Question about Goldstar Heating & Cooling
Regarding the Dual Zone Multi Split Cooling only Unit model GM0240C The pamphlet indicates the Max. Length of the line set is 50'. is this the Max length to each indoor unit or this the Max. length for the two indoor units. (25' to each indoor unit for a total of 50'). Thanks .. Gerry. R.
Speed boy
  • 76 Answers
SOURCE: York Mini-Split Not Cooling? : (
This can only be a gas problem.
the split units goes on on and off if a shortage of gas is involved, the chances that you would here it wont be that big for the fans would make too much noise.
get a repair man for a re gas and all is well.
Good luck.
Wouter.
Posted on Oct 22, 2008
  • 398 Answers
SOURCE: Camper A/C extension cord length
http://www.campingworld.com/shopping/item/marinco-park-power-50-amp-locking-adapter-with-25-30-amp-cord/15889
this is what i use
Posted on Mar 02, 2009
SOURCE: ac split unit indoor an ouydoor unit electrical wiring diagram
machine off
Posted on Apr 25, 2009
relaga58
  • 158 Answers
SOURCE: my office room model dimensions are
u need 1 hp unit
Posted on Nov 25, 2009
  • 384 Answers
SOURCE: I have problem regarding water tapping in indoor
dear sir /madam
please do every week clean your split type a/c,s filter it,s main coz who responsible for block the drain water line and after that split indoor drain ac unit drain water from inside of the unit , try to find out the drain water line of indoor unit of air conditioner the make clean it and also check it i mean keep some fresh water for make test its drain line it have been open or not if water is going easily then ,it,s ok
it,s up tp you if you think you can do it or contact to it,s technician for do solve this problem.
thank you for using fixya for get solution
hope answer the question
please vote!
Posted on Sep 16, 2010
1.ton ac capillary pipe size and length I want to know. B coz suction line cooling level is very low gass psi 75
I'm guessing you should have 3/8 & 5/8 copper on that unit with a maximum of 50 feet. I doubt the line set size is affecting your pressures that significantly, you likely have a leak.
May 05, 2017 | Heating & Cooling
Multi zone mini split
The package of multi condensor is pre charged. No need to charge again unless if there was leak.
Feb 16, 2014 | Midea Heating & Cooling
WHAT IS MAX LINE SET LENTH FOR 12,000 BTU ART COOL COOLING ONLY UNIT? CAN I GET INSTALL MANUAL ON LINE?
Length can be any thing you want....EXCEPT both pipes MUST increase to the next LARGER size every 25 feet.
Jun 04, 2011 | LG Art Cool LA121CNP wall/window Air...
E 7
Multi Splits and Multi V = indoor unit is set to run in a different mode from the master indoor unit. Set ALL indoor units to cooling or ALL to heating to clear.
Splits = Compressor Over Current (CT2), Check loose wiring/condenser coil for clean
Jan 10, 2011 | AmcorAire UCHW-H24AF2 Split System Air...
Location of compressor to wall hung unit
According to the manufacturers spec sheet the 1.5 ton unit can have a max line length of 100'. This info was obtained from http://dl.owneriq.net/b/ba099899-54f3-45d6-a374-1ce6d249205a.pdf
Hope this helps.
Jul 24, 2010 | AmcorAire UCHW-H18AF2 Split System Air...
LM-2430C2L 24000 BTU Cooling Only Dual Zone Mini Split Air Conditioner: Does LG makes AC which can cater two rooms at time...
Yes they Do they are called Dual Zone Units. At http://www.paylessminisplit.com they are very helpful if you call them they can answer alot of questions about many brands of mini split air conditioners.
May 16, 2010 | LG LM-2430C2L Cool Mini Split Air...
Indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Apr 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Heart rate zones
Heart rates are known by the garmin software as zones, numeroted 1 up to 9.
You can set on the software your heart rate, based on :
- HR max ;
- intermediate HR, linked to the zones.
Then, when you upload a session in the software, you will analyze the zones you ran in.
Another tip : to set on the Garmin itself, the Zones to ON,then Z0 to ON, and Z0 HRM to ON : here you can indicate your HRM low (ex : 165 for me) and the HRM High (185 for example). Then during your session, an up or down arrow will appear, indicate if you run below your HRM low (aerobic zone), your anaerobic zone (betwin HRM Low and High) or in VO2 max.
Hoping that's clear and that can help you.
Feb 20, 2009 | Garmin Forerunner 50
How to set page length in computer for dot matrix printer model wep 800DX
to set up page length in inches
?? chr(27)+chr(67)+chr(0)+chr(12) - for 12" page length
to set up page length by lines
?? chr(27)+chr(67)+chr(50) - for 50 lines / page
Jul 20, 2008 | Epson LQ-2180 Matrix Printer
Samsung split system air conditioner model as24bpa
Suction-5/8"
Liq. line-1/4"
Max pipe length-50'
Max vertical hight bet. accu and fcu-25'
Jan 06, 2008 | Samsung AS18A6RB Air Conditioner
Heating & Cooling Logo
41 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
