Question about Whirlpool Ovens
Light works neither oven will turn on and clock display is out. Think it may be the control board? not sure if they still make replacement boards for my model RBD275PDT11
  • 1 more comment
  • totoconsulti Mar 24, 2011
    looking for probable cause for current problem - can you confirm if it sounds like a bad control board or if it might be something different. Do I need to give more info to narrow down the cause of the problem?
    Thank you for your help. I will order a replacement board.
    Cheers.
    The very answer I needed and the information on where to order it. Thanks.
  • 2,382 Answers
Hi, the parts for your whirlpool oven model RBD275PDT11 is readily available if you want to purchase any part including the control board you are requesting for..
You can get the control board on this LINK and this LINK.....
Posted on Mar 24, 2011
  • Tunde Autos
    Tunde Autos Mar 24, 2011
    I understand the question quite alright..
    This is a frequently occurring problem due to a failure in the control board. The board can be repaired or replaced to solve this...
  • Tunde Autos
    Thanks for using FixYa.....
    You can now accept and rate the solution....
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Probe light on convection oven stays on. Clock won't display. Oven still works though.
Sounds like the control board is not communicating correctly with the rest of the unit, consult a professional.
Aug 10, 2012 | Frigidaire 30" Built-In Single Electric...
The clock on my Cambridge oven wont work, I cannot set. Therefore the oven wont light unless the clock is set. How do I fix this problem? All the buttons have stopped working so therefore unable to set the...
bad digital control board if tis just a clock and all the settings can be done with a knob and not the board then the replacement wont be too expensive but if that board controls eveything which i suspect it does then its going to be at least 150 more to repair than if it was just a clock display
Mar 30, 2010 | Ovens
Hi I have a Tappan oven model TGF357CCSF. The clock display andtemperature display is working but it is very dim. I have been told the I need a control panel 316028350 which is no longer available is this...
Hey - That part is available thru AppliancePartsPros online listing is clock/timer.  Part # AP2125110     $203.75   These timers are old-timers anymore. Can be hard to find, and at 200 bucks, make ya think twice. Gas model is probably worth it though.  Either way- it's an electronic clock that has had 120v running through it for 20 yrs or so. Time to replace for sure. Let me know if this info helps-  have more if needed-  Thanks--Ed
Mar 16, 2010 | Ovens
Display Panel Not Working
Only thing is check to make sure clock control is getting 120 volts into the l1 connector on the board. If it is make sure the ribbon cable is plugged into the board properly. If it is replace board.
Mar 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Dislpay is blank but oven works
HI, you will need to replace this faulty ECC. the chip set that is soldered on this board is damaged as well as the led display. replacing the Electronic Clock Control will fix this issue.
the control board is fine and this explains why the oven is still functional. its the ECC that is faulty.
Click here to purchase your new ECC online.
May 25, 2009 | Whirlpool RBD305PD Electric Double Oven
Jenn air oven
More then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
Mar 23, 2009 | Jenn-Air JJW8230D Electric Double Oven
Display light faded and now gone
Supposedly the electrolytic capacitors on the display board need to be replaced. See: http://applianceguru.com/forum1/18842.html
Jan 15, 2009 | Thermador SC302T Electric Double Oven
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Aug 25, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Display doesn't work, but oven works
First turn the electricity off by locating the breaker to the oven and turn it off. Now wait for an hour or so and turn the breaker back on, if the display turned back on, you need a control board (other manufatures call it a clock, PCB or ECC but it's the main elctronic board with the diaplay built in). If it didn't come back on, turn the power off again and make sure all the wire harness's going to the board are connected good. Turn the power back on and it the display still doesn;t come back on you need to replace the main electronic control board. By the way double check the model number and brand because it might be wrong. Please post back.
Oct 04, 2006 | Whirlpool RBD275PD Electric Double Oven
Ovens Logo
144 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
