Question about Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look
Whirlpool refrigerator replaceed new filter ukf8001 I get no water
  • 29 Answers
Did it work before you replaced the filter? If so try taking the filter out and then trying it.
Posted on Mar 24, 2011
Tip
New Jenn-air refrigerator, Model #JFC2087HRS, water filters do not work...
The new Jenn-air refrigerator, model #JFC2087HRS, water filters (UKF8001) do not work correctly. Water flow is slow. I have called the manufacturer but cannot get any help from them. They insist they work fine. I have tried several of the new ones. The problem seems to be that the small ramps on the new water filters are not tall enough to push the small plungers sufficiently into the water dispenser. I have added a small piece of plastic (glued) to the ramps on the water filter in order for them to work better, but not as good as old ones worked (UKF8001AXX). The next best thing is to buy the old filters if you can find them.
on Feb 24, 2014 | Jenn-Air JFC2087HRS Side by Side...
Slow water pressure and buzzing sound on fridge with new filter
Have you tried removing filter and reinstalling. Try that. Also sometimes you just get bad filters. Sounds like the bypass on filter housing not getting depressed all the way
Aug 18, 2012 | Refrigerators
Where is the water filter located in back?
On your refrigerator filter is in the ceiling of the refrig. section above the top shelf in the upper right corner
The part number for the filter is ukf8001 its available at your local appliance parts store,Sears,
Lowe's or HomeDepot. Just take in the old one to match it up.
Gene
Aug 15, 2011 | Maytag MZD2669KE Side by Side Refrigerator
I need to replace my water filter. The Model number on my refrigerator is: MZD2666KEB. It has a Puri Filter II in it now but I can't find a replacement. Will Maytag filter UKF8001 work in this model?
Hello, Thank You for using FixYa. I will be helping you today.Yes that is the correct filter for this model.
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Maytag Refrigerators
I have an amana refrigerator model abd2233dew. What type of water filter do I need for the back so the ice maker will work?
the factory filter is a ukf8001 cost 38.92 . the filter may not make the ice maker work but if will help .. . if water comes out of the foutain then filter will not help ice mker work .. mm
Jul 03, 2010 | Refrigerators
I CANNOT REMOVE THE WATER FILTER LOCATED IN THE UPPER RIGHT INSIDE THE REFRIGERATOR. I TRIED TO TURN IT COUNTER CLOCKWISE BUT IT WILL NOT COME OUT. THE PART NUMBER ON THE FILTER IS UKF8001. ANY...
  1. 1. Look for the water filter cartridge. On some refrigerators it is located in the back, upper right corner of the refrigerator compartment. Some refrigerators have it in a tubular-like slot under the door and accessible from outside.
    2. Remove the old cartridge. On the cartridges that are located inside the refrigerator, the cartridge should be slowly turned to the left. Don't pull down on the cartridge. A small amount of water may drip. On the type that are under the door, follow the arrow labeling for the direction to unscrew it. Slide it outside.
    3. To replace a filter, fill the replacement cartridge with water from the tap. This will speed up water flow after installation. Run water from the dispenser for three minutes after replacing a filter to clear the line. Refrigerators with a filter warning light require you to reset the light. Press and hold the Reset Water Filter button to do that.
Jan 18, 2010 | Refrigerators
Filter will not turn counter-clockwise.
Push in while turning. Some are on a spring-loaded bayonet mount. This should do it.
Regards, --W/D--
Aug 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look Logo
52 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
