Question about Microwave Ovens
Microwave won't run
My microwave runs for 7 seconds and then it stops and displays f-9 in the display window.
  • smokewhite00 Aug 18, 2008
    I am having the same problem, my microwave runs for 7 seconds then stops displaying F9 on the control panel.
  • Microwave Ovens Master
  • 9,086 Answers
F9 code means either a bad door switch or a loose door switch mount.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
(If not, please reply back with your brand and model number so we can help you.)
Posted on Aug 09, 2008
Microwave runs for 5 seconds then shuts down displaying F9 HELP
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad
Oct 19, 2014 | LG Microwave Ovens
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermostat
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Feb 08, 2013 | Microwave Ovens
Microwave was run empty and now it won't run. Display works but no fan or microwave. What to do?
The magnetron does not fair well when running empty, the thermal fuse usually kicks in if a metal object was put in by mistake, but should be checked along with the door switches.
May 31, 2012 | Panasonic Microwave Ovens
My Kenmore Elite over the range microwave model 85293 will only run for a few seconds and then it atuomatically stops and says F-9 on the display pad. It does not heat anything. What does F-9 mean?
Just had this happen - the repair guy says it is the inverter. And they have stopped making the part so it cannot be fixed!!! When did you buy your unit?
Jul 03, 2010 | Microwave Ovens
Microwave will turn off a few seconds after start.-
It seems there is something wrong either with the builtin controls or the buttons. It needs to be examine by a professional.
Oct 31, 2017 | LG Over-the-Range Microwave
Model 72180883400
F-9 error code indicates a defective control board, inverter or line voltage too high. f the microwave runs for about 7 seconds with a ticking sound..then stops and shows "F-9", it is the magnetron that has failed. The fact that the unit starts and runs with the TICKING SOUND means the control board is sending signal to inverter board and the inverter board is sending signal to magnetron. Magnetron is covered by full 5 year warranty, inverter board is only 3 years.
Sep 01, 2008 | Kenmore 62702 Microwave Oven
We set the cook time and push START, the oven runs for 30 seconds then stops,then (F-9) appears in the display window. What does this mean? Please send me an answer! Thank You, Tom Clegg PS...
What brand is your microwave? I looked under panasonic and kenmorer because of the numbers you gave but can find nothing under either. I need:
The Brand (complete Name)
The model(Complete model name
Model #
Please have another look. :0)
Aug 12, 2008 | Microwave Ovens
F-9
Need to know the entire model # on the microwave.
Oct 05, 2007 | Microwave Ovens
Shuts down after running about 8-9 seconds.
We'd need the full model number to be sure, but it sounds like an inverter failure. Due to the lethal voltages involved, I do not recommend that a person without training and experience ever work on these models. I would call Sears for service. See http://www.sears.com
Sep 15, 2007 | Kenmore 80883 Microwave Oven
4205 stops after a few seconds, beeps, every segment of every digit lights up.
Sabotaged??? What could they mean by that?? It could be a bad control panel or connection, but I would say you have a bad magnetron, the magnetron is mounted loosely, or the RF gasket (mesh washer) on the magnetron is missing, loose or damaged. I would contact MayTag and see if they have a different authorized servicer in your area, or get on the phone and complain to them in great detail. Do not put up with this, please.
May 10, 2007 | Maytag MMV4205 Microwave Oven
Microwave Ovens Logo
133 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
