Question about Kenmore Dryers
Kenmore 70 series; Appx 12 years old; When I tried to start the dryer I heard a "pop" and the timer cannot be heard and nothing works. It has been taking about 90 minutes to dry load. Have cleaned out the vent that leads outside of house and all clear.
  • 822 Answers
After 12 years..........you done well......may be time for a newer machine..........sorry
cheers
Posted on Mar 24, 2011
Old Kenmore Dryer can't turn-off and won't heat
Look like you need a timer control
model number should start with a 110. number timer for your dryer is about $70
Dec 05, 2013 | Kenmore Dryers
Kenmore dryer 70 series 66722690 - has power but won't start (no humming noise, no ticking noise from timer, and no light when you open door) nothing!
I would check the breaker before you go any further. Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok. I have a strong feeling that you won't need to get to this point cause I'm betting on breaker.
Apr 30, 2012 | Kenmore Dryers
Kenmore Dryer 70 series is about 3-4 years old. It will not start when you push on the "on" knob.
check the safety switch in the door first , then the start button switch, you can do this by jumpering the switches one at a time to find the bad one
Jun 21, 2011 | Dryers
I have a Kenmore 70 series. About 10 years old. The inside light comes one, the timer ticks when turned but nothing happens when I push the start button. We have already checked the breaker. Is there...
you either have a blown thermostat, blown thermal fuse, or a bad heating element most likely a blown thermostat
email me if you need more help in replacing or testing
Nov 16, 2010 | Kenmore 73952 Gas Dryer
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Kenmore dryer 70 Series doesn't shut off, timer continues to run
there are 2 different kinds of units made back then.
one has a push to start button that could have a stuck contact causing the unit to think you are pushing the button and want it to run again.
the other could have a stuck motor switch and thats not available separately. you would have to replace the motor. try to clean any lint out of the motor if you have that type. use compressed air to blow the lint out of the motor. it usually works to get the lint out and it can cause the switch to stick.
Dec 28, 2008 | Kenmore 63942 Dryer
Kenmore Heavy Duty 80 Series Gas Dryer won't cycle/won't heat.
if you ran this unit awhile without timer advancing,,now you blew the thermal fuse,,,re place thermal fuse and timer..
Nov 27, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
57 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
