Question about NAD C545BEE
Hi, I have a nad c545bee and the buttons on the front panel don't work anymore. Please help Thanks.
2 Suggested Answers
AJIN G
  • 6694 Answers
SOURCE: Hi Skipping problem with a NAD
hi
There is a diode in the power supply which gives dc supply to the laser focusing coil driver ic . if the diode get faulty this problem can occur. Just replace all the rectifier diodes in the power supply stage. Its better than searching for the exact one. then check the cd player is it skips the tracks. if then also its skips the tracks then you have to change the laser pickup unit.
ok
Posted on May 19, 2011
How to connect a turntable to a nad c730 receiver
Hi
You can get a manual for your receiver here
730 Stereo Receiver NAD Electronics
by clicking on "manuals and Downloads" and then the 7 language manual.
This will download the manual to your computer where it can be saved for future reference. Page 2 shows diagrams of the front and rear panels of the receiver and clearly shows that the turntable should be plugged into the pair of sockets on the left hand side (as you look at it) of the bank of 10 paired input sockets on the rear panel.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 26, 2014 | NAD C730 Receiver
How to fix skipping problems for nad 545BEE
clean your player. your disk may be scratched if so you can't stop skipping
Sep 23, 2013 | NAD C545BEE
Locked out front control panel while in menu. Now I can't unlock front control panel and I don't have original remote control or owners Manual. Help me please. The front panel is all I use for DVD pla
Hi there, if you know what model it is you can do a google search for the owners manual. There should be a sequence of buttons you can push or hold to reset to factory/default settings.
Jan 25, 2013 | Televison & Video
Fix selector button
Best word of advice...if you don't know, call an appliance tech. It will save you alot more time.
May 20, 2012 | Speed Queen Washing Machines
Hi Skipping problem with a NAD C545BEE, plays OK for 1 minute, then skips randomly wthin the track, then will skip to different tracks on the CD, like fast forwarding. No problems with the disc themselves
hi
ok
May 19, 2011 | NAD C545BEE
Pressing the 'open' button on my NAD C542 CD Player no longer opens the disk drawer. Any suggestions to fix this would be appreciated. Regards Michael
G'Day Michael,
Having fixed thousands of CD players in my career, and also being a NAD Authorised service guy from 1989 till recent times, I can comment with some authority to your situation, and correct some of the ill found assumptions given to you already.
This unit uses a KSS213c transport. Very common and used in many machines, also relatively reliable.
The drawer load motor is not shown above. Is will be mounted on the black plastic load assembly. The drive belt/motor for it will be under the tray runners.
If you do not hear the motor run, then it WILL NOT be a broken or failing belt. However, this is the most common problem with this style of transport. I would be checking anyway to see, the load motors do free run fairly quiet with no drive belt connected. Wind the tray assembly out by hand by kicking the gears over to open the draw to see the belt/motor
Because you cannot get it to work from the remote, AND you have "open" indicator on the front panel, it WILL NOT be a faulty front panel button(never seen one fail ever!)
I have never replaced a load motor to a Sony transport. Spindle motors can be a problem, but they never stop working altogether.
I would be checking the tray mechanics, a jam caused by something fouling the gears may cause a fail. Tap the front of the draw as you press eject to see if you can encourage it to work.
Sometimes, small nylon drive pinions can split, the excessive gap in the gears caused by the split causing a bind. Check also for blown pico fuses in the servo drive stage. This will cause no drive to the load motor.
If you cannot pin down the source of the problem, the player IS welll worth repair. These machines sound great and would have cost you a few bucks to begin with. If you need help locating an expert NAD authorised repair guy I can help.
Happy to discuss any of this further with you. As previously direct your comment to me by name. Cheers
regards
robotek
Aug 03, 2010 | NAD C542 CD Player
Hi, The dial doesn't turn anymore and you have to push it in hard and try and work out what setting it is on. Also the start/hold to reset button has to be pushed several times to get it to start and has...
You have probably dislodged the plastic moulding in the control module that hold the buttons in place, you will have to remove top cover, soap dispenser draw, and front panel to gain access to the control module.
Please rate my solution.
Thanks.
Jul 24, 2009 | Hotpoint WMA32 Front Load Washer
Nad 743 shuts off at -14db vol. Why?
mine got fixed by replacing the front panel PCB with control processor. Only 350€...
Feb 28, 2009 | NAD T743 Receiver
My NAD T763 turns on but no sound comes out of any speakers
HI,
I had the same problem and AH reset did not work. IS there anything else i can do?
Thanks
Adrian
Dec 02, 2008 | NAD T763 Receiver
NAD T762 stuck in standby
Remove the power plug first, try to find the Battery inside the unit,Remove it, just for a minute, or two, and put it Back, hope it work again.if you don,t find in the users manual ,how to reset !
Oct 17, 2017 | NAD T762 Receiver
NAD C545BEE Logo
107 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
