Question about Hilti Tools & Hardware - Others
Need to get a new piston where can i get one from
  • 4,234 Answers
Since you don't specify the model number, I can;t provide specifics. Use the link below and enter the model number in the upper right hand corner or select the category to find the part you need.
Dan
Link: http://www.us.hilti.com/holus/page/module/product/prca_catnavigation.jsf;jsessionid=EEE6A44B2C043FD466974115009CBC71.node4?lang=en&nodeId=-71302
Posted on Mar 24, 2011
2003pontiac grand prix how compress the piston by compressing or by turn in ?
What you need to do is lift the car take out the wheel where crank shaft is,
also know as the harmonic balancer
Jan 20, 2013 | 2003 Pontiac Grand Prix
My 24v 95 landcruiser fzj80 needs new pistons after a gas conversion disaster. I have stripped it down and have the head off ready for the new pistons. I phoned toyota to order 6 new ones only to be told...
the engine and vin numbers supplied to Toyota customer / technical division should be able to tell you which pistons were in that engine
failing that go to an engine reconditioning shop and talk with the mechanics there as they replace pistons all the time
Aug 10, 2017 | Toyota Land Cruiser Cars & Trucks
My bike is smoking a lot changed piston valves seals guides but no good result can ya giveany tips
New valves, valve guides, valve guide seals; all fine but probably not needed. When the piston was changed, did you run a cylinder hone in the bore to check for distorted cylinder walls? Was the old piston seized up at any time? Were there scratches or grooves cut into the cylinder wall from being seized? Did the new piston get new rings? Chances are you will need to have the cylinder bored then install a new 1st oversize piston and rings. Please rate my answer.
Aug 10, 2011 | 2005 Honda CRF 230 F
How to replace a piston on an 06 sonata
You should not need an engine piston on such a new vehicle.
Do you mean a brake piston or something?
If you threw a timing belt, you don't have to replace pistons, just the valves.
If a piston really were bad, you need to take the head off, drop the oil pan, mark and remove the rod cap, and then push the piston and rod out the top.
If the car was not so new, you would also have to **** the ridge off at the top of the cylinder. But probably unnecessary after only 4 years.
May 04, 2010 | 2006 Hyundai Sonata
How do i remove piston pin from 375 poulan pro
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
I suggest you look around the above site. Someone here has been where you are. You can join for free and they are a very helpful group of folk.
Apr 21, 2010 | Poulan Pro Chain Saw 46cc 20"
My hyundai accent piston rings need a change how
If it needs rings, it probably needs a lot of other engine work, like a cylinder hone, or if it's out of spec, a bore, which means new pistons and on. You might look into a good remanufactured engine that comes with a warrantee if your has a ton of miles on it.
Apr 13, 2010 | 2002 Hyundai Accent
1987 polaris trailboss piston
Sure - it is worth fixing when a new one is 2300
Mar 31, 2010 | RTO 200cc Full Size Four Wheeler ATV
Calipers are hung up
This usually happens after a long period of storage: the first time you apply the brakes, they fail to release their grip on the brake rotors. Moisture in the system causes corrosion to develop which prevents the caliper pistons from retracting when the brake lever (or brake pedal) is released.
What you need to do is take the calipers apart and remove the pistons. With the pistons removed, carefully pry out the rubber piston seals and soak everything in soapy water. Using a dental instrument or similar device, be sure to clean all of the corrosion from the groove where the piston seal fits into the caliper. Replace the seal and reassemble everything using clean DOT3 brake fluid as it goes back together.
Refill the system with new brake fluid and bleed out the air. Once completed, your brakes should work like new.
Oct 24, 2009 | 1979 Honda GL 1000 (K3)
SEIZED PISTON
excessive piston clearance.really needed bore job with oversized piston,not just honed and rings.measure piston to cylinder clearance,check spcifications and verify
Apr 05, 2009 | 2003 Yamaha YZ 125
Piston ring installation on 96 geo 1.3 liter 4 cyl engine.
If you are that deep into things you will do poorly without a good manual. Are the pistons new or used?If they are used you need to completly clean the ring grooves in the pistons or the new rings will stick and gall.Did you remove the ridge at the top of the cylinders? If not there is a good the top ring will either break or bust the upper land off of the piston. Hopefully you had a machine shop go through the block. Check the ring manufacture's web site. I am sure they will have tips and instructions.
Nov 29, 2008 | 1996 Geo Metro
Tools & Hardware - Others Logo
83 people viewed this question
Top Hilti Tools & Hardware - Others Experts
john h
Are you a Hilti Tool and Hardware - Other Expert? Answer questions, earn points and help others
