Question about JVC Gumy Ear Bud Headphone - Peppermint Blue
I can not hear anything out of my right ear bud
    Master:
  • 519 Answers
Would you like to try bluetooth wireless eadbud
Amazon com YELLWWORSE Bluetooth Headphones V4 1 Wireless Sports Stereo...
Posted on Nov 28, 2016
Hi there thobe47!
Please test the pair with a different audio device and see if the problem goes away first!
Firstly, make sure you are pressing the plug all the way into your audio device jack. Most are designed with two tiers, so only one ear will sound if only one tier of the electrical connection is fully established. Once you've tried that, continue!
Most earbuds are created with very small working parts with equally small electrical connections. If you have lost sound in one side, the most likely cause is a loose connection somewhere.
If it still doesn't work, your options are sort of limited. I would recommend first gently "jimmying" the wire leading to the bad earbud around while it is in your ear and music is playing. If you manage to get the sound to be restored, wrap sticky tape tightly around the wire and the tapered part of the bottom of the earbud in an attempt to maintain the new connection. It is not a permanent fix but might buy you a bit of time with the pair.
If you can't get it to work in that way, your remaining options are pretty much to either open the earbud and attempt to reestablish the connection (difficult, small parts, and could damage the earbuds if you don't know what you are doing), or to buy a new pair. You can get some pretty nice earbuds for under $5 at most megastores, and anybody who could fix them and would charge you will charge you much more.
If you must try to open the earbud (I don't recommend it!), I have a generic set of steps here. I take no responsibility for damage of your earbuds or devices that may follow!
Gently peel back the gelly cover of the earbud, starting under the top seam and pulling it off.
Unscrew or "pop off" the portion of the earbud that has the small grating. There may be an inner retaining system involving more plastic rings. Just keep these safe and remember the order in which you took them apart.
You will now probably be seeing the speaker of the earbud, looking like what you might see on an uncovered subwoofer speaker (just much smaller!)
Being careful to not touch the flat portion of this disk and avoiding anything magnetic (including your laptop / desktop), see if you can pinch it by the sides and gently pull it out of the casing -- probably less than a quarter centimeter. If you can, look for any severed connections between the solder points on the bottom of the speaker and the wires coming from the bottom of the bud. Soldering these would be extremely difficult, but you can attempt to fix them with small pieces of tape.
Nestle the speaker back into the housing, replace any retaining disks in the correct order, screw/pop the outer clip back on, and slide the gelly back into place.
Hope this helps!
Posted on Mar 25, 2011
My samsung s4 has a problem when i call someone they can hear me but i cant hear them .i tried testing my ear piece by pressing *#0*# and tested its working fine. After testing it would work...
Do you have the correct type of ear buds for the Samsung? When I first got my Samsung phone I only had ear buds for the iPhone, but they are wired different than ear buds made for the Samsung. I went online and bought ear buds for the Samsung and now all is copacetic.
Feb 24, 2015 | Samsung Cell Phones
Alcatel evolve, people can't hear me but I can hear them
Try plugging in ear buds with a built in microphone and call someone to see if they hear you while you speak into the mic. If they can hear you then there must be a problem with the ear bud or head phone input. Some times the connector inside the female plug gets stuck and it fixes itself when you plug a jack into it then pull it out.
Sep 01, 2014 | Cell Phones
Jvc gumy ear bud headphones purple
When you pull the wire up does it increase the right ear bud volume/ sound? If it does, then it means the right side ear bud has a short within the head phones circuit which is aka the wire that leads to the musical device in which the ear buds branch off from.
If the right side ear bud does not produce an increased volume for sound by picking the wire up or pulling it in towards you or to the left side of your body or musical device then it means that the right speaker is blown.
I know that all head phones come spiced together aka they are stuck together and have to be pulled apart in order to get both head phones seperated from each other so that they can be worn in the ears. If you pulled the wire apart to much or too quickly then that is what ruined the right head phone.
I suggest that regardless if the ear phones begin to work by pulling the wire up,side ways, or into towards your body that you return them back to the store since after awhile the problem will eventually continue to happen causing the right ear bud to completely blow. Once you return the ear phones be cautious with the new set when you seperate the ear buds from each other since they are very touchy and have to be handled with delicateness when seperation is taking place.
Please let me know how it works out for you. I have had many ear buds and I tell ya something; they are very easy to blow one side when seperating. I had to learn after a few pairs that I was ruining the speakers by the way I was seperating my wires. I kept thinking for the first 3 pairs that the store was selling blown ear buds until I began having same problems with another few stores so I said to myself "well the solution is to figure out what I am doing wrong in order to blow one side of my ear buds every time". After few seconds it was not that obvious that all I had to do for assembly was to pull the wires apart in order to get both ear buds to go into my ears.
Jan 22, 2014 | JVC Gumy Ear Bud Headphone - Peppermint...
I can't hear people but people can hear me
It could be a speaker issue. Try using you phone on speaker phone, or ear buds with with built in MIC or blue tooth headset. If it works with these options then its an issue with the speaker. If it doesnt work even with other options then its a more serious issue
Apr 09, 2013 | ZTE Score
When i put my ear monitors on i only hear on one side i bought a nother pair of ears but now when i sing the music in my ear cuts out?
You may have bought "noise cancelling" ear buds and those cancel out local noise... NOT the type you want for this application !!!
The wires to earbuds are really tender and easily damaged... Make sure the replacement earbuds are the right type for use with your wireless... if necessary, call the vendor to verify.
Dec 13, 2010 | Shure P2TRE2 PSM200 Series Wireless In-Ear...
I have the GC-1020 Element mp3 player..i have had it for 3 months.All of a sudden i can only hear the music out of one ear of my ear buds,i have tried my earbuds on something else and they work fine..why...
I have the GC-1020 Element mp3 player..i have had it for 2 months.All of a sudden i can only hear the music out of one ear of my ear buds,i have tried my earbuds on something else and they work fine..why won't sound come through both ears anymore?
Aug 22, 2010 | Sears GC-1020 MP3 Player
My ipod video 30 GB is only playing sound out one ear.
one of the connections in your ipod is broken/bent. there is no good way to fix this youself. contact apple or go to your nearest apple store to have them fix it
Aug 06, 2009 | Apple iPod MA446LL/A MP3 Player
Sound very muffled in right ear bud
Yes, more than likely it is the wax build-up inside the screen of the earbuds. Take a tack and lightly pry the screen out. You will definitely see a noticeable amound of "gunk on the inside. Clean and you will hear a clearer and crisper sound. If you put the screens on flush and press them in they will stay.
Sep 24, 2007 | V-Moda Headset VIBE in Gumetal Black...
JVC Gumy Ear Bud Headphone - Peppermint Blue Logo
545 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
