper jam in a cannon PC 720. I cannot find any paper inside when I open it up. When I press the button to start copying, it sounds like it is responding but after a few seconds it stops and the paper jam symbol comes on. Of course, there is no copy printed
  • 3 more comments
  • MJLIPTON Aug 03, 2008
    I already left it unpluged over night without good results.
    I have already left it unpluged over night
    but the results were the same. paper jam symbol
    How can I examine the paper path? I lift the lid and see the rollers but I cannot see
    anything caught between the rollers. Can I safely turn the rollers with my finger without causing any damage to the machine?
    mjlipton
    where is the paper sensor?
  • George Gedye Jan 04, 2012
    I know this is an old thread but I'll put this info here for others who may come across the same issue.
    This is an old and well documented problem with the PC720 and PC740 copiers.
    The problem is a spring that has come off one of the gears.
    If you look to the back of the machine you will see a pivoting housing that contains some white gears.
    At the top of this housing you will see a piece of metal that sticks up and has a slot in it. One end of the spring was hooked into that. The other end of the spring hooked to a small piece of plastic down and a bit toward the feed side of the copier. The plastic "tab" has probably broken right off and usually you can't even see where it is broken. The solution is to look through the machine for the missing spring (usually in the same area); it should be a fat little one about an inch long. Drill a small hole in the plastic that is remaining and hook the spring back up. Make sure to drill the hole so it is not too close to the plastic edge. You may have to reshape the end of the spring again to get it into the hole. I spent more time finding the spring than I did repairing the machine.
    Genius:
  • 1,689 Answers
Paper sensors are usually located on the far side of the printer, like the lock that keeps the rollers in place, try to remove the toner set first, then examine the rollers and the paper path(it is the route of the paper from the feeder tray out)
once you have the paper jam error out, try to clean the rollers using low % ethyl alcohol.
good luck, hope this helps
Posted on Aug 03, 2008
  • 6,487 Answers
Have a close look at the paper path. There should be paper bits obstructing the path. Have also a look at the paper pickup and sensor, it might be wornout.
Hope that helps........
  • 19,396 Answers
Try first unplugging the power cable, see if it reset.
  • Ginko
    Ginko Aug 03, 2008
    Disconnect printer and wait ten minutes.
    Open all pri nter doors , check inside the front and bach door.
    Remove toner and check in deep under the toner for fragments of paper or foreign object.
    If you keep getting the error one of the sensors is faulty, and the printer must be inspected by a technician.
    Ensure all doors are closing.
Small photo paper jammed inside I cant even see it with the front open ....
If you provide the model number of the Cannon printer we can help you get that piece out.
Jan 31, 2016 | Cannon Office Equipment & Supplies
Cannon mp282 pixma ,how to fix error code 3
The E03 code indicates (1) That the Paper Output tray is closed and you are trying to print. Open the Paper Output Tray and the printer will resume printing. (2) There is a paper jam. Remove the jam, reload the paper into the printer, then press the "Black" or "Color" button,
Dec 25, 2014 | Cannon Office Equipment & Supplies
Cannon d1320 false paper jam
this happens due to overheating of the fuser unit.try resetting it
Jan 25, 2014 | Canon Imageclass D1320, Copy, Print, Scan...
Hello , i have cannon IR 2270/2870g photo copy machine ,paper jam at the time of double side copy
Open your developer unit and check sensor , refix it an close unit see........your problm solved
Apr 22, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Tried to print and it says remove paper jam and press start, tried that several times, put more paper in, powered off and it stil says paper jam...opened it up and no paper i can see thats jammed..
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 06, 2010 | Lexmark Pro X125 All-In-One InkJet Printer
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
Cannon Ip4300 - Orange light flashes on printer.
A possible paper jam has happen on the unit. Did you have an paper jam error before you have this problem?
You must clear any paper jam on the unit, check the unit for any stuck paper or object or check if there was misaligned parts inside.
Let me know for any clarifications.
Thank you for using fixya.
micro-
Dec 12, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Shows paper Jam on Canon 720 PC photo copier
Sounds funny but this model shows a jam when the exposure lite goes bad. Turn on the copier and watch the exposure lamp, should lite up and not flicker. Lamp is still available.
Nov 16, 2009 | Office Equipment & Supplies
Canon pc 720
Check if you have any matter that is blocking the paper path, also try to clean the rollers that picks up paper. If you happened that copier is in a dusty enviroment, dust could deposit on rollers, and rollers when picking up paper will start slipping. Try to clean with alcohol.
Jul 04, 2008 | Office Equipment & Supplies
Paper jam
well part inside your product (paper handler/sensor) got damaged. must be serviced / non-user serviceable part.
Jan 22, 2008 | Epson 1000 ICS All-In-One InkJet Printer
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
