I SENT DVDRECORER/VCR PLAYER . YOUR RECEIVED ON 7/16/08 AT 11:47 AM AND I HAVE NOT GOT ANY REPLY ON IT. AND IT WAS TO TAKE 7 TO 10 DAYS TO RECEIVE A NEW ONE. ALSO YOU WERE TO SEND MY DVD "FEVER PITCH " BACK. PHYLLIS COLLEDGE
markevans
  • 148 Answers
SOURCE: dvd player not working
the disc may be jammed. try using a paper clip straightened a bit and insert into the little hole in the front of the dvd door. that should release the dvd drawer. if the drawer can not be pulled out because of a disc jam, you can try to close the drawer again and gently shake the dvd player side to side, front to back to jostle the disc back into the tray/drawer. then try the eject button again. failing that, you can try to remove the outer case and that ought to give you access to the disc, and allow you to see where it is relative to the tray.
try that and let me know how you are progressing with this problem
good luck
mark
Posted on Dec 29, 2007
SOURCE: rca dvd player drc285
I have returned the same dvd player twice and it seems that they all have this defect after a few runs. It's a shame because they can read divx but I'm done with this cheap brand made in very light fragile plastic. I've been told that there is nothing to do with this problem, it's just a bad one.
Sorry
Posted on Feb 02, 2008
djdizzys
  • 22 Answers
SOURCE: I am receiving a message
Hello have you cleaned the laser with a laser cleaning disc ? otherwise take the top off and get a clean cotton bud and put a small amount of white spirits on it and clean the laser when you have done this use another clean cotton bud and wipe off any exess fluid if any.
Does it play anything eg cd's or is it always saying bad disc ?
Posted on Mar 06, 2008
SOURCE: magnavox dv225mg9 dvd/vcr player. Hooked
I had the same issue. You probably have your unit connected with the newer cables that are red, blue and green. These are more sophisticated and offer better quality for the DVD portion. However, they will not carry the video for the VCR, only the audio.
You need to connect a *yellow* Video Out cable from your DVD/VCR to the Video In on your TV, this should carry the video for the VCR! Hope this helps!
Posted on Jan 05, 2009
SOURCE: Remote control via RI terminal on Onkyo Receiver
Not sure I can solve, but maybe help. I am having a similiar problem. However, make sure you Analog Audio (RCA type) cable are connected even if using Digital connection between the two. They use those cable to send the Commands (Mentioned in the documentation).
If you did get yours to work, please give me a hint... I upgraded mine from a 603 to a 701 and haven't been able to get it to work since.
Posted on Feb 14, 2009
550 5.5.1 Protocol Error
550 generally means the mailbox is unavailable. Make sure you typed the address in correctly. If you're just hitting reply, the person who sent the original message may have misconfigured their email client with the wrong "reply to" address.
Mar 30, 2016 | IncrediMail
I cannot reply to an email but am able to send emails out if they are originated by me
try saving it as new first, then try replying to it I have had this happen if the person I am replying to has blocked me; not your case if you are able to get through with a new email.
Mar 08, 2015 | Microsoft Windows 7 Home Premium 64BIT...
Connect a Dish VIP622 to a DVD/VCR
Hi piautewith the VIP622 receiver connecting to your DVD/VCR player you will need theinput/output jacks. To setup recordings to your VCR/DVD player, you will want torun from receiver output to VCR/DVD input and from VCR/DVD output to TV input. Thefan on the VIP622 receiver is just like the fan in a computer tower. Even ifthe receiver is off the fan will still run to keep unit the right temperature foryour DVR receiver. MikeHouston of DISH Network
Oct 18, 2009 | DISH Network ViP622 DVR DTV Receiver /...
There has got to be a way
I have this model..was trying to hook it up to a directv hughes receiver. After a day of trying and many curse words I found that using this hookup works . Hook up your satellite connection to you tv as usual...Now plug rca cables(red, yellow white) into the corresponding holes on the BACK of the Directv receiver ..now plug the rca cables into the FRONT of the Magnavox player...you will only use find holes for the white and yellow(that's ok) Now hook up up the dvd player to the tv using the rca connection back of dvd/vcr player..or if your tv only has a coax connection you will need a rf modulator available at walmart etc. You will run the dvd/vcr on L2. The key is the connections to the FRONT of the dvd/vcr player..I hope this helps..:)
Aug 03, 2009 | Philips Magnavox DVD/VCR Dual Player
DVD player not working properly
I have a DVD player, a VCR player, a TV set all hook into an RCA RT2250 Audio/Video receiver. Everything was working fine until 2 days ago. Now the DVD player gives me a great pix but no sound. The VCR,and TV are just fine and I have checked everything out, speaker connections, mute buttons, etc. and nothing seems to be wrong. I am thinking that some thing in the receiver got fried. Is it repairable?
Dec 13, 2008 | Electronics - Others
I have a 30 year old tv w/cable. I want to install a dvd/vcr combo player. What kind do I need? I've tried one and it didn't have the right connection.
If the original TV doesn't have audio/video inputs, you'll need a DVD/VCR player that has a built-in RF modulator. A RF modulator takes the audio & video and modulates a RF carrier to one of the channels that your TV can receive. In the U.S., this is usually channel 3 or 4. If the DVD/VCR player has a built-in tuner, connect your cable to the RF input of the DVD/VCR player and the RF Output of the DVD/VCR player to the cable input of the TV. This way, you can receive your cable channels through the DVD/VCR player and watch movies as well. If your DVD/VCR player does not have a built-in tuner, you can put a RF switch inline that will allow your TV to either receive the cable signal or signal from the DVD/VCR player.
- Jim
Jul 03, 2008 | Televison & Video
Sound problems
TRY PUTTING A SET OF PHONO CABLES INTO THE VCR INPUT THEN TO THE ANALOG OUT PUTS ON TOUR DVD/VCR SWITCH AMP TO VCR PRESS DIGITAL INPUT BUTTON ON FRONT OF AMP UNTILL YOU GET _ _ _ SET SOUND TO PROLOGIC 2.THIS SHOULD WORK.
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Onkyo TX-SR605 Receiver
Texting
please contact your network ""wireless service""..it is undoubtly the network provider prblem and ur mobile is safe and sound..all the best
Happy to help
Have a nice day!
tc
May 30, 2008 | Nokia 6300 Cellular Phone
Motorola V360 on Vodafone pay as you go
chuck that phone away it always has that issue-
Nov 21, 2007 | Motorola Mobility T-MOBILE V360 Flexible...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
