Question about Garden
What is the fuel line routing for a poulan 14" woodshark chainsaw?
  • 2,239 Answers
Fuel hose from tank, with filter on the end goes to the fuel inlet on the carb, nearest to the pump cover held with a single screw, then a pipe from the other noozel on the carb goes to the shorter connection on the back of the primer, the pipe from the longer connection on the primer goes back to the tank, just remember the primer pulls fuel from the carb, into the bulb, and back to the tank
Posted on Mar 26, 2011
5 Suggested Answers
  • 4088 Answers
SOURCE: Routings of fuel line to Poulan 14 inch chainsaw Model 2025
No drawings or pix, but will try for description--the line from the tank that has the fuel filter is the main fuel source which goes to the upper connection on the carburetor. The lower carburetor connection goes to the intake side of the primer bulb, and the outlet side of the primer goes back into the tank, which has no filter inside the tank. The main problem is determining the correct primer port to connect back to the carburetor. When everything is connected, try priming the carburetor. If fuel fills the bulb, you have everything connected correctly. If nothing happens, try switching the two primer port connections and try to pump fuel again. If still nothing, hook the main supply line from the carburetor over to one of the primer ports and try for fuel again--if still nothing, switch the main supply line to the other primer port and pump again. If still nothing, check for a plugged fuel filter in the tank. If the filter was plugged, then go through the previous procedure again. Make sure to replace the fuel lines with original rubber lines, not plastic. Hope this helps!
Posted on Jul 16, 2010
B-Roosky
  • 59 Answers
SOURCE: Woodshark poulan 14" slack chain
make sure the little tooth on the end of the adjuster for the chain is locked into the groove its supposed to go into and tighten it down.
Note: the chain is supposed to get loose on you but not as quickly as it is. maybe after an hour or so of cutting.
and as for it not cutting well, the chain may need sharpened.
if it has been sharpened once by someone than take it to someone esle if it is not satisfactory.
Posted on Jan 11, 2010
  • 4 Answers
SOURCE: I have a 14" Woodshark Poulan chainsaw. I put in
Poulan Chainsaws are pretty well all powered by two stroke engines. My best guess is that you have the fuel mixture incorrect (it should be a 1:40 ratio of oil to gas). if the fuel mixture is not the problem then your choke is messed up. If you haven't tried already try and find the sweet spot in the choke where it will run.
Posted on Mar 04, 2011
  • 2239 Answers
SOURCE: Poulan Woodshark 1950 14" Chainsaw Family: WPWES
Checked all the parts lists, they seem to use the same primer through all types no.s part no. 530047213.
Posted on Jun 24, 2011
How to rout fuel lines to primer bulb on poulan 14" chainsaw
Short line on primer bulb goes to the left side of the carb. The long side on the primer bulb goes to in the fuel tank as the return line.
Jul 23, 2014 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Where do gas lines go
Depending on the carb you have, the short side of the primer bulb goes to the carb and the long side of the primer goes to the fuel tank as the return line. The fuel line on the right side of the carb goes to the fuel tank and is the one with the fuel filter.
May 04, 2014 | Poulan 14 Woodshark Chainsaw
Replace fuel line on poulan 1975
Hi Will...
I think this is what you need
Please take time to rate me
Bud
Mar 17, 2013 | Poulan 14" Chainsaw
Replace fuil filter, location
inside fuel tank, take a piece of wire with a hook on end and fish it out of tank and change it, may also want to change fuel line too
May 17, 2012 | Poulan 14 Woodshark Chainsaw
Jun 24, 2011 | Poulan Garden
Mar 04, 2011 | Poulan 14" Chainsaw
How to connect the fuel lines for Poulan Model # 1950 Chain Saw
The following link should be very helpful:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
A link to a Poulan model 1950 Type 7 follows (may not be your saw, there are 7 different Types and 2 Woodsharks (LE))
http://www.ordertree.com/modelinfo/PWE/1950-Gas-Saw-Type-7/75.1950-Gas-Saw-Type-7.1.59.1.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 22, 2010 | Poulan 14" Chainsaw
Need to know how to connect the gas lines from the primer bulb to the carburetor on a poulan woodshark model 1950 chainsaw
The lines should be connected to push fuel into the carburetor. The output (overflow) of the carb is routed back into the tank. So, two lines in the tank, one is an overflow (return) and the other is the suction. On the primer one line from the tank and the other to the carb. Connect so as to "push" fuel into the carb when the primer bulb is pushed.
Jun 16, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Disassembly of poulan woodshark model p3314wsa to
This is an IPL for a Poulan P3314 (may not be your saw), It seems there are 2 different size hoses, I suggest you disturb only what is necessary, take a digital photo, then a small sample of both sizes to a local saw outlet. 12" of both sizes should be ample, ask for his guidance before you order.
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2008/NIUS2008-P3314-530165402-952802026.pdf
Many also find this helpful:
If not your saw try here (there are 3 "P3314WSA"s available):
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
The IPL can be used as a disassembly guide too, although you should not need disassembly beyond removing a cover or 2. Good luck with your project If I can be of more help you can reply below. HTH
Lou
Jan 28, 2010 | Poulan Garden
Garden Logo
639 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
