Question about Whirlpool Washing Machines
Fills with water but won,t adgitat or spin the motor is running the belt is good but it looks a litell losse
  • 1 more comment
  • gabe_t
    gabe_t Mar 24, 2011
    What is your model number?
  • rogeralanads Mar 24, 2011
    the model # is
    the model # is LA5800XKW1 top load it fills with water the motor starts the belt turns all the pullys then it drians fills with water again. it keeps doing the same thing. this washer will agitate with the lid opan the switch is ok.every thing looks good. the elictric solinnods won,t in gage the levers that make it adgitat
    the
  • rogeralanads Mar 28, 2011
    I took the whasher apart completly. I did not find a thing wrong the plastic gear is fine.the rubber conection is ok.the spin switch ok so what is wrong. could the cotrol switch be bad.
  • 2,382 Answers
Hi, if you washer won't spin/agitate, and the motor is running with a good belt troubleshoot the washer with my expalanation below.
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
The motor coupler may be broken. Many Whirlpool manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
The transmission may not be shifting properly. Older washers produced by Whirlpool have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Posted on Mar 24, 2011
What needs to be replaced? I installed a new motor but my washer still won agitate or spin.
check / replace the start run capacitor for the motor
have a electrician do it or a service technician if you do not recognize it
it is normally up near the control panel
Oct 19, 2015 | Haier HLP21N Washer
Amana washer won't spin, drains and fills with
DIRECT DRIVE OR BELT DRIVE? CHECK MOTOR COUPLER OR LOSSE BROKEN BELT? IF DIRECT DRIVE THEN CHECK THE CLUTCH FOR SLIPPERAGE, THEN AGIN A SIMPLE SOLUTION SOMETIMES THE DOOR LOCK SWITCH IS BAD AND IT WILL NEITHER SPIN NOR WASH ? CHECK THESE WITH A MULTIMETER, ITS EASY AND CAN GET CHEAP MULTIMETERS AT MOST HARDWARE STORES
Sep 13, 2014 | Washing Machines
Washing machine fills and agitates but won't spin or drain, just hums.
When the machine beeps it is giving you a code with the 8 wash progress lights along the top. Some will be on some will be off. With OFF = Zero and On = 1 Can you give me the 8 digit code. An example is (01001001) It is normal for the pump motor to get very very warm. Make sure you can spin the pump impeller easily.
Aug 09, 2014 | Fisher Paykel EcoSmart GWL15
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
Kenmore 80 series model # 110.82382110 fills, agitates and drains but won't spin
Based on the information you provided, you need to replace the wig wag on the unit. No joke, that is what the part is called. Here is a link to the part to order.
Nov 05, 2012 | Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Sep 30, 2012 | Roper Washing Machines
Won't spin fills and drains water if i manually turn dial
Direct drive or belt drive? If belt drive then thats easy, motor belt or pulley. Direct drive? motor, ,,, maybe.
Jan 11, 2012 | Frigidaire GLTF1240A Front Load Washer
Will not fill with water or agitate but will spin.
The problem might be due to the motor is trying to run and can't or does'nt start or the motor is running but the belt broke and so it is not transfering any power.You will need to take a look and see which is the case.
Motors and belts can be challenging to repair so be warned if you are attempting the fix yourself. It does depend on the machine some are harder than others....
Mar 28, 2010 | Maytag Washing Machines
Maytag HAV2360AWW will not start
Check the back of the lid their is a litel plastic button to make sure the lid is closed see if not broken or stack
or see if drain pomp V belt is out of place or broken
this is the simple way
Dec 19, 2008 | Maytag HAV3460AWW Top Load Washer
Washing Machines Logo
35 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
