We keep getting a F-21 error on our Maytag Epic Z washing machine. What does this mean and what can we do to prevent it? Thanks
  • Washing Mach... Master
  • 822 Answers
Sounds like the drain is blocked.......
shud be a drain catch at the front near the botton..
just open it get ready for some water escaping
clear drain n you should be job done.........
cheers
Posted on Mar 24, 2011
What does F- and 21 mean
Error code F 21 means the drain is clogged...follow this advise for the Whirlpool washer as Maytag was bought by them
there is also this site for the washers http://fixedappliance.blogspot.ca/2011/11/whirlpoolkenmoremaytag-more-f02f21-sd.html
Jun 04, 2015 | Maytag EPIC MFW9700S Front Load Washer
My maytag washer epic Z started out with an F 21 code. I opened it up after I turned it off and water started coming out. I turned it off and waited about 20 min and it did start and I fut it on Spi
That error means that it is taking too long to drain. Check the pump filter under the unit and remove any debris that may be in it. Be warned that when you take the drain plug out to clean it, you will get water on the floor.
Jan 22, 2015 | Maytag Washing Machines
Maytag washer throwing fault code 21
An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
May 20, 2012 | Maytag Washing Machines
Maytag epic II washer error codes, especially error code F 21
HI. Click here to download the complete service manual for this unit. All the repair procedures and error code definitions can be found in this repair manual. I would advise to save this PDF to your HD for safe keeping.
May 02, 2010 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic Z with error codes F20 and F24
my epic will start & wash & then gets F 20 & won't drain until I hit start again
Oct 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
Error f-21 what does that mean?
not enough water intering tub with in the first
10 seconds of the fill cycle
Jun 20, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag epic
hi there,
the FH error means it's either you have a drain problem if there is water in it or if if there is now water in it, make sure that both water inlets are turned all the way up. check to make sure that you don't have any water leaks anywhere visible.
Oct 03, 2008 | Maytag EPIC MFW9700S Front Load Washer
Epic 9600 model door will not open machine will not engage code comes on screen dl f
hi there,
this code means you have a door latch error. this is why the door does not open or does not work. the machine automatically shuts down when this error happens to prevent the machine from running endlessly. call a technician to replace the door lock.
thanks
Oct 02, 2008 | Maytag Washing Machines
I just purchased a floor model Maytag Epic Z front loading washer and it's giving me the error code F28, What does that mean?
hi there,
you may have a shorted thermistor.
can you tell me when this problem happens?
also, can you provide me with a complete model #?
thanks
Sep 27, 2008 | Maytag Washing Machines
Washing Machines Logo
98 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
