Question about Kodak EasyShare C180 Digital Camera
Not downloading to computer Kodak easy share C180
  • kakima Mar 24, 2011
    Have you considered NOT connecting your camera to your computer? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
    Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
  • 823 Answers
Did you install the software and/or drivers before connecting it to your computer? if not, the computer won't recognize the camera. If you don't have the disk that came with the camera, you can get the software for free from Kodak's website. Download the software and drivers, then reconnect the camera to the pc with it turned on. That should solve your problem.
Posted on Apr 22, 2011
5 Suggested Answers
  • 141 Answers
SOURCE: Is the kodak easy share c180 digital camera webcam?
I won't say the camera is usable as a webcam because you will definitely severly shorten the life of the camera by using it as such. Firstly the camera is designed to take photos and short videos, NOT being left on continuously for use as a webcam. The heat generated by doing so could damage the delicate CCD (the part which collects light from the lens and converts it into electrical signals) Secondly most cameras are deigned to switch themselves off after a certain period of non use. Not handy for webcams.
Next there's the power issue. Unless you are using an external power supply for the camera you will be forever replacing batteries and for what an external power supply costs you could buy a proper made for the job USB powered WebCam complete with focus and sometimes zoom.
Next there's the mounting issue. Where will you mount the camera to give a well lit and steady picture of your face. Definitely not on top of the monitor due to extra heat generated by the monitor itself. Mix that with camera's heat and hello, and too soon, goodbye camera.
Webcams cost $20 if ou shop around maybe cheaper. OK your cmera will give a better picture but at the distance you're talking it won't matter. Plus you will need software to generate the webcam picture. MSN is a good webcam program. Plus depending on the output of the camera, usually only video. You may need a video capture card for your computer. The camera will give you a full screen image of what it's pointed at but you need a box to put a smaller picture in on the screen otherwise all you will see is one big face, yours.
So do you really want to wear your camera out prematurely simply because you can't afford a $20 webcam. The made for the job unit is cheap, will stay on all day and the power comes from the USB port. Everything you need and cheap. I think you know which way to go.
Good luck
Posted on Apr 22, 2010
lock123
  • 6831 Answers
SOURCE: Kodak Easy Share CD1013 pictures won't download on Vista
Hello and welcome to FixYa
Please go to a electronics store and buy a USB card reader. I bought one last week and it cost $0.5 so its cheap as dirt. Then simply remove the card from your camera , pop it into the reader and the pictures will appear on a drive like a flashdrive in your my computer folder.
This is a much better option than using the camera's cable as it is faster , safer , saves on your camera battery and you don't need to install any software or drivers.
The card reader will most likely also still be compatible with any new camera you buy in future.
Kind Regards
Andrea
Posted on Sep 27, 2010
  • 102366 Answers
SOURCE: i hav kodak easy share
Here's the page from the extended user guide:
http://resources.kodak.com/support/shtml/en/manuals/urg00964/urg00964c3s2.shtml
Posted on Jul 29, 2011
  • 102366 Answers
SOURCE: can't change date and time changed on kodak easy
Press the MENU button. Use cursor-left/right to select the Setup tab. Use cursor-up/down to select "Date & Time". Use cursor-left/right to move between fields, cursor-up/down to change them. Press the OK button when done.
Posted on Sep 06, 2011
Where do I find the menu on a k9dak easy share c180
Hello Linda,
You can click these links and they will take right to the download page and save them on your PC further reference.
Good luck
JP
http://resources.kodak.com/support/pdf/en/manuals/urg00965/C160_C180_UG_GLB_en.pdf Kodak NOT FOUN C160 Extended User Manual Back View
Jun 25, 2015 | Cameras
Download Kodak easy share c180 to next book 8
Check Kodak's website for a firmware update for your C180; it was designed for Windows and Mac but it is not likely compatible with Android used in the Nextbook.
Jan 02, 2015 | Kodak Cameras
Camera shuts down when i use the zoom.easy share c180
Using the zoom requires the motor which pulls more power than the camera when idle. If the battery is close to exhausted it will shut the camera off when you zoom. If this isn't the case your zoom may be stuck and the camera shuts down to prevent damage.
Oct 13, 2014 | Kodak EasyShare C180 Digital Camera
Can't change date and time changed on kodak easy
Sep 06, 2011 | Kodak Cameras
Does a kodak easy share c143 have a volume
No. It records audio with video, but on playback lacks a volume control.
Aug 21, 2011 | Kodak EasyShare C180 Digital Camera
I hav kodak easy share C180 & some of pics are locked it is showing as lock plz help me out to unlock it
Jul 29, 2011 | Kodak EasyShare V1073 Digital Camera
I bought a kadak easy share camera c143 and cant hear any sound on the video
The question and answer from the following site will answer your question:
http://www.xkaw.com/Livelihood/Consumer_Electronics.asp?id=1564750
I copied it for you.
"Question Does the Kodak EasyShare C180 capture Video Sound?
2010-7-2 21:13:19I just bought this camera, and i opened it at home and LOVED IT. its cheap and affordable, but i was just wondering if it was SUPPOSED to capture sound on videos because if it is, mine doesnt. Thanks :)
Answer Kodak EasyShare C180 is a simple camera, Video capable camera w/NO SOUND.
"NOTE: Sound cannot be played on the camera. Sound is heard after the video is transferred to your computer."
http://www.amazon.com/gp/product/B001OC7...
Other best Kodak cameras : Kodak Easyshare M341, Kodak EasyShare MD41.
Kodak Easyshare M341 : 12.2MP, 3x optical zoom, 2.7-inch LCD screen, Smart Capture feature automatically identifies the scene and adjusts camera settings
http://www.amazon.com/gp/product/B002IVV...
Kodak EasyShare C180 is a simple camera, Video capable camera w/NO SOUND."
Jan 17, 2011 | Kodak EasyShare C180 Digital Camera
Recieved Kodak Z915 for Xmas. Follow directions
Please follow the instructions:
  1. Uninstall Easy Share software:
  2. Select Start > Settings > Control Panel > Add / Remove Programs.
    For Windows XP operating systems, select Start > Control Panel > Add / Remove Programs.
  3. Select Kodak Easy Share software.
  4. Select Remove (or select Change, and then select Remove).
  5. Run the Clear utility:
  6. Visit the CLEAR Utility for Kodak Easy Share software Web page at www.kodak.com/go/clear
  7. Click the Download button, and then follow the on-screen prompts.
  8. After restarting your computer, visit the Kodak Easy Share software Web page at http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=15222/15223&product=EKN036302 and install the latest version of Easy Share software.
Jan 06, 2010 | Kodak EasyShare Z915 Digital Camera
Can't get easyshare to start download
If this fault message is on your computer starting Easy Share Software: Please do a Clean Install on the software:
    1. Select Start > Settings > Control Panel > Add / Remove Programs.
    2. Select Kodak Easy Share software.
    3. Select Remove (or select Change, and then select Remove).
  2. Run the Clear utility:
    1. Visit the CLEAR Utility for Kodak Easy Share software Web page at www.kodak.com/go/clear
    2. Click the Download button, and then follow the on-screen prompts.
  3. After restarting your computer, visit the Kodak Easy Share software Web page at www.kodak.com/go/easysharesw and install the latest version of Easy Share software.
Dec 16, 2009 | Kodak EasyShare V1003 Digital Camera
Kodak EasyShare C180 Digital Camera Logo
132 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
