Question about HP OfficeJet Pro K8600 Printer
I put new ink cartridge in,and it still prints but vey lightly& not all of it.do Do I need to do somthing else....HELP HELP!!!!!
  • 51 Answers
Hi is the ink you fitted a hp or a refilled one?
you can go to properties on your pc and do a head clean.
if that dos not work but a small amount of worm water in a small plate take the ink tank out and with the print head down and just enough water to cover the head leave it to soak for 5 mins
dry all the water off and place back the ink in the machine. or Tate the ink back to the shop.
good luck yours ian
Posted on Mar 24, 2011
My printer states "paper jam" although I don't see any paper. I bought new ink cartridges & it doesn't print the multi-color, only the black.
Paper jam means just that. Look for paper or a piece of paper jammed into a gear or stuck between a roller or even in your ink cartridge . When you put in your new ink did you take off the protective seal and run the HP software to check if it is reading the Cartridge ,You might want to read the instruction on how to install an ink cartridge. It might also help you ?
Nov 03, 2014 | HP Deskjet 3052A
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
After printer said ink cartridge was empty I removed it & found it was not-I put it back in printer & now getting error message that the cartridge is used & needs to be replaced. How can I
your only option it to replace it with a new one . printer mfg's have chipped the cartridges and they can not be reused.unless the chip is recoded as new .
Aug 16, 2017 | Ricoh Aficio GX3050N Printer
After many cleanings, head refreshings, and "head allignments" the color printing is very light...especially the black. I've put in all new inks and the print is still very light. The new ink...
Try putting a bit of isopropyl alcohol in the bottom of the cartridge holder where the ink goes through and letting it sit for a couple hours then putting the cartridges back in and running the cleaning cycle a few times.
The alcohol should help dissolve the dried ink in the print head.
Jan 07, 2011 | Canon PIXMA MP780 All-In-One InkJet...
I have the PIXMA MP500 & 3 of m ink cartridges #8 blue, magenta & yellow ran out of ink but I have a brand new #8 black & #5 pgbk that I changed. Now I just want to print from the black ink...
Unfortunately, the printer is designed to need all of the ink cartridges in place and no empty ink cartridges. This is designed to protect the ink system from damage.
There is a way to print a color document in black and white but it won't help with your issue. (Enter the Printing Preferences by right clicking on the icon for the Canon MP500 in the Devices and Printers Panel (Win7). (It's Printers for the Vista Classic View and Printers and Faxes for XP) Then put a check mark in the box for Greyscale Printing in the main tab. Then click OK and close the window. There is a similar method for Mac OS versions.)
I wish that I had better news.
Jan 03, 2011 | Canon Pixma MP500 All-In-One InkJet...
Not printing in color and black/white copy not clear, light in some places
Dear sir
good day
to fix up such problem
Clean the printhead, then print and
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Printhead Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo + Copy simultaneously to print a demo sheet
and you have to Replace ink cartridges.
IMPORTANT: Make sure you are using KODAK Ink Cartridges. Your KODAK All-in-One Printer is designed to work with KODAK Ink Cartridges. Kodak is not responsible for the compatibility or performance of either non-Kodak brand ink cartridges or refilled ink cartridges. To purchase KODAK Ink Cartridges, go to KODAK Ink Cartridges & Photo Value Packs.
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Insert new KODAK ink cartridges into the printhead, then press down firmly until you hear the cartridges click into position.
  3. Close the printer access door, then make the same print.
and you can point to the website below for further information
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=5224/6198
thanks
Dec 18, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Hp psc 750 won't print with new color ink cartridge
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Aug 24, 2009 | HP PSC 750 All-In-One InkJet Printer
My canonmp830 printer is not printing in black ink
**Repeat from previous post. Would not print black. I went through all the troubleshooting of cleaning the printhead several times. The Nozzle check (found under Printing Preferences/Maintenance tab) kept coming out without the PGBK section (Black) printed on it. All the colors printed. If your see any of the colors missing, it is probably the same problem---it needs the Print Head replaced.
Part # QY6-0061-010. I was able to find it at Canyon Computer Supplies in Phoenix, but you can also order them via the internet from multiple outlets. Mine cost $59.57 with tax...much cheaper than a new printer. The replacement is very easy...Canon has info on how to do it at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804#SupportDetailAct ...if the link doesn't get you right there, search MP830, Support & Service, then search print head & you should find it. Once you remove all the print cartriges (printer ON), the gray lever on the left side lifts up and releases the print head...which is the unit that houses all the print cartridges. I just put the new print head in, replaced all the ink cartridges, did a nozzle check...and it worked!! I love fixing things myself.
Jun 02, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
HP OfficeJet Pro K8600 Printer Logo
79 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
