Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washer shakes th whole house during spin cyle
  • 29 Answers
Most likely the washer is not level. The rear legs are self adjusting. Pull washer toward you so rear legs are off ground. This will allow them to reset. The front can manually be adjusted with a wrench or pliers.
Posted on Mar 24, 2011
Whirlpool duet mod#ghw9160pwo washer shakes the whole house during spin cycle. shocks look good, springs look good and adjustable feet are tight and on floor. the washer is level and i get no alarm...
Unit probably has bad main shaft and bearings. Worn bearings will cause excessive shaking on spin cycle. The shaft, bearings and seal will have to be replaced. Also if you grab the tub by the top and shake it up and down, it will have a little play in it. That will confirm bad tub shaft bearings. It's a pretty big job for a DIY.
Dec 10, 2017 | Whirlpool Washing Machines
Our Maytag washer rocks violently during the spin cycle.It shakes the whole house and seems to be getting worse. We put shock absorber rubber mats under it but it just rocks off them.
Sorry to read about your problem, I hope this helps you out.
you must have a broken balance spring/shock on your machine...
I suggest you contact a service company
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Maytag Neptune MAH5500B Front Load Washer
Front loader washer shakes house
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 06, 2010 | Washing Machines
It shakes so violently, it knocked 2 holes in the wall. During the spin cycle, it also turned completely around backwards!! It's so loud it practically shakes the whole house.
take bottom panel off,check the shocks,if it is making loud noise it's probably spider gear,if you keep using it the boot could rip off and you'll have a flood,get rid of washer it will cost as much to fix washer that you could buy a new one but that's up to you to decide
Nov 06, 2009 | Frigidaire FTF2140F Front Load Washer
Spin cycle shakes the whole house everytime why
check first if any of the legs are not sitting flat on ground,check the roughness of bearings by placing your hand in the drum and rotate slowly back and forth,loose balance weight could also be a cause but id say it sounds like bearings
May 07, 2009 | Washing Machines
New front load washer shakes my whole house
remove the shipping material...read install instructions that came with owners maneul
Dec 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
108 people viewed this question
Dan Webster
Dan Webster
Sal De
