Question about Tomtom XL 330 Car GPS Receiver
I tried to update my unit and got an error message before it was done that the update wasn't completed and now when I turn it on it says I cannot use the USA_Canada map on the device..Stuck
  • 17,970 Answers
Quote:
We're sorry, but HOME can't complete that task. Please try again later, or contact customer support. For problems with items that are stored on your device, we advise you to remove and re-install the item.
END
To make a long story short, the problem was with the map that is stored on the computer from downloading the latest map guarantee (2 1/3 years ago). In my case, this is the same map as is on the GPS, but it is not complaining about the map on the GPS. If this happens, there are several things that can be done:
1. Accept the message whenever it appears and go on with what you were doing since at least most functions of Home appear to work correctly in spite of it saying that it can't complete the task.
2. If you have a backup of the previous version of TomTom Home, replace the updated version in the Applications folder with the backup version. This will return behavior to what it was before the update, without the error messages.
3. Remove the map folder (e.g., USA___Canada) from your Documents->TomTom->HOME->Download->complete->map folder. You may want to save this someplace so that you can put it back when TomTom releases an update to Home that works correctly.
Hope helps.
Posted on Mar 24, 2011
My 3 1/2 yr old unit stopped working completely at almost the end of the cycle. When I went to take out the clothes they were still wet, thought it was the spin cycle so I tried that and the machine...
Hello Anne, thank you for allowing me to assist you!
Based on the symptoms you are describing it sounds like the issue could be related to the door switch or control board. However, first let's try recalling the error code by waking the unit and wait approximately five seconds. Then press and hold CANCEL and START/PAUSE key at the same time. Error code should display. With the error code I can help you determine the possible failures.
If the washer does not display an error code, reset the washer. This can be done by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes, turn the unit on and redo the steps above.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you!
Sep 25, 2013 | Frigidaire Affinity ATF7000E Front Load...
TI-83 Plus "waiting ...please install message then "error message
Please Install Calculator Software Now error
This message means that the operating system has been corrupted. These steps will allow you to update the OS.
Unit to Unit
• Connect two TI-83 Plus units by means of the data cable (short black cable that was prepackaged with the TI-83 Plus)
• Make sure that at least one of the TI-83 Pluses contains the current Operating System
• Select [2nd] Link
• Select "Send OS" option from the Link menu
• Make sure that the other unit still reads "Waiting Please Install"
• The OS should be downloading.
From the Computer
• Make sure you have the latest version of the TI Connect™ Software
• Download the latest version of OS for the TI-83 Plus to the desktop of the PC.
• Connect the appropriate TI-GRAPH LINK™ cable between the PC and TI-83 Plus.
• Since the TI-83 Plus is currently off, the TI-83 Plus will automatically turn on when the TI-GRAPH LINK Cable is inserted.
• On your computer, choose Start, Programs, TI Tools, TI Connect, TI OS Downloader.
Dec 10, 2007 | Texas Instruments TI-83 Plus Calculator
SYSTEM PROBLEM FOUND
You need to update the toy. Connect it to your Learning Lodge Navigator. You should be prompted for an update.
Aug 03, 2013 | Vtech MobiGo 2 Touch Learning System -...
Cartridge Error 50C consult user guide. I
Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
Newbie doesn't know what to do with 3rd gen itouch
bring it back to apple store and get a refund
Sep 20, 2009 | Apple iPod touch
Printer will not print it will say error 50c
Hi there Error 50c
Ok try this.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Sep 18, 2009 | Dell A940 All-In-One InkJet Printer
Error 50 c
  1. Power off your printer.
  3. Turn the printer on. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Hope this helps.
Jul 29, 2009 | Lexmark X6170 All-In-One InkJet Printer
Error 50c Using real Dell carts Tried reinstalling drivers still
Hi there Error 50c
Here we go try this out.
color cartridge.
Mar 26, 2009 | Dell A940 All-In-One InkJet Printer
Each time i run the Norton liveupdate there is an error message regarding the Norton 2009 virus definitions:- Status:Failed to complete
hi tuddy,
all you need to do is do an update on your norton and when its done, try restarting your pc and do an update again.
maybe 2 or 3 restarts and updating will do the trick.
if the problems remains, pls try this. follow the link
this is a manual update on the visurs definitions that your norton status faisl to complete.
hope this helps you.
Jan 22, 2009 | Computers & Internet
8002F1C1
I think you should contact them. ;-]
Sounds like an internal error with the hardware.
Sep 09, 2008 | Sony Playstation 3 (PS3) Console
Tomtom XL 330 Car GPS Receiver Logo
125 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
