Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
The picture I receive on my TV enlarges the faces and heads of the people on the TV. Their heads are actually cut off. I can not seem to diminish the size. How can I reduce the size of the people on my TV?
  • 31 Answers
It sounds like you have the Zoom feature in the wrong mode. There should be several levels of zoom that you can cycle through with your remote. These were designed so that you can fill a 16:9 aspect screen with a 4:3 picture if you want to. You also may have the Auto Format feature turned on. Go into settings and check that first. It sounds like you should be set on 16:9. Sometimes the right and left arrow keys on the remote will cycle through the various formats.
Posted on Mar 24, 2011
I lost my remote, and the picture is smaller than the actual screen by about 2-3- inches on all sides. how do i enlarge the picture to fit the screen?
This function u can't do it without the tv original remote.Try website like Remotes.com to buy the tv original remote.Than used one of those buttons on the tv remote like View Modes,Picture Sizes,Aspect Ratio,Zooming to do the adjustment for tv screen pictures sizes.
Jun 23, 2011 | Philips 32PFL5403D/27 32 in. LCD TV
My Vizio LCD HDTV 32in. doesn't seem to "center" the picture on sports programs so when they have a score box in the upper left corner most of it is cut off and can't be seen. Doesn't matter how I adjust...
This is a common complaint. To be frank I don't have the exact term for your Vizio, but most recent LCD and plasma TVs have the ability to "zoom" or adjust "picture format" (those are two commonly used terms) depending on the signal source and format.
it has to do with the fact that currently there are both classic style format 4:3 signal sources as well as new HD 16:9 signal sources and on top of that it may happen that a 4:3 signal source is distributing adjusted image from a 16:9 or other signal source. Think cinema adjusted to run on classic TV - remember the vertical strip of image with two huge black areas below and above it?
Well the ZOOM or PICTURE FORMAT allows to adjust such an image so that you cut the "void" are by scalling (enlarging) the visible area to fit the whole screen.
A problem then appears when the signal source is normal and showing full screen. Then, because of the enlargement, you start missing some of the picture. Before there was nothing there because it was showing adjusted wide (cinema) format to the TV box format, but when the new TV box format gets enlarged it sure starts missing around the edges.
That's what you're seeing.
More and more TVs do not have the ability to adjust that through the TV itself. Don't ask me why, but they can only do it through the remote.
So if you have an original remote there MUST be a button there that's called ZOOM or FORMAT.
It does the trick.
Hope this helps. If it does do not forget to rate it.
Cheers,
www.coppelltvrepair.com
Oct 18, 2010 | Vizio L32 32 in. LCD HDTV
Cannot zoom in a picture. When I enlarge it it is
Are you using the optical zoom or the digital zoom? digital zoom only enlarges the pixels and eventually distorts the picture. Optical zoom actually brings the subject closer.
Apr 27, 2010 | Cameras
My kids were playing with the buttons on the tv, and itseems like the picture is now "stretched" vertically - the tops of heads are cut off, and it seems like some of the picture is missing from the sides....
there should be a zoom, or strech, or even the letterbox option somewhere. What your describing is a enlarged picture that doesn't fir the screen, like if I select zoom on my remote.
Dec 10, 2009 | JVC AV-36D302 36" TV
My tv enlarges the picture cutting off peoples heads on the screen
First go to your source such as your Cable Box or Sat Box. The problem is that the Aspect ratio is set incorrectly on the source or the tv.
Jul 01, 2009 | Samsung PN42A400 42 in. Plasma TV
Picture in wrong position, too big for screen
Hi
maybe the system settings is not set in default mode
Thanks!
Mar 05, 2009 | JVC AV27F476 27" TV
I have a Toshiba 27WLT56B. A year ago it developed a problem: (1) I have to switch it on from the buttons on top of the TV. (2) Only after 10 minutes does it respond to the remote control (RC). (3)...
there it is a complicated problem your tv seem to have one big problem with the supply module inside him the power current was accidentaly increased and now your tv dont respond better and your picture is enlarged because had a big alimentation current and now you must to go in authorized service to fix that problem
Dec 11, 2008 | Televison & Video
52" RCA TV Plus color TV (12 years old)-picture is diminishing
Go into the menu and set contrast to full, bring brightness up to an appropriate level after.
Aug 31, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Enlarged Picture
yes it is fixable. this problem is due to more supply is going to h/output stage. please check 1 power supply for more voltage then normal. 2 component failure or settind in horz. stage to be checked. 3 print crack in h/output stage you can not control from remote control.
Sep 27, 2007 | Sony FD Trinitron WEGA KV-32FS16 32" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
109 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
