I am getting the hp screen and it freezes there it will not enter set up or boot menu just freexes hp pavillion please tell me what do i do
  • Computers & ... Master
  • 27,725 Answers
The first thing to test
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Mar 24, 2011
How do you put the computer in safe mode on a HP pavillion?
If I remember correctly, for Windows XP:
Click on 'Start' at the bottom left of your screen
Click on 'Run' - should be on the right side of the Start menu towards the bottom.
A box will appear at the bottom of the 'Start' menu. Enter "msconfig" (without quotation marks), and press the Return/Enter Key.
A new window will open with several tabs. Click on the BOOT.INI tab to open that, and click in the square box first on list by /SAFEBOOT. There are three variants of safe mode. For now, choose 'Minimal' (click in the circle by that word). Now move to bottom right of the MSCONFIG window and click on the 'OK' button. Now the window will close, but next time you Restart/Start your computer it will be in Safe Mode (font will different, and it will say 'Safe Mode' at the four corners of the screen).
12.April.2014
Aug 30, 2012 | HP Pavillion s7420n PC Desktop
My HP Pavillion dv7 3112sa won't boot and remains
Hi, at startup try pressing f8, this should give you a menu, select 'start windows with last good configuration', this should restore windows to the state before it started rebooting randomly. Failing that...try starting in 'safemode with command prompt' and then do a 'system restore'- press f8 again at start up and then follow the instructions below. this should restore your system to a previous state when the computer wasn't doing random things.
  1. Restart your computer, and then press and hold F8 during the initial startup to start your computer in safe mode with a Command prompt.
  2. Use the arrow keys to select the Safe mode with a Command prompt option.
  3. If you are prompted to select an operating system, use the arrow keys to select the appropriate operating system for your computer, and then press ENTER.
  4. Log on as an administrator or with an account that has administrator credentials.
  5. At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER.
  6. Follow the instructions that appear on the screen to restore your computer to a functional state.
I hope that this helps you to sort out the problem. Toni
May 27, 2012 | HP Computers & Internet
I want to restore my laptop to factory settings its an hp pavilion dv4000
  • Using the recovery partition
    • 1 Turn on your computer and insert your recovery disc. Press F10 during start-up to open the console. This opens up the HP recovery console.
    • 2 Click "Next" on the screen that appears.
    • 3 Choose whether you want a nondestructive recovery (one that keeps your files in place) or a destructive one (one that erases your disk and rebuilds your system to factory defaults). If most of your files aren't corrupted or are still usable, go with a nondestructive recovery. Otherwise, perform the destructive recovery.
    • 4 Follow the instructions on the prompts that appear to restore your HP Pavillion.
  • Using recovery discs
    • 1 Turn on your computer. Press F1 at the first logo screen to enter the BIOS menu.
    • 2 Move to the Boot Options section of the BIOS menu. Look for the Boot Priority menu.
    • 3 Set the Boot Priority option to booting the CD-ROM first.
    • 4 Insert the first recovery disc into the HP laptop. Then press "Enter" on your keyboard to save your settings and exit. The computer will then reboot into the recovery console.
    • 5 Follow the instructions on the prompts that appear, to restore your laptop.
  • Jan 01, 2011 | HP Pavilion dv4000 Notebook
    I have an HP Pavillion a1250n which has a MS-7184 V1.0 that will not boot. When turned on the HP Invent logo screen appears with thw following at the bottom:(Esc=Boot Menu)(F1=Setup)(F10=System...
    It sounds as though you might have a problem with BIOS.
    You should remove your motherboard battery (little round silver disc) and if you can find (or Google motherboard model#) the CMOS reset jumper, you can remove the battery for 30 seconds and put it back in and reset the CMOS, then see if it boots. If it doesn't, you might need to flash the BIOS, which is not recommended unless you know what you are doing.
    Nov 16, 2009 | Intel Motherboard
    Have an hp pavillion a6319fh boots to blue screen and curser
    Could be alot of things, Scratched , even a small pinprick on the CD, or you have some bad ram, or your Hard drive is going. Thats the thing about troubleshooting a PC.
    Sep 22, 2009 | Computers & Internet
    Haw to boot dvd windows in my laptop hp hdx16
    Dear user,
    Please set the CD/DVD ROM as a first boot device in bios setup. then you will be able to boot from CD/DVD.
    Please dont forget to RATE my answer
    Sep 05, 2009 | HP HDX16t Entertainment Notebook PC
    Ongoing problem with HP dv9000 Pavillion
    I have a pentium 4 computer but the computer does not work properly.
    Jan 15, 2009 | Computers & Internet
    Freezing or shutoff on boot, setup or minutes into operation
    Try this:
    Boot the system with your Windows XP installation disk. When the boot options window appears select R for recovery console. Once you have logged into the DOS session type: fixmbr and hit the enter or return key and select "y" for yes you want to do this. Type: fixboot and hit the return key again, hit "y" for yes.
    May 17, 2008 | HP Pavilion ze2000 Notebook
    Hp pavillion trying to boot from dos mode
    This is a common HP laptop problem.
    Please try these steps, if they dont work you will have to do a restore.
    Please let me know how you make out.
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00372724&cc=us&lc=en&dlc=en&product=1137817&dlc=en&lang=en
    Dec 08, 2007 | HP Pavilion zd8000 Notebook
    Computers & Internet Logo
    Alun Cox
    David Payne
    David Payne
