Question about GE Profile JGP636 Gas Cooktop
After cleaning the cooktop surface the "clicking"
I just solved the continuous sparking in my gas burner. I removed the control knobs and the rubber below those knobs. Gave the rubber and the area below it a good clean using kitchen and bath cleaning wipes that I bought from Coles. The key is to remove the water and grease from the rubber and the area below it. Good luck!
Posted on Mar 28, 2011
How do i clean my cooktop on a whirlpool 465
Light Cleaning
  • Clean your CERAN cooktop after every use. To remove simple spills, wait for the surface to cool before beginning the cleaning process. Pour a small amount of cleaning cream on a damp paper towel and wipe the cooktop surface until the soil and cream are no longer visible. The cleaning cream will leave a protective finish, which will preclude scratches and other types of damage.
  • Heavy Cleaning
  • Wear a heavy oven mitt to remove burnt foods or liquids while the cooktop is still warm. Use the metal razor scraper to remove the substances that are stuck to the cooktop surface. Once the cooktop has cooled, use a damp paper towel to spread a small amount of cleaning cream over the entire cooktop surface and wipe it thoroughly until the cream is no longer visible. Rinse the cooktop with water and dry with a clean paper towel.
  • Cleaning Melted Substances
  • Remove melted plastic, foil or other kitchen products immediately using the metal razor scraper. Spills containing sugar, such as ketchup, tomato sauce, syrup or pudding, must also be removed with the metal scraper at once. It is best to remove these substances while the burner is still hot. Once the melted substance has been removed and the cooktop has cooled, use a damp paper towel and cleaning cream to complete the cleaning process. To protect your hands, remember to wear a thick oven mitt when cleaning the hot cooktop.
  • Tips
  • Scratch marks resulting from daily use will not interfere with the performance of your cooktop. Pots and pans with flat bottoms and those that cover the entire burner surface are recommended for use on your CERAN cooktop.
  • Warnings
  • Spills containing sugar may permanently damage your cooktop unless the substance is removed immediately. Use only the recommended cleaning products on your CERAN cooktop to protect it from damage. Do not use scouring pads, plastic coated sponges or abrasive products of any type. Do not use oven spray or any other type of cleaner containing ammonia or chlorine. Clean all spills thoroughly before using your cooktop again.
  • Nov 07, 2010 | Whirlpool Cooktops
    The starter does not work anymore
    Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
    Cooktop Range Stove spark ignition does not work
    http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
    heatman101
    Jul 10, 2010 | GE Profile JGP636 Gas Cooktop
    My jenn air espressions gas cooktop has four burners. When
    Remove the round burner plates and clean thoroughly in soap and water. Clean the burner ring where the burner plates rest with soap and water.
    Let me know what you find.
    Dec 13, 2009 | Cooktops
    My ignition will not stop clicking
    hi friend,
    There are a few things to check for. Make sure the electrode ( the small metal piece that the spark comes off from ) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and NOT a tooth pick as these can break off and make things worse. Example of a burner. The next thing to check for are the ignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it. Sometimes cleaning can get moisture into the surface switches, try drying them with an hair dryer to see of this will help.
    it sounds like it is the spark module that's making the clicking noise. normally there are 4-6 wires that connect to it , and if you are not comfortable making the repair yourself then I would call an appliance repair company.The part should cost 30-50 $ Good luck
    hope this helps u
    please rate me.......................
    thank u for using fixya
    regards
    sivaranjini
    Nov 25, 2009 | Wolf Range 18 in. SPR-100 Gas Cooktop
    Electric starters keep firing after I sprayed cleaner
    your spark modual got shorted with the liquid you sprayed in there or spilled you can try unplugging it overnight to let it dry. at least 24 hours or you can take the cooktop of and get a hairdryer and dry out the spark modual.or if you wait 24 hours - 3 days and still not dried out you need to replace your spark modual but more than likley give it time it will fix itself.
    Apr 23, 2009 | Amana AKS3040 Gas Cooktop
    GE gas stove top igniters won't stop clicking
    My wife just called me with the same problem - all 4 starters are clicking repeatedly - which started while the range was being cleaned.
    From a Google search, this is what I found. Don't know if it will solve our issues, though wanted to share as it sounds like we may all be suffering from dirty starters (electrodes).
    My surface burners keep "clicking" even after the burner is lit. There are a few things to check for.
    And, to check the model number, look at the various places pointed to in the upper left of this diagram. http://www.applianceaid.com/newpics/range-model2.JPG
    Oct 18, 2008 | GE Profile JGP636 Gas Cooktop
    Trouble with Kenmore Gas Cooktop
    hi there,
    the clicking noise is the spark module trying to ignite. i would get a technician to come and check it.
    Sep 28, 2008 | Cooktops
    Cleaning glass cooktop surface
    I used Mr. Clean multi-surface and the green, back side of the sponge. Turned on a light to show visible stains better, and scrubbed away. It didn't scratch the glass and got it out quick. Hope this helps.
    Jul 20, 2008 | Jenn-Air JED8430 Electric Cooktop
    GE Profile JGP636 Gas Cooktop Logo
    198 people viewed this question
    Top GE Cooktops Experts
    Dan Webster
    Dan Webster
    Dave Harrison
    Are you a GE Cooktop Expert? Answer questions, earn points and help others
