Question about LG WM2455 Front Load Washer
My water hose is leaking on the inside of my washing machine and I need to get the top of the machine off. How do I do this. Please help
  • 29 Answers
The panel should have 2 or 3 screws on the backside of top panel.
Posted on Mar 24, 2011
I have a Kenmore top load washing machine and it is dripping water inside. Do i need to replace a valve or a gasket?
Until you find out why it is dripping turn off the water behind the washer. Then I would go and search online typing in the browser search "Kenmore top load washing machine model no _____ leaking - what is causing this?" and hit enter. You will get lots of leads. I did a quick search just on Kenmore top load washer leaking and found this video.
Hope it helps.
Tami
I’m happy to help further over the phone at https://www.6ya.com/expert/tami_f8d2d553d5094045
Mar 03, 2015 | Kenmore Washing Machines
Washing Machine will not drain
the signs all point to the pump. thanks for the model number... i looked up this machine and the pump it electric 120v retails for $100. before you buy anything you need to get to the pump and take the hose off... i bet there is something inside causing your problem if not let me not then plan B
hope this was helpful
Apr 07, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
MACHINE MAKES DOES NOT WASH,WATER OUT FROM DRAINAGE PIPE
is it a top or front loader?is your drain hose same level as top of machine?if not ,raise hose to level and start cycle.machine will not wash if it does not fill.please reply if u need more help
Apr 05, 2010 | LG Washing Machines
Problem : Water leaking out from under washing machine
NOTE. PLEASE UN-PLUG THE UNIT FROM THE ELECTRICITY SUPPLY BEFORE ATTEMPTING THE FOLLOWING JUST TO BE SAFE:-
Problem may be due to a blocked dispenser hole. Completely remove the dispenser unit and check for blockages in the hole where the water goes in. If you cant see anything immediate, take the top off. (Remove the 2 self tapping screws on the back holding the top on). Looking at the unit from the front. look inside where you took the top off and locate the rubber hose that connects the dispenser unit to the drum (it's a tight space, but if you look inside , front left you will see where the hose connects to the drum). Remove the hose and check for blockages. (The hose just pushes into the drum). Let me know. I had a similar problem and found that somebody had shoved a sock and pair of knickers down the water dispenser hole. This was also causing the machine to make a loud noise when spinning. Have you also checked the filter in the bottom right hand corner of the unit ? You have to remove the kick panel to get access to it.
Jan 20, 2010 | Ariston Technologies Washing Machines
Westinghouse LT955s Washing Machine
Its the water solenoid. Is it where the hot and cold water connect? Check that the connection is tight and there is a rubber washer inside the hose fitting.
If this is inside the washing machine and not where the water connects to the machine as above, it sounds more like the water pump.
A photo would really help.
Aug 22, 2009 | Washing Machines
Cold water hose or seal leak inside machine leaks into basin
Replace the water inlet valve. That is where the hoses connect.
Here is a link to show you how to access the inside of the washer..
Mar 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
GE Top load washer.
Hello rschneeweis
Welcome,
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Huuum
Please remember to leave a rating
Oct 04, 2008 | GE WBSR3140D Top Load Washer
Front loading washing machine is having leakage problem
You need to work out where the water is coming from, either the front, back left or right hand side to give you an idea what/where to look.
Front - Open the door and check the door seal (usually grey rubber round the door) look for splits, chaffing, damage.
Rear - check the connection to the pump, there will be a (Black) rubber hose from the drum housing about 12-18"long, check for splits, connection etc.
Check and remove the pump itself, Isolate the electricity, to remove - disconnect the outlet hose from below the sink or upstand, lower the outlet hose to the floor and syphon off the water into a bowl from the machine, there will be some even if the machine appears empty. disconnect the plug on the pump (2 wires), disconnect the hoses from the pump (2 off) and check inside the hoses, bra wires, socks etc. look inside the pump for foreign objects, the pump can be wasily split open via 3 screws normally, refit in reverse order.
Top - remove the top cover usually 2 screws at back or side and will slide slightly to remove, check hoses to drawer and the hose below drawer to top of the drum housing, check the inlet solenoids at the back (where the water hoses connect).
hope this helps
Apr 08, 2008 | Washing Machines
LG WM2455 Front Load Washer Logo
44 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
