Question about Logitech Audio Players & Recorders
I have a set of Logitech G51 speakers that have been perfect until today. They are plugged into a UPS and the UPS shut down, reasons unknown. I reset the circuit breaker on the UPS and everything (computer, printer etc) came back on but not my speaker system. The lights on the pod with all the controls are not on. I ran a separate extension cord to the speakers and still nothing. Is there a circuit breaker or switch somewhere on the unit that I can service? I can't see anything so far. Thanks! Rick
  • Logitech Master
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 24, 2011
Will this cost me?
>What about it? Are you asking about the cost of that Monster Speaker?
Isn't that beautiful.... ?
Sep 19, 2010 | Logitech G51 5.1 Multimedia Surround Sound...
There is no sound coming out of the speakers. I checked and everything is on, nothing is muted, and the green light is even going up and down when music is on. What should i do?
the problem of the no sound could be as a result of blown fuses in the audio stage of the printed circuit board, please do check for blown fuses, if otherwise take the system to the manufacturer for proper diagnosis. hope this will help..
May 28, 2010 | Logitech G51 5.1 Multimedia Surround Sound...
How can I test if my my g51 speakers are working
Hi Try using your MB Audio Programs that came when you installed your MB drivers...I know GIGABYTE Audio Programs Test sound from each Speaker that is connected....Or you can try this website and download that and test....Hope this helps
Happy new year bud :)
http://audio.rightmark.org/index_new.shtml
Dec 30, 2009 | Logitech G51 5.1 Multimedia Surround Sound...
Having trouble hooking up logitech surround sound system
Hi , just make sure that your PC has a 5.1 Channel Sound Card that can handle that Surround sound system
Thanks
Dec 28, 2009 | Logitech G51 5.1 Multimedia Surround Sound...
Speaker stops after a few minutes
I was having the same problem but I seemed to solve it by having the laptop volume maxed and using the dock to control volume. I think that it has a sleep function where if it is not getting a signal it powers off and for some reason the laptop isn't putting out a strong enough signal to keep it awake. Maxing the laptop volume seems to give it a constant enough signal so that the problem went away.
Jan 13, 2009 | Logitech Pure-Fi Anywhere Portable...
Repalcement Logitech Z5500 Control Center?
My Control center turns on but i can get any sound not even from the test system, Logitech cant help.
I went the a shop and check it on ther system still no sound :(
any ideas
Nov 17, 2008 | Logitech Z-5500 Computer Speakers
Z5300e Subwoofer Problem.
in my view, it is due to any of the following
1. its fuse burnout or wire breaked, check fuse and cordwire
2. its subwoofer coil is damaged to loud volume, replace it
3. its amplifier IC is damaged, replace IC
Dec 31, 2007 | Logitech Z-5300 Computer Speakers
Logitech g51
I'm sure you went to Control Panel, opened device manager, and and checkeck for any yellow checks for your
sound, video and game controllers. If there are none, your system is go. Then go to your audio manager on control panel, and set it up for whatever speaker configuration you have. I have realtec audio manager. This step is a must for configuring—you choose whether your laptop will use its own speaks or use your external speakers—you have to turn off the internal speakers and turn on the external. Did you forget?
Nov 08, 2007 | Audio Players & Recorders
140 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
