Question about GE GSHF3KGZ Side by Side Refrigerator
Water wont come out of door dispenser - GE GSHF3KGZ Side by Side Refrigerator
  • 29 Answers
There are 3 common issues that can cause this. 1. Bad water valve in back of unit that supply line connects to. 2. bad control board, also in back 3. ice in water line in freezer door or in reservoir in refrigerator side behind crisper draws.
Posted on Mar 24, 2011
Water on door wont dispense
Your water line could be frozen inside the freezer door. Open your freezer door and remove the kick plate on the bottom of the unit. Follow the water line from the door under the unit and it will be clipped under the unit. Pull out the water line and disconnect either line from the coupler (push the water line in and hold the ring then pull out the line). After you do that close the door and try the water again, if you get water then you will need a low wattage heater for the door.
Mar 14, 2013 | GE PSS25MGN Side by Side Refrigerator
No water and ice dispensing
most dispensers have a hidden lock button that may be set the lock button is a child safety feature,despite that could be the door switch since they wont dispense with the door open or perhaps could be the switch on the dispenser cradle
Jul 18, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
The water dispenser wont dispense water. Line is open and on. I
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Dec 23, 2010 | Whirlpool ET1FTTXK Top Freezer...
Water dispenser stopped working. Ice maker works.
Some of these ge frig have a problem with water freezing inside the door and so the water dispenser wont work. only way to be sure it to turn off your frig for about a week and leave the doors open. plug in then try the water dispenser. if this is the problem call g.e. you will need a special kit to solve this problem. it dispenser still doesn't work replace water valve!!!
Mar 22, 2010 | GE Refrigerators
My GE ice maker is working, but the water dispenser will not dispense water. I replaced the filter and the water dispenser did work for a few days and than quit. When I take the bottom grill off and take...
The line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . WR49X10173 , is the part number for the heater for the water dispensor , to keep this from happening again . Instructions come with the part .
Mar 04, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
Water dispenser won't work
check the freezer door switch; this is a safety so the ice maker wont come on while the door is open
Oct 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water or ice
sounds like your door swith is not working. it wont let water or ice flow when door is open (even when door is closed it is not making contact)
Jan 12, 2009 | Refrigerators
No water or ice through door
sounds like the dispenser assembly is not sensing that the trap door is opening fully, so it wont send power to the auger motor or fill valve. If you are pretty handy, you can disassemble the door and take out the dispenser assembly and try to take the assembly apart and correct the throw on the trap door. Otherwise, I'm afraid you need a new dispenser to the tune of about $250 parts and $225 trip and labor. Good luck!
Nov 07, 2006 | Sub-Zero 690 Side by Side Refrigerator
GE GSHF3KGZ Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
