Question about Boating
120-105452-6 coil white rogers where can i find?
  • yadayada
    yadayada Mar 24, 2011
    We have no way to reference part numbers. I suggest you contact Sears Direct.
Gas boiler white rogers need a relay white rogers 8a03a2
contact the manufacture or manufacturers distributors or authorized service agents to get the part
if they are not handy then take the part into an electrical wholesale shed and they may have a replacement part for you
after all white rogers will not make relays but will use brands off the shelf on their assembly line
Oct 19, 2015 | Heating & Cooling
Connecting 2 wire thermostats to white-rogers type 1311 3 wire zone valves
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. Make sure to connect a thermostat that will power open and powered closed the zone valve. I pretty sure that the two wire thermostat that your going to connect will not be compatible. To better assist you with this further contact us directly at 18002842925.
Oct 15, 2012 | Heating & Cooling
White Rogers digital thermostat displayed "lo".
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. After replacing the battery you need to do the reset operation. If you need further assistance please contact us at 1800-284-2925.
Sep 24, 2012 | Heating & Cooling
My white rogers 1f78-151 programmable thermostat is set at 76deg. but will only cool to 79deg.
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. Reset the unit by pressing UP, DOWN and TIME buttons all at the same time. The unit will go blank for a couple of second then operate the unit. If this did not resolved the problem contact us directly at 18002842925.
Sep 11, 2012 | Heating & Cooling
Hi I would likt to replace Honeywell LR95329 with White-Rodgers 1F85. Would you please work me through on how to remove LR95329 and then how to wire 1F85? Thank.
http://www.emersonclimate.com/Documents/White-Rodgers/0037-6488.pdf
Here is a site you can visit with the installation manual for the W/R 1F85.
What type of system are you operating? Is it a Heat Pump? Do you have a heat strip or heating coil for emergency heat? How many stages of heat and cooling? I am sorry for all these questions but they really are necessary. Roger
Apr 02, 2011 | Heating & Cooling
White rogers manual
Hello my name is Heath it will be my pleasure to assist you. There are many models of white rogers thermostats I would need t know the model to get the correct manual.
Oct 08, 2010 | Heating & Cooling
Changing a Cingular Razr to a Rogers phone
You need to flash the phone with a Rogers Monstor File to load all the settings for Rogers.
Jul 29, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Boating Logo
169 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
