Question about Dell E173FP 17" LCD Monitor
Tipped monitor away from me just to dust under and it turned pink. Restarted and checked cables. Can still read text but it's not good.
  • 11,361 Answers
You need to check all the pins at both ends of the video cable. Just incase, you should also try i with another PC also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 25, 2011
My screan is gone pink and purple what can i do
Check that the monitor cable is securely connected to the video card. Also restart the computer. Now just as the computer is starting up, is the text pink/purple? If so, it is likely that your monitor has failed. -Ravi Shanghavi
Aug 19, 2010 | Computers & Internet
My Q19wb keeps turning pink where it shoulod be white. This isn't the first Optiquest monitor that I have known to do this. What can I do to keep it from turning pink? It's very annoying......
Not much you can do. I would recommend just buying a nice affordable general brand LCD monitor. Don't go to best buy or some place that specializes in that, you can get it cheaper at wal mart or k mart. possibly sears or Sam's Club
Sep 04, 2009 | Optiquest Computers & Internet
Display shakes on monitor
Try these, 1) check the pins on the leads into monitor and computer thy tend to bend,
2) check there is no mains near the cables or monitor, it can cause feed back (EMF)
3) check the graphic card "if fitted " is not lose, unplug computer, then switch on comp without plug in socket, this will purge the board of any electicity, remove graphic card check for dust ect clean and then replace, put plug back in socket and switch on.
4) when a moniter is first switch on it purges the screen "degauses" "maybe spelt wrong" if it is constantly doing this it will be a fault within the screen.
5) Try a different cable that you know works it could be a break in the cable someware.
grandpaben
Aug 16, 2009 | Computers & Internet
Tiny pink dots will appear over the entire monitor viewing area
Its a signal cable problem,between AD bord to Panel..Fix it poperly, If no then replace the LCD panel..
Jul 10, 2009 | HP w17e Monitor
Monitor turns pink quite frequently
i think problem is the vga cable of monitor try to remove the cable of your monitor attache to pc or try to reconnect the vga cable
May 21, 2009 | eMachines E17T4W 17" Monitor
Westinghouse LCM-22W2 has "ghosting"
Usually, LCD monitor ghosting appears when the cable isn't tight, the cable is faulty, or low quality. The cable should be less than 8-10 feet long. Try using a different monitor cable (they're mostly interchangable) and see if the problem goes away. I'd put my money on the cable or a loose cable connection.
May 13, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
LCD Monitor Half Screen Pink
sounds like a color balance issue. Check the menu, do a degauss...and then check for the color temperature (reset for default)..
Got backup?
Feb 10, 2008 | Proview PL 566s 15" Flat Panel LCD Monitor
Pink-hued display
one try a degauss
second check the cable wich connect the monitor to the pc video card.
third. keep away the magnetic things like speackers from the monitor..
bye:)
Feb 03, 2008 | Compaq CV 7500 17" CRT Monitor
Monitor screen turned into pink
A defective monitor cable can cause the monitor to turn pink.
May 13, 2007 | SAMTRON 55V 15" CRT Monitor
Dell E173FP 17" LCD Monitor Logo
Alun Cox
