Question about Sylvania G-Netbook
My 7' sylvania is not working it is brand new bought for my son in december we just got wireless but when we turn it on all it says is loading os image and it wont do nothing else
    Genius:
  • 1,267 Answers
You are probably going to have to re-flash the system as part of the operating system is not loading or is missing. See mu TIP at: It is looking for apassword (WiFi Network Key) You have to double click on the little computericon down in the right tool bar area, the one with the two side radiating arcs,and possibly has a small red X under it. The red X indicates that it is NOTconnected. When you double click on that icon a window called RT28701 opens up,then you click on Wireless Information tab, then you cursor down to the name ofyour WiFi and high light it and click the connect box. Then another windowopens up called Network Properties. Uncheck "The key is providedautomatically" box. This will allow you to type in your "NetworkKey", the password that protects your network from outsiders. This"KEY" was set up when you installed the router on your servercomputer. If this does not work at first, turn the machine over on its back andusing a toothpick, insert it into the little hole about an inch diagonally fromthe right corner of the data plate, this will re-load a new copy of everythingincluding the WiFi RT28701 driver. sometime thisdriver gets confused. See my TIP at: It is looking for a password (WiFi NetworkKey) You have to double click on the little computericon down in the right tool bar area, the one with the two side radiating arcs,and possibly has a small red X under it. The red X indicates that it is NOTconnected. When you double click on that icon a window called RT28701 opens up,then you click on Wireless Information tab, then you cursor down to the name ofyour WiFi and high light it and click the connect box. Then another windowopens up called Network Properties. Uncheck "The key is providedautomatically" box. This will allow you to type in your "NetworkKey", the password that protects your network from outsiders. This"KEY" was set up when you installed the router on your servercomputer. If this does not work at first, turn the machine over on its back andusing a toothpick, insert it into the little hole about an inch diagonally fromthe right corner of the data plate, this will re-load a new copy of everythingincluding the WiFi RT28701 driver. sometime thisdriver gets confused. See my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing AdditionalInformation When I try to signon with the red X showing, I get "The page cannot be displayed If I thendouble click on the icon down in the right corner I elucidated above, RT28701opens up to "Internet Protocol (TCP/IP) with all zeros in the IP addressfield, and Subnet Mask, with no entries in the default gateway. That is a clueto me that the automatic sign on has not found a viable network, or needssomething else. If I then click on Wireless Information tab, the list ofavailable networks, appear in the box. The machine keeps trying to associate myprevious entered name site with my preferred site and tells me the signal isgood, but it cannot link up. This is a signal to me that it has lost my NetworkKey or that the softwarehas failed or both. I then click on advance and delete my preferred network andhit OK, this will force the software to ask me for my network again, and noticethat the preferred is missing. I click on the name of my network again and thenhit connect., then the Wireless Network properties window opens up and I caninsert my Network Key again after I uncheck the "The key is providedautomatically" box. I enter the key and hit the OK button. I still do notget a connection, so I reboot the machine, and wait for about 30 seconds andthe machine synchs up because the little RED X under the icon has disappeared.Now the machine will hook to the internet as long as I want to, but sometimeswhen I turn the machine on it will not synch, so I go through the abovesequence again. The secret is once you have entered your key and ask for themachine to synch up you have to reboot. Why? I do not exactly know, but Isuspect that the WiFi driver looses it You may also wantto look at the TIP http://www.fixya.com/support/r7679654-sylvania_syneto7526_wirless_keyboard To make your knowledge complete AdditionalInformation When I try to signon with the red X showing, I get "The page cannot be displayed If I thendouble click on the icon down in the right corner I elucidated above, RT28701opens up to "Internet Protocol (TCP/IP) with all zeros in the IP addressfield, and Subnet Mask, with no entries in the default gateway. That is a clueto me that the automatic sign on has not found a viable network, or needssomething else. If I then click on Wireless Information tab, the list ofavailable networks, appear in the box. The machine keeps trying to associate myprevious entered name site with my preferred site and tells me the signal isgood, but it cannot link up. This is a signal to me that it has lost my NetworkKey or that the softwarehas failed or both. I then click on advance and delete my preferred network andhit OK, this will force the software to ask me for my network again, and noticethat the preferred is missing. I click on the name of my network again and thenhit connect., then the Wireless Network properties window opens up and I caninsert my Network Key again after I uncheck the "The key is providedautomatically" box. I enter the key and hit the OK button. I still do notget a connection, so I reboot the machine, and wait for about 30 seconds andthe machine synchs up because the little RED X under the icon has disappeared.Now the machine will hook to the internet as long as I want to, but sometimeswhen I turn the machine on it will not synch, so I go through the abovesequence again. The secret is once you have entered your key and ask for themachine to synch up you have to reboot. Why? I do not exactly know, but Isuspect that the WiFi driver looses it You may also wantto look at the TIP http://www.fixya.com/support/r7679654-sylvania_syneto7526_wirless_keyboard To make your knowledge complete
Posted on Mar 25, 2011
I had gotten a brand new sylvania smartbook model # synet07526 I had followed the instructions on my quick start guide book and all the smartbook book os doing is saying loading os, it wont even let me get...
