Question about Sub-Zero Refrigerators
We are experiencing heat along the panel between the fridge and the freezer. What could cause that?
  • Sub-Zero Master
  • 3,289 Answers
Many fridge's have a selector switch for "humidity" This can be vague as some do not go into great detail about what they do or how they work.
The 10 cent answer is that the heat you feel is part of the defrost circuit. There are places on the outside of the fridge & freezer (mostly near the doors) that are prone to moisture build up. This is caused when the cold air (escaping the fridge & freezer compartments when the door is opened) meeting warm humid ambient air of the kitchen in warm, humid months. The cold air condenses and water droplets form on the fridge case.
If you live in a warm, humid area; you would set the switch the way is currently set - that is; to turn on the electric heaters in the these certain spots of the fridge cabinet to prevent moisture (and eventual corrosion) from accumulating. If you are not living in such a climate, you could change the setting of the switch so that the heater does not run. This would save you a few bucks on you electric bill. These heaters are fairly small and only run for a relatively short time (20 minutes) 2 - 4 time / day - at the same time the defrost circuit in the freezer runs.
Try it the other way and see if you don't have a problem with moisture / don't mind moisture build up.
I hope this answered your question. Please rate my reply. Thank you.
Posted on Mar 24, 2011
  • 29 Answers
Most refrigerators have some of the condenser coil running through this area to keep condensation down. As long as the unit is cooling fine and it is warm but not very hot there probably isn't a problem. You can check to see if the coils on the bottom are dirty, a cover will have to be removed. Also check to see if the condenser fan is running which is close by the compressor.
Samsung RF25HMEDBSR bottom freezer fridge. Fridge is at right temp.,ice maker works, but the bottom freezer is not working.
The condenser coils are usually located under the refrigerator. They dissipate heat as refrigerant passes through them. If the condenser coils are dirty, they won't dissipate the heat effectively. As debris builds up on the coils, the refrigerator/freezer becomes less efficient, causing it to work harder to cool down. If the coils are significantly dirty, it will not be able to maintain the proper temperature. Check the condenser coils to determine if they are dirty. All models have coils in an enclosed area usually accessible via a vented cover at the back of the refrigerator. These coils help to keep the refrigerator and freezer cool. If these coils become too dirty from dust or other particles, the freezer may not work as efficiently.
unplug when taking the vent panel off to clean. bottle brush or a vacuum attachment be careful not to bend aluminium fins.
Jan 30, 2018 | Samsung Refrigerators
Freezer not freezing but cools like the refrigerator would. Refrigerator not cooling enough. the cover in the back of the refrigerator was off. I reconnected but the freezer still won't freeze
is the freezer fan running? is there frost on the rear freezer wall if so it would be a defrost issue. if no frost on freezer rear panel it would sound like a bad compressor or sealedsystem leak.
Jun 06, 2011 | Kenmore Top Freezer Refrigerator
Ref side not getting cold, freezer still cold
Hi, Is the Freezer still cold? If so either the Fan (In back of freezer-Remove rear panel) is not working or the vent between freezer and fridge is close (side panel between freezer and fridge) Check either of those should be able to pick which is not working
Jul 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator not getting cold even when set at lowest point.
Not enough information. But here is something which may help you diagnose the cause. I assume that you have a frost free fridge freezer. That there is a fan in the freezer which blows cold air down into the fridge.That the freezer is still cold. You can hear the fan cutting in and out.
Try opening the Fridge door and locate the little plunger switch which is pushed shut by closing the door (like the switch on you car door that turns the interior light on and off).
Push it in manually with your hand. (the fan needs to be running. The fan should blow cold air into the fridge. There will be a panel with vents, probably on the back off the fridge. Cold air should be coming from this. When working properly the temperature sensor in the fridge will control a flap like valve to allow or disallow entry of cold air from the freezer to the fridge.This controls the temperature of the fridge. If the flap is jammed shut no cold air can enter the fridge. Likely cause is ice build up, most likly in the back of the freezer blocking the path of the cold air. I had this problem on an old fridge of mine.I think that it is caused by the heat cycle not kicking in correctly to defrost the heat exchanger . I used to DISCONNECT THE FRIDGE FROM THE ELECTRICAL SUPPLY dismantle the inner panels of the freezer. And pour water over the ice monster blocking up the back of the freezer. Not a good solution i grant you. But it would work for a week or two. Then i would have to do it again. later i found a small panel on the back (outside) of the fridge with wiring and stuff inside it. There was a rotatable knob which clicked as you turned it. in one position you could hear it make the heat cycle kick in manually. I spent about 6 months doing this every few days whilst saving for a new fridge. It worked. But there is a RISK OF ELECTROCUTION .
Sorry i cant fix your problem . But this might be of some help to diagnose it. If you are not sure i wouldn't recommend fishing round in the electrics. I have had quite a few electric shocks doing stuff like this because i am not as careful as i should be, and i am not a qualified electrician. It never hurts me much. But some people will die quite easily from mains voltage. BE CAREFUL!!
Feb 17, 2010 | Kenmore Refrigerators
Our 10 year fridg seems to get very hot on the side...wondering what would cause this Model et18pkxaw00
The condensor coils run along the inner sides of the fridge . The heat you feel , is the heat being pulled out of the freezer which is the purpose of "freon" (to attract heat) . A freezer doesn't get cold , "freon" pulls the heat out , which is then cooled by the condensor fan ( fan which cools the compressor and coils ) . The more heat you feel , the colder the fridge should get ( to an extent ) . Also make sure the compressor fan is working .
Aug 19, 2009 | Whirlpool Refrigerators
The bottom of my fridge is frozen alonge with the fridge food
Hi sir
it bis thgermostat problem,(heating element),,,so the heating is not done properly by thermostat,,so u should check iot,,,
thank u,,,please rate it,.,,,
Jun 30, 2009 | Bosch KGU32124 Bottom Freezer Refrigerator
Burning Rubber smell coming from fridge
try taking the bottom panel off and vacuming all the dust on the coils. The dust may be heating up and burning. The coils are usually at the bottom of the fridge. Check to see if the fan is running also.
Jan 16, 2009 | Refrigerators
Overheating
the inreasion of heat is normal if you recently add food to froze.Let it work for some hours without open it and check it again
Nov 06, 2007 | Samsung RS2630SH Side by Side Refrigerator
Bosch Classixx fridge / freezer
Hi - experienced this myself and spent ages trying to get to the bottom of it - only found one post but it worked and was absolutely clear on the cause nb: i'm not an "expert" !
My understanding of how the Bosch f/f works is that the freezer compartment generates the cold air for the fridge which is regulared at the fridge end . At the back of my fridge there are two "vents" which feed up this cold air up from the freezer into the fridge.
Problem happened to me because I left the freezer door slightly ajar which generated a massive amount of frost (sucking in the moist air from the house I guess then freezing it) and subsequent ice froze up the cooling ducts between the freezer and the fridge. Therefore, no matter how much I turned up the fridge thermo it never got cool. Only solution was to dump my frozen at a mates house and defrost the the FREEZER for a good 24 hrs +.
Worked tho' - fridge was completely back to normal.
PS: I understand this issue may also happen if you put too much unfrozen food into the freezer at one go and in working overtime to get it frozen causing a massive frost up again.
Nov 01, 2007 | Bosch Classixx KGV28323 Bottom Freezer...
Refrigerators Logo
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
