Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Water still in the drum, and have cleaned out the filter
  • 29 Answers
Put the washer in drain/spin cycle and check to see if pump tries to come on. put hand on top of pump to feel for vibrations. If pump comes on but doesn't pump out you either have a bad pump or a blockage some where.
Posted on Mar 24, 2011
How do i clean out a blocked filter
The F&P is easy to work on, the rubber tabs on the left and right front top. remove screws top will lift up. support it . Then reach into agitator and loosen spin nut . remove agitator. then remove inner drum. Outer drum will be exposed. Filter should be visible. Clean out and service any residue from water and soap. Check water inlet for proper inflow and leakage.
Oct 10, 2014 | Fisher and Paykel GWL11 Top Load Washer
Tip
INTEX POOL CLEANING
YOU CAN USE A 30 GALLON CLEAN PLASTIC DRUM TO VACUUM OUT YOUR POOL BY GOING IN ONE SIDE WITH YOUR OUTLET HOSE CONNECTION WITH A 6 ' PIPE INSIDE THE DRUM, AND BY USING A PIPE 4 INCHES OFF THE BOTTOM ON THE DISCHARGE SIDE GOING INTO THE PUMP. COVER THE BOTTOM OF THE DISCHARGE (THE LONG PIPE) WITH A PIECE OF PANTYHHOSE CLAMPED ON THE END AND THE TRASH FROM THE POOL WILL STAY IN THE DRUM INSTEAD OF GOING INTO THE FILTER. AFTER VACCUMING OUT DISCONNECT THE DRUM, AND REHOOK YOUR HOSES AS NORMAL TO THE PUMP. CLEAN THE DEBRIS FROM THE DRUM AND YOU'LL BE READY FOR THE NEXT TIME. JUST FILL THE DRUM BEFORE YOU START WITH POOL WATER,IF YOU DO THIS YOU WON'T LOSE ANY WATER. OF COURSE YOU HAVE TO PURCHASE THE CONNECTIONS TO ADAPT TO YOUR HOSES. BLEED THE AIR OT YOUR PUMP AND YOU'LL BE AMAZED AT HOW MANY FILTERS YOU SAVE FROM THE TRASH FROM VACUUMING STRAIGHT INTO THE FILTER.
on Jul 29, 2010 | Pool & Spa
Clean awm5104 washer filter
There can be many issues but you need to remove and clean all the filters and the drum, the drain.
check this link for tips: Smelly drum
Nov 20, 2013 | Whirlpool AWM5104/1 Front Load Washer
Washer not entering rinse cycle tube in front near filter won't drain water no kinks in hose
You may have to remove and clean out your drain filter located inside the cabinet between the bottome of the drum and the pump motor. Make sure you hand bail the water out of your drum prior to removing the drain filter. Your model may have a shut-off valve between the drain filter and the tub, if so turn it to the OFF position to stop the water flow. If you do have this shut-off valve you will not have to hand bail the water out of your tub. After you remove, clean and reinstall the drain filter, be sure to turn the valve back to the ON position.
Nov 26, 2010 | LG WM2277H Front Load Washer
I have a front loader that smells like something died in it. I have tried affresh bleach Tide washer cleaner Basic G leaving the door open cleaning the gasket washing the drum cleaning the filter and hoses...
you can open the filter drainage under near the drain hose. there may be something that comes into the washer drum and died leaving a smell. how to open the filter is rotated and pulled out only. then you try to drain the washing machine how to turn it. will allow water or sewage, which is in the drum filter out of the hole. and do not forget to clean the exhaust filter the water, there will be a lot of dirt.
Jul 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water not draining from the drum and no filter in evidence
Remove rear panel of washer, locate, and remove large black hose fastened to bottom of drum, remove and clean plastic filter inside hose.
Please rate my solution.
Thanks.
Aug 15, 2009 | Creda W100FW Front Load Washer
Drier Filter
There is one filter below the drum, but this for the water drain and there should be another filter another filter for the dryer there should be a filter between the drum and the exhaust hose for the hot air is. You should be able to pull this filter out for cleaning
Jan 29, 2009 | Hotpoint Aquarius WD63 Front Load...
Need to find the filter as drum not spinning and water leaking
The filter on this model is in the main hose leading from drum to pump. It can be accessed by removing the panel at back of machine.
Dec 13, 2008 | Hotpoint Ultima WD72 Front Load...
Water Remaining in Drum "OE" info in the screen comes on
its a filter in the sump...under the tub theres a rubber sump with a plastic filter inside..its a tight squeeze but it comes out...remove and clean..
Oct 16, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
55 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
