Question about Dishwashers
I need instructions on how to install part # W10224431 on my whirlpool dishwasher
  • 436 Answers
This was solved by MNFisherman 7 months ago, he gets the credit:
Disconnect the power source to your dishwasher before you conduct this or any other repair. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel
Before you can begin to replace your dishwasher's wax motor, you must first locate the device. It is located within the door assembly, in very close proximity to the detergent dispenser cup. You will need to gain access to the inside of the door.
Examine the outside of the appliance. Depending on the model, you will have to remove either the entire internal door panel, or the entire external door panel. In each case, the panel can be removed by removing anywhere from 6 - 10 screws. Be careful to not remove the screws at the very bottom of the door that are actually a part of the hinge assembly. Removing the hinge assembly screws will remove the entire door from the appliance, which is not at all necessary to replace the unit's wax motor. With all of the screws removed, the door panel should be easy to lift off of the door assembly. If you have difficulty lifting the panel, look for additional screws you may have missed.
With the door panel removed, locate your dishwasher's detergent dispenser cup and the wax motor assembly.
There are two wires connected to the wax motor. Label them so that you will be able to correctly reconnect them later. Remove each of the two wires from their respective terminals - they are connected with slip-on connectors. When removing the wires, grasp the connectors and pull firmly. Do not pull on the wires themselves. You may want to use a pair of needle-nosed pliers to help you. Now that the wires are removed, remove the wax motor.
Discard the used motor and connect the wires to the terminals of the new motor. Position your new wax motor in place of the old one. Replace the door panel and restore power to your dishwasher.
Posted on Mar 24, 2011
Installing dishwasher WDT710PAYM door will not open
It is likely the door springs at the base are too tight and holing back. The installation instructions show how to release the door springs.
If you do not have these instructions then download from this site.
http://www.manualowl.com/m/Whirlpool/WDT710PAYM/Manual/221751
Jun 12, 2014 | Whirlpool WDT710PAYM Dishwashers : Built...
Whirlpool dishwasher insulation - how to affix
It could be just draped over the top and hooked under the "tabs" on both sides. I have seen a similar installation
Dec 04, 2012 | Whirlpool Dishwashers
Whirlpool GU1500X dishwasher motor noise got loud
Hello- Yep- it's toast. A small seal on motor shaft failed, causing water to destroy bearings. Motor is about 100$. Installation instructions available if you choose that route. Let me know if this info helps- have more if needed.- Thanks - Ed
Mar 12, 2010 | Whirlpool 24 in. GU1500XT - Multiple Color...
Does not start, Nornal light blinking
Hello- Common problem. Touchpad has a short at 'normal' switch. Console assy. is about 120$ Installation instructions available. Let me know if this info helps- have more if needed.- Thanks- ED
Mar 09, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Our Whirlpool makes a howling noise
Hello-  Debris in sump can cause noise, but if unit is 5yrs or older, motor bearings are failing. Part about 100$. Have installation instructions if needed. Let me know if this info helps -have more if needed. -Thanks-ED
Mar 08, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Water wont go in to the dishwasher
Hello- The most likely suspect is a failing water valve. Part is 30-50$ Installation instructions available. Let me know if this info helps- have more if needed. -Thanks- ED
Mar 08, 2010 | Whirlpool 24 in. ADP5966 Free-standing...
Door brake on dishwasher broken
part number 8194001.. easy install, just need to remove th eunit form the cabinet perhaps 1 foot or so, the "door links snap" the kit comes with everything you need(including instructions) probably 20-25 bucks.. i get $200 for that job, might take you all of 30 min.
Feb 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Replace Heater Element for Whirlpool Model GU 1200XTLB1 Dishwashr
Look inside the dishwasher to see where the heating element terminals are. If they are in front you might be able to change it but if the element is in back, you will need to have the dishwasher pulled out to install the element.
http://tclaundryrepair.com/
Feb 20, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Replacing drainage hose on Whirlpool dishwasher?
Just follow the hose to the other end, it goes under the dishwasher and it usually just clamped to the drain pump. Should be able to buy a replacement hose at repair clinic dot com. Installation is the reverse of removal, just pay attention to how the hose is routed, they need to be reinstalled the same way. Hope this helps.
Feb 08, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Dishwasher Heater Element
service manual for gu1200 and 1500
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/52521bdbd0ef763c85256cbc00520548/$FILE/8178022.pdf
Jun 05, 2008 | Whirlpool GU1200XTLS Stainless Steel...
Dishwashers Logo
273 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
