Question about Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer
My mhw2000aww is no longer locking during wash cycles or properly spinning the closes when wash cycle is complete clothes are coming out saturated still is there a control board that i could replace to solve this problem
  • 29 Answers
You most likely have a bad (lock wax motor) that can also cause the main control board to go bad. the lock motor sits above the washer door behind the panel. the control board sits inside the dryer above the drum to the right. go here to look up your parts
Posted on Mar 24, 2011
Ge toploadwasher that does not get water out of clothes after final spin
Could be that the spin cycle is not rotating at the required speed to wring out your clothes. Check that the cycle completes at a significant speed to generate centripetal acceleration forcing out the water. Perhaps the load is unbalanced which can trigger the spinning cycle to repeatedly stop during the spin cycle.
Jan 31, 2015 | GE Washing Machines
All cycles are working except the spin cycle. I have visually inspected the wiring connections and motor and dont see any obvious issues. There are no error codes and the LED lights seem to be functioning...
Because of the high spin speeds of front load washers, the doors are equipped with a latch and lock mechanism to prevent the door from being opened during the washers operation. These locks will often be actuated by a solenoid or wax motor to ensure they remain latched during the wash cycle. This model uses a two stage lock that latches the door when the load starts, and then when it is time to spin, the second lock engages to ensure the door is properly secured prior to beginning the spin. When this second lock engages, it also closes a set of switch contacts (the auxiliary door switch) telling the control board the door is closed and locked. If for some reason this switch is not closed, the washer will tumble during what would normally be the spin cycle until the entire cycle is complete.
Jul 02, 2011 | Frigidaire Affinity ATF7000E Front Load...
I have a Kenmore Elite HE3 Tearing holes in my clothes
Are you using HE ( high efficiency ) detergent?
If you are using regular detergent the machine may be sensing all those bubbles and may be working longer to get rid of them.
Try using a net/lingerie bag for delicate clothes.
This type of washing machine works by sensing when the clothes are saturated then it will start to tumble back and forth, and it will continually drain out the dirty soapy water and bring in clean soapy water, then spin out and go into the rinse cycle..
It's all done by the machine sensing when it's time to go to the next cycle.
I am wondering if you are maybe using too much detergent.. Only use the max of 3 tablespoons of HE detergent if you have hard water and 1 tablespoon if you have soft water.
Hope this helps.
Sep 09, 2009 | Kenmore Elite 45986 Front Load Washer
Tub sometimes will not spin to wring out clothes.
Sounds like the machine is not pausing between cycles to allow the transmission to lock into spin.
Eric
Jul 02, 2009 | Kenmore Washing Machines
Machine won't rinse or spin properly..also stinks!
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
May 08, 2009 | Maytag HAV2557 Top Load Washer
Tube doesn't spin during rinse/spin cycle.
It needs a new clutch. Call a repair technician.
Nov 19, 2017 | Washing Machines
Washer won't complete spin cycle
Try pushing down lightly on the lid and see if the spin cycle starts back up. On mine, the same thing happened because the small plastic pin attached to the lid was just barely long enough to push the switch that tells the washer that the lid is closed. The spin cycle will only run when that switch is pushed, i.e., when the washer thinks the lid is closed.
Jan 06, 2018 | Maytag Neptune MAH6700A Front Load Washer
Washer stops during wash cycle
you may a pluse cycle where the washer will stop for a couple of min, this cycle is for perm press to minimize wrinkels
Nov 12, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer Logo
116 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
