MOSMC139IPXI wont work in the CD/USB/Card mode
SD card wont work on Fujifilm F550EXR (CARD ERROR) Its a 32GB Kingston, is this why is doesnt work??
make sure you insert correctly, because some SD card are not compatible to other device,
Sep 22, 2011 | FUJIFILM CD-R Storage Media
I replaced my video card and now my screen wont come on... could that b a motherboard issue
  1. Sounds like you forgot to Disable your On-board Video card..
  2. If your video card came with a disk? Get it, if not go to the website, find your product, under support, and download the software, to a CD or Thumb Drive (USB drive)
  3. <Start>, <Restart>, slowly tap the F8 key until You see a list of choices, select Safe mode WITH Networking.
  4. A message will pop up explaining that you are in safe mode and what it means Click<Ok>
  5. <Starrt>, Right Click <Computer>, choose <Manage>
  6. From the left column choose <Device Manager> Scroll to <Display Adapter>
  7. Click the + left of <Display>
You should see 2 Video items, your New Device (Model) and another, <Disable> the old one [DO NOT- DELETE IT], just Right Click and <Disable> you will see a red 'x' on the old device, once it is Disabled..
If your new Device Is Showing, just restart and Enjoy; if it is Not showing in Device Manager, put in your CD or Flash Drive and <Install Drivers> and then <Restart>
Don't Worry: even if your new driver isn't installed, yet you can always still see your screen while in Safe Mode, As long as you don't Delete all of your Video Drivers.
After restarting remember to go back to Device Manger (steps 5 & 6) to make sure you have you new driver Enabled and the old driver Disabled.
Note**
if you can see you screen without going into Safe Mode? You're okay... Do a Windows Update to check if there are Windows Driver Updates for your Video Card...
Mar 18, 2011 | Computers & Internet
Hiya can you use a usb cable without a cd
while it depends on the phone model, but most Samsung phones have 3 options when connected via a USB cable.
1.Media mode
2.Mass Storage
3.PC Studio
If you need to work on the memory card(browse file Etc.) then select Mass Storage.
MEDIA MODE does the same thing but it also allows you to browse the phone's internal memory.
to use PC Studio,you need the CD
Mar 04, 2011 | Samsung Cell Phones
Not reading CD card or USB
install your card driver again plz reply yes to help imporve my rank
Oct 29, 2009 | Acer Aspire 3680 Laptop
Wont let me get to logg in stage
If it has USB slots, you could boot with a usb floppy or usb cd to dos. If it has a cd and you have a windows cd, you can use recovery mode.
http://support.microsoft.com/kb/314058
Mar 15, 2009 | Acer Aspireā„¢ T180 PC Desktop
Installation of K810i to pc who is now vista and not XP anymore
You dont need the Cd i also have same fone and Vista just plug the usb cable into the computer then into the fone then select file transfer mode on the fone... then go to start my computer your fone will show up in there as phone and fone card.. if you have memory card in it should show as fone card.....open that and look for DCIM file your pics should be in there ...When you have finished do not just unplug you fone got to the bottom off the screen by the clock and click the safley remove hardware and stop the fone in there before you unplug it from the computer ;-)
Jan 13, 2009 | Sony Ericsson K810i Blue Smartphone
Micro card doesn't work
Go to Setings, Connectivity, USB connection mode, and select "mass storage". Windows should now show the media card when USB is connected.
Oct 20, 2007 | LG CU500 Cellular Phone
Troubleshooting Steps for Windows USB connection issues
It can sometimes be difficult to setup a digital camera on a new computer. Usually the process is simple: plug the camera in, allow the system to install the driver and begin using the system, however, sometimes things can go wrong. Following these steps can solve more than 90% of problems relating to USB connection issues. You must be thorough and follow it step-by-step. What CF Card is installed in the camera? A large number of problems are caused by incompatible CF Cards. In many cases these cards will work while shooting but can fail to properly download to the computer. You must be extra careful that the card is approved. Actually look up the card you are using in the manual to see if it on the list. Many retailers include "Unapproved" cards in their bundles, so just because a card came with the camera doesn't mean that it is "Approved". If in doubt, use the "Nikon Starter Card" for testing. Is the Camera in Mass Storage Mode? While PTP mode can be used if your camera and operating system (Mac OS X and Windows XP) supports it, for troubleshooting it may be useful to switch to MSC USB mode using the camera's setup menus. Are there images on the card that can be viewed on the camera in playback mode? Nikon View will not auto launch or give a transfer window with no images on the flash card. If you have covered the first three items you should now connect the camera to the rear USB port (not through a hub or front port) on the computer. On all Windows systems excluding Windows 98 Second Edition (SE) ("Plain" Windows 98 is not supported.) make sure the Nikon View CDROM has been removed from the system prior to connecting the camera. Does the LCD Display Screen go dark after being connected for 2 seconds? If you are not getting the "Found New Hardware" wizard then check the LCD display. If the display stays "on" and the camera seems to be in Shooting mode or Playback mode then you may have a bad cable, camera USB port or computer USB port. If this is the case, contact Nikon Support for more information or Click Here for more troubleshooting. Does "New Hardware Wizard" Start? If you connect the Camera and a "Found New Hardware" wizard comes up you should allow the system to auto search for the driver by simply clicking the "Next" button until it is finished. (Windows 98SE requires the Nikon View CD-ROM to be in the CD-drive at this point.) On Windows systems newer than Windows 98SE the camera should pick up and use the Microsoft Mass Storage driver. "Hardware Handshaking" You need to understand how hardware handshaking works. The hardware Handshake occurs when a USB device is connected to the USB port. The computer detects the USB device on the USB bus and asks: "What are you?" The Coolpix line of cameras should answer: "I am a Nikon Coolpix 5700 currently set to Mass storage mode." If the computer does not understand this message the most likely cause is an incompatibility with the USB chipset on the partic
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
51 people viewed this question
 Grubhead
Grubhead
