Question about Dell A940 All-In-One InkJet Printer
A940 will not scan
The "All in one" software freezes and the console buttons will work but always tries to Scan To Fax regardless of what is selected. I suspect a controller in need of replacing.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Posted on Aug 19, 2008
Scan wont work on mac psc 1410v
First are you trying to scan using the scan button on the all-in-one or from the computer? If you are trying to use the scan buttons, you need to install the HP full-feature software package: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=219&lc=en&cc=us&dlc=en&sw_lang=&product=458978#N193 . (If you need to expand the section marked drivers.) Uninstall the printer and disconnect the data cable before installing this full software.
If you installed the basic drivers that came with the Mac OS, you can scan using Apple Preview and Image Capture software. You can also acquire a scan from the Print & Fax > Printer browser. Open the software from the dock or from the Applications folder. In Apple Preview, choose File > Import from Scanner. In the Image Capture program select the all-in-one from the list of devices.
For the Print and Scan. Open System Preferences from the Apple Menu. Click Print & Fax and select the all-in-one. Click the Scan tab and Open Scanner. Then click Scan.
With the HP software you can launch a scan from the computer or from the scanner (but only if the monitoring program is running). You need to set up the HP Utility for the scan task manager.
This site has the full set of steps: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02456650&tmp_task=useCategory&lc=en&dlc=en&cc=us&product=458978#N2158 .
Sometimes an all-in-one will work for printing but not for scanning due to a damaged cable. Scanning requires bi-directional communication with the printer. Try replacing the data cable. If you use a USB hub or print server, try a direct connection to the computer.
I hope this helps.
May 14, 2011 | HP PSC 1410 All-In-One InkJet Printer
Cant scan
Try to scan with Preview or Image Capture apps (in your Applications folder).
If that does not work, try deleting and re-adding the printer in the print queue:
- Sys Prefs, Print & Fax
- Select the printer in question and click the minus sign at the bottom of the list
- Select the plus sign to re-add it. Look for the printer, select it and wait until the "Add" button becomes available. Click it.
If this does not work, do the same thing, only instead of the second step, right (control) click the print queue area and select Reset Printing System
Jul 12, 2010 | HP Computers & Internet
I've recently reinstalled the software for my Dell A940 All-In-One printer. It prints fine. It scans fine. But...when using the software--Dell All In One Center on the computer--when I try to...
Hi! Thats odd... Try this, Select properties and maybe you can select a tool to correct this. The scan destination may be disabled or maybe you should need to select the browse button to select the destination of the scanned material. Hope this helps and have a good one!
Apr 15, 2010 | Office Equipment & Supplies
My scan button does nothing. How can I scan?
When you press the "scan" button on the lexmark, the scanner is trying to connect to a specific software program that in this case you may not have installed.
You will want to try to test the scanner driver directly.
For windows XP and Vista, try the following.
1. Open your start menu
2. Select Control Panel
3. Select "scanners and cameras"
NOTE: for windows Vista, make sure you are in "classic view" to see scanners and cameras.
4. Check whether there is the lexmark listed in this window.
For windows 7, you will need to do something a little different.
2. go to All programs
3. Open "windows Fax and scan"
4. Click on "new scan".
5. Check whether there is the lexmark listed in this window.
If there is no lexmark, you need to check the lexmark website for drivers. If the lexmark is there, try double clicking the icon to run the scan wizard.
Thanks,
Pat
Mar 31, 2010 | Lexmark X2330 Printer
How do i scan and email a document using the a940 printer
On the printer press scan, then press options, move the right arrow key. Select e-mail and press select button. Also, go to start menu, go to all programs, Dell printer, then select DELL AIO Printer A940, then select Dell All-In-One Center. On the Scan box on the drop menu select e-mail. All set, scan from printer to e-mail.
Sep 25, 2009 | Dell A940 All-In-One InkJet Printer
I am unable to send faxes or recieve faxes
Please follow the steps given below to check wheather the error correction is turned off.
You need to disable "Error Correction," please follow the steps given below:
1. Press "Fax Mode."
2. Press "Menu."
3. Press "Up" or "Down" Arrow button repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press "Up" or "Down" Arrow button repeatedly "Error Correction" is highlighted.
6. Press "Right arrow" or "Left arrow" button until "OFF" appears.
7. Press "Select."
Please follow the steps given below to recieve the fax:
1. From the control panel, press "Fax Mode."
2. Press the "Menu" button once.
3. Press up or down arrow repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press up or down arrow repeatedly until "Pick-Up On:" is highlighted.
6. Press left or right arrow to choose an option.
7. Press "Select."
If you want to set a schedule to turn "Auto Answer" "on" or "off:"
1. Press up or down arrow repeatedly until Auto Answer Scheduling is highlighted.
2. Press left or right arrow until "On" appears.
3. Press "Select."
4. Press down arrow button to select the time for "Auto Answer On."
5. Use the keypad to enter the date and time. Press 1 for AM, 2 for PM, or 3 for 24-hour mode.
6. Press down arrow button to select the time for "Auto Answer Off."
7. Repeat step 5.
8. Press "Return" button to save the settings and exit the menu.
9. Make sure the "Fax Auto Answer" light is on.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
To scan a document, please follow the steps given below:
1. Go to "Start," "Programs," Lexmark printer, "Lexmark All-in-One Center."
To see how an image will look after it is scanned, click "Preview Now."
2. Click "Scan," "Send scanned image to."
If scanning an image, choose a graphics program such as "Lexmark Photo Editor," "MS Paint," etc.
If you wish to "Scan to OCR," choose a text program such as "MS Word," "WordPad," etc.
Once the image is scanned, the "Abbyy OCR" software will open automatically.
3. To begin the scanning process, click "Scan Now."
4. To view the additional options, click "See More Scan Settings."
To indicate what type of image is being scanned, select the "Option" next to the type of object you are scanning. Your settings will be optimized for that object type.
To indicate how the scan will be used, select the relevant option from the menu. Your resolution and other settings will be optimized based on your selection.
5. To revert back to the normal All-in-One main page, click "Hide Extra Scan Settings."
6. Under "Display Advanced Scan Settings"; you can see change settings, which will affect the outcome of your scan.
Mar 21, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Unable to scan text doc to Word
hi i thing your software is corumpt and you nead to reinstall it. when you buy your printer you have the cd whit it. but if you don't find it you cant download the torrent of ocr
bye and good look
Dec 04, 2008 | Dell A940 All-In-One InkJet Printer
Trying to scan a picture to my computer
Scarlet, I have a mid 2007 iMac and find that the MX310 does not always behave with OS X Leopard. To scan via software. Turn on the printer. Select SCAN from the printer. Press either PRINT (Black or Color) buttons on the printer. A fax - scan icon will appear in the dock and a window will open allowing you to fax. Now comes the problem. Often it will not scan the first time, I almost always get the message ¨SCAN FAILED¨ the first time I scan. Just click scan again without touching the printer will usually work. Sometimes I have to play with the settings on the left side of the scan window, switching between duplex and simplex or B & W and color and back. Usually this frees up what ever is stuck. Once it works, it works! After the scan, quit the scan and save to either a PDF or one of the photo file types (JPEG, TIFF, etc.) The results wind up in the PICTURES folder under the name of the printer and then the current date.
Jim
Jun 14, 2008 | Canon PIXMA MX310 All-In-One Printer
The Fax software on my a940 seems to be gone
gotta get the Vista friendly printer management update, from the printer mfg page.
Feb 05, 2008 | Dell A940 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
29 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
