Question about Samsung Televison & Video
My samsung le37r88bd suddenly went dark and now needs the brightness turned up full also any text stays superimposed in the background for a while
    Scholar:
  • 146 Answers
Sounds like text is staying on screen because you have brightness turned up too much
the reason it is dark is probably because backlight is bad - backlight is flourescent bulb and if you have ever seen a flourescent bulb you know how it gets dark from edges almost as soon as you start using it
you might be able to replace bulb yourself if you are handy or bring in for service
there is a chance (possibly a good chance) that the power supply for the backlight is bad also - you might want to consider if a repair is worth it considering how cheap they sell these things now
let me know if i could be of more help
good luck!
Posted on Mar 24, 2011
Testimonial: "sounds very feasable i will try your suggestions and let you know the result. cheers"
  • ken jones Jun 12, 2011
    I was advised that the tcon board could be the problem, so i sourced one off the web for £40.
    It took me about 10 mins to change it and now the tv is like new.
    hope this is of help to someone else instead of having to pay extortionate repair prices.
Their is a very good chance its the tcon board had this in this model many times
lucky you didn,t go with the first fault as they dont,t know what their talking about
has nothing to do with backlight
Posted on Nov 22, 2011
Read books through google play store
In settings, check display setting for brightness. See if the auto brightness is selected. If so de-select and try. Another thing to check is the battery saving mode !
Feb 04, 2015 | Samsung Galaxy Centura SCH-S738C...
Mottled background
Sounds like you may need a new lamp according to my Samsung DLP manual for a HLR4667W.
"Why do I need to replace the lamp?
The lamp used in a DLP TV has a limited lifespan. For the best screen quality it needs to be
replaced periodically. After replacing the lamp, the screen quality will be bright and clear as new."
Nov 12, 2013 | Samsung HLP4663W 46" Rear Projection HDTV
Screen went black but sound stayed
Your Xbox Rims In Xbox ARE NOT WORKING.
May 16, 2013 | Microsoft Xbox 360 Console
Samsung dlp 1080p picture is dark and brightness control is at max
I am hoping somebody will answer this because my TV is dark and I played with the controls and it is still dark!
Sep 24, 2012 | Samsung HL-S6187W - Rear projection TV -...
Vizio lcd flatpanel tv with dark background
If half screen is affected it will be either a board (LCD and Plasma have different names) but in those one board drives each side of the screen unit--worst case is the display panel itself which is fatal from a cost point of view.
May 25, 2012 | Vizio VT Televison & Video
I have a 19 inch samsung monitor. suddenly it went dark. Can it be repaired?
Please be more specific about your problem:
1. Is it black or just darker by lower brightness? 2. Is the power led turned on and what color is it showing?
Sep 14, 2011 | Samsung 19" TFT LCD Monitor...
Dark, horizontal lines after text and dark images.
This implies that your monitor had gone bad. you need to take it to a computer repair shop.
Apr 10, 2010 | HP w1907 LCD Monitor
Front Display screen
It is not a leaf. The inside glass in the front of the LCD screen is cracked.
It will need to be replaced.
Best of Luck.
Nov 06, 2007 | Samsung C417 Cellular Phone
Closed caption text is pale white now instead of bright green
Theres no color option on this set as far as the manual says. It sounds like the Video driver comming out of the microprocessor is bad, so the micro will need to be replace. This is not a user replaceable part so please seek a pro to repair this for you. Sorry i couldnt assist you more with this. Good Luck
Jul 01, 2006 | Quasar VV-1319W 13 in. Combo
Strange silhouetting and a vertical strip
If A vertical strip appears on the screen when recording a dark background or the subject is blooming or silhouetting, you need to adjust the BLC. * The contrast between the subject and the background is too great for the camcorder to operate normally. * Make the background brighter to reduce the contrast or use the BLC function while you are recording in a brighter environment. BLC (Back light Compensation) * BLC works in CAMERA/M.REC mode.B * Back lighting exists when the subject is darker than the background: 1. The subject is in front of a window. 2. The person to be recorded is wearing white or shiny clothes and is placed against a bright background; the person?s face is too dark to distinguish his/her features. 3. The subject is outdoors and the background is overcast. 4. The light sources are too bright. 5. The subject is against a snowy background. 1. Set the power switch to CAMERA mode. 2. Press the BLC button. Normal - BLC - Normal BLC enhances the subject. Notes: * When NITE PIX to set to ON, the BLC function does not work. * The BLC function will not operate in EASY mode.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Televison & Video Logo
611 people viewed this question
Jerry Greenberg
Jerry Greenberg