To reset back to factory this is how i just did it , with the charge plugged, push the reset button in hold in for atleast 10 seconds, this may take several attempts it took me about 5 tries to get it to work successsfully , once it is reset all it does is just reboot and load new copy of OS.
Aug 14, 2013 | Sylvania G-Netbook
Sylvania os is gone
If it's new return it. Or contact Sylvania for a replacement.
Dec 08, 2012 | Sylvania Netbook Smart Book Mini Laptop 7...
Sylvania Netbook SYNET7WID frozen on OS Image what do I do?
When you turn it on, as soon as the very first screen appears press F11.
Than it should take you straight to factory restore settings. P.S.
This will delete everything it so safe your stuff in Hard drives or flash drives.
hope this helps
Oct 06, 2012 | Sylvania G-Netbook
I just bought my smartbook today. When I plugged it in to charge... the red light comes on indicating that it is charging for no longer than a couple of minutes before turning off. Also, when I try to...
I would not attempt any repairs, return this if it is under warranty, there is a fault with the battery, the charger, or the charging/power circuit
Jun 16, 2011 | Sylvania G-Netbook
I tried pushing reset and it still wont do nothing please help me get the loading os image of his computer so he can use it for the first time
if you are talking about the reset image or factory restore, not working that means your image is also corrupted. he will use it for the first time? is it brand new? if it is I suggest you contact support for Sylvania maybe you can get a replacement unit, Out of the box unit should not act this way. since the only way is to reformat it.
Mar 24, 2011 | Sylvania G-Netbook
L bought a Sylvania 7" Netbook as a gift for my
I would return it .. our Janitor has one, a gift from his dad.. He brought it up to me to setup for him.. If every thing would work, it would not be a big deal. I did at one point get it to connect to a wireless connection, but it would not communicate - would never get an address for a DNS server. Then at one point it would not turn on. After letting is set overnight it would start up but not a single program was on the device. I hit the reset button, nothing. I downloaded the latest and greatest OS update from the advertised web site.. unzipped it to an SD card.. tried to re-flash the unit - nothing.. Now I cannot recharge the batteries .. I can't wait to get rid of it. Most (maybe all) of the reviews and comments you read about this device are negative in one way or another.
Dec 28, 2010 | Sylvania G-Netbook
I bought a synet07526 for my son. We turned the thing on,, but all it says is loadin OS image, then goes black,,, we charged all night. What can be done
first time operation will take longer to load up as it must config.. may take a while anything up to 5-15 mins. if still no joy, you have 2 options post more details, or return it to where you got it.
Dec 26, 2010 | Computers & Internet
I can get the Sylvania Netbook connected to my wireless network, but it will not load the web pages
The WiFi software that is embeded into the OS does not work very well. Fortunately digitalgadget.com has a download that somewhat fixes this problem fairly well. The new download is not totally goof proof, but you can work with it.
Go to: http://www.digitalgadgets.com/netbooks/update.html and download the indicated update. You can copy it to a thumb drive and connect the thumb drive to your Sylvania , find it under My Computer and then copy it to your
desktop and run it from there.
Dec 03, 2010 | Sylvania G-Netbook
Need replacement lcd screen for sylvania 32"
Im nned tio find the location to download the soft ware for my wireless sound system Sylvania wireless sound system sa86011 ?
Feb 13, 2009 | Sylvania LC320SS9 32 in. LCD TV
Sylvania G-Netbook Logo
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
