Question about Samsung DigiMax Pro 815 8.0MP Digital Camera with 1GB CF Card Flash
Hi there.. I cannot find in any way the fuse for the backlight screen on Samsung Pro 815... Please help if someone know about fuses location on this digital camera.. Thank you.
  • 2 more comments
  • bmw-rail Mar 24, 2011
    Hi.. Thanks for you response.. In fact, the display backlight doesnt work.. everything work, but no power on the lamp/connector from display.. so somewhere must be a fuse for that i think.. also, i cannot see anything become hot there.. just no power for the screen at all
  • bmw-rail Mar 28, 2011
    Hi everyone.. I offer $20, if someone can show/send me a link or eletr. diagram also for a Samsung Pro 815 digital camera. I just need to know exactlly, where should be a fuse for the backlight. Everything work, just the backlight doenst in any way.. No power on the connector for LCD..
    Thanks to all.
    Very good.. Thanks a lot for your good intention !
    Also, did you know where i can find a service manual for this camera ? I cannot find it at the moment..
    Yes.. excellent.. Thanks again..
  • Samsung Master
  • 12,061 Answers
Hi, to my knowledge there are NO Fuse, fusible links nor fusible resistors in the circuit to the backlight? However I maybe wrong?
However, any fuses etc, would be in the power supply section anyway..
I suggest that you obtain a service manual, this will show you exactly where every component and it's value are in the camera..
Posted on Mar 25, 2011
  • 734 Answers
If you lost the backlight, you may have to replace it along with a display LCD screen. But it could be the intergrated circuit got too hot and shut down the LED screen. If you are lucky, it may just be moisture problem, and putting it in a ziplock bag in the refrigerator might dry it out and work again.
Posted on Mar 24, 2011
  • Arthur Tang
    Arthur Tang Mar 29, 2011
    The camera can be taken apart and you can read the IC number that LED is connected to. Then all you have to do is replace that IC and the motherboard or daughter board to get your camera working. Today, ICs do not use fuse, but it will shut down the power if too much current is drawn, or the iC itself got too hot. If you are lucky, you can stick a piece of sticky tape on the IC and get it to work for a while. The tape cools it a while longer, then makes the IC hotter to drive out moisture. Does not work all the time, but does not hurt the IC.
No picture on toshiba 42" flat screen tv
Definitely a blown fuse, you just need to locate it.
Look up the diagram for your make and model.
Dec 22, 2017 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Sony Vaio vgn-sz483n lcd screen no backlight
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jan 01, 2013 | Computers & Internet
My audio works fine but no picture.I was told to check the fuses but dont know where the fuses are located at
The slow-blow white fuse is located nearest the point of where the power cord of the tv first contacts the power supply (middle-board, usually)
However, I would suspect the backlight inverter is faulty:
I would try to look on the power supply first for popped capacitors that supply the 24v rail for the backlight inverter.
Having sound is a positive when it comes to repair. This means that only your screen is not lighting.
If you repair the 24v line and check the 5v feed also going to the ps_on (on) the backlight inverter and you still have no picture...you will need a new inverter.
Hope this helps! Please rate!
Mar 07, 2011 | Televison & Video
Toshiba 22LV505 TV-DVD:
Check the DC filter caps in the power supply first. Check the 24vdc (or 18vdc for this 22" model) to see if it goes away when the screen goes black.
There are main AC fuse, backlight inverter fuses, T-CON fuses.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 07, 2010 | Toshiba 22LV505 22 in. LCD TV
My samsung Pro 815 does not flash
the flash bulb must be dead & needs to be replaced, you can buy it online & do ur yourself or take the camera to a service center to get it done for you
Apr 20, 2010 | Samsung Digimax Pro 815 Digital Camera
Cracked lens on Samsung Pro 815
As it would mean the replacement of the entire lens assembly, even if repair is possible it would not be financially viable.
Sep 27, 2017 | Samsung Digimax Pro 815 Digital Camera
LG L4200A
Hi again !
After a few (6) hours of troubleshooting i finally fixed it !!
Underneath both powersupply and signalboard, there is a third circuitboard that sends the signal to the monitor it self (i guess). On that board there was a small, small fuse, it said F1 and 1,5A, 63V.
Soldered two cables and put a regular glass-fuse instead. Voila, it works !! Hope this helps for someone else.
Feb 21, 2008 | LG L4200A 42 in. HD-Ready LCD Television
Samsung Pro 815 Camera
YOU HAVE NOT TURN YOUR CAMERA ON OR YOU HAVE NOT INSERTED THE BATTERY PROPERLY.
Sep 27, 2007 | Samsung Digimax Pro 815 Digital Camera
Samsung DigiMax Pro 815 8.0MP Digital Camera with 1GB CF Card Flash Logo
62 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
