Question about Amana ARS2464B Side by Side Refrigerator
Amana Freezer has defrosted and fridge is getting warm.
  • 132 Answers
The defrost timer has stopped working.
it should have timed out and started cooling again
You may need a new defroat timer
A technician can help you with that
Posted on Mar 25, 2011
Amana fridge freezer AS2628HEKB fridge warm & freezer frosty inside
The board should be replaced before the unit will operate properly. Be sure to check out all circuits to make sure there is not some kind of short. If there is, it may burn out the new board also.
Jan 21, 2013 | Refrigerators
I have a fridge with the freezer on the bottom, model#ARB190RCW. the freezer is working but the fridge is warm!
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 24, 2011 | Amana Refrigerators
Amana bottommount refigerator--ABB1922FEW--- BUY 08-03-07 AMANA REFIGERATOR WARM---60+ DEGREES FREEZER ---YES---10 DEGREES FREDD- APHASIA--COMMUNICATION PROBLEMS--- NICKNAME: giesslerf PASSWORD: abd7f
Wow
Ican not understand what you need.
So I am guessing here
Ice has built up on the evaporator coil stopping air flow to the food section.
Try manually defrosting the fridge. If this works then the auto defrost cycle has failed and you will need to get a technician to help you
Mar 30, 2011 | Amana ABB1922FEW (186 cu ft) Bottom...
The top portion of both the freezer and fridge are warm but bottom half are freezing.
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 27, 2010 | Amana ARSE66MB Side by Side Refrigerator
Refrigerator is warm @ 60 degrees and the freezer is still freezing happens every so oftern
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 08, 2009 | Amana ABB1927DE Bottom Freezer...
Freezer side blowing all the time and fridge side is warm with no cooling on amana side by side unpluged and defosted with hair dryer and it worked for a couple days then went back warm in fridge side...
You have a defrost issue.
Adaptive defrost control.
Defrost thermostat.
Defrost heater.
These are the only 3 parts involved.
If there was a model number I could be more help.
Feb 20, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Warm fridge
check the fan in the frezer and check the defrost
Nov 29, 2008 | Amana Refrigerators
Refrigerator warm but freezer is fineChanged the evaporator fan (12013211q)for BR18Ve Amana...Is it possible that the part last only a couple of years...
If your bottom freezer has ice build up, (you will see it frosted up), you do not have proper air flow. Check to see if your defrost elements are working. They are in the freezer compartment. in the evaporator. There is a defrost timer on the bottom of your fridge. You can turn the knob until the refergerator turns off, then listen in the frezzer compartment to se if the elements are working. (You will hear them sizzle)
Aug 26, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana ARS2464B Side by Side Refrigerator Logo
89 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
