Question about Jenn-Air JS42SEFXDA Stainless Steel Side by Side Refrigerator
Jenn-Air js42sefxda. Freezer and fridg won't cool. Ice was built up at the top of the freezer. I turned it off for 24 hours and once the ice melted it operates normally. How do I prevent the ice buildup?
  • 132 Answers
There is a defrost timer that normally controls the defrost cycles.
It appears that the defrost timer has failed. A new timer needs to be fitted. a technician can help you with that
Posted on Mar 25, 2011
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
Freezer side is freezing and refrigerater is warm
You have an Iced up freezer there...is the freezer "packed full of stuff?" If so you are blocking all of the vents that cool the fridge...The freezer section of a refrigerator is responsible for keeping the freezer frozen and the frige cool...air passes between the two compartments via the settings you set on those dials "a b c etc." Take everything out of the freezer and stick it all in coolers or something for a couple of hours see if there is ice built up around the vents at the sides and bottom of the freezer compartment. If so, the freezer needs to be "de-iced" normally this is accomplished automatically via heaters placed here and there throughout the fridge...So this may also be a source of your problem. if the heating element is bad, it would allow ice to form...I can also assume that the airflow from the fan in the freezer is "weak at best" meaning it is also full of ice... You can melt the ice with a hairdryer and some time of course...but be thorough with it. If you have a heat gun even better, just don't get it too close to the plastic or you will melt it. hope i've helped a bit...let me know what you find in there
Jun 09, 2012 | Jenn-Air 48" Side-By-Side Built-In...
My refrigerator is warm, but the freezer seems to be fine.
Top of Form
Since frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.Since Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Nov 24, 2010 | Jenn-Air JFC2089HE French Door...
Refrigerator is not cold (50);freezer is working; vents not blocked. What can I do? Fan is working, & compressor does kick on.
Nine out of ten times it turns out to be a defrost issue. What most people dont understand is the refrigerator gets its cool air from the freezer. If the evaporator coil in the freezer becomes a block of ice then the airflow from freezer to fridge section is blocked. The block of ice along with already frozen foods in the freezer compartment help to keep those foods frozen. Therefore you assume the freezer section is fine. However, the lack of cool airflow to the fridge side quickly turns that 38 degree air into 50 degree air. You could try unplugging the fridge and leaving doors open for 24 hours, this will thatw the evap coil. Plug it back in after the 24 hours, and within 12-24 hrs everything should be cool. If the fridge continutes to cool for about 3-6 days and then fails again, you certainly have a defrost problem. This is long winded, but hope it helps
Mar 01, 2010 | Refrigerators
The temperature alarm is beeping and the fridge and freezer continue to get warmer.
Hi i have a jenn-air side by side ice & water dispenser and the ice & water bottons keep beeping and flashing, what does this mean
Jan 26, 2010 | Jenn-Air JCD2389G Side by Side...
Freezer is fine but the lower compartment is just cool not cold temp setting is turned to coldest
Firstly turn you temperature setting to the MIDDLE in between cold and coldest. This will allow cold air coming from your freezer to go into your fridge. if this does not seem to change your problem, check to see if the air vent at the back, top of the fridge is allowing air to flow from the freezer to the fridge. if there is no air flowing there may be a clogged ice drain or pan. usually if this is clogged you can unplug your fridge for 24 hours with the doors open. and it will manually melt the ice buid up.hope this helps
Thanks
Oct 12, 2009 | Magic Chef Refrigerators
Frig not stayng cool. Freezer not freezing
most fridges have a evaporator dish or container.
it must be emptied ...and cleaned and disinfected.
now-a -days they are usually mated with the compressor and cool this unit down. notice there is no coil along the back of the fridge...it is usiually behind the fridge at the bottom with a cardboard or plastic access cover...
this will make the unit cool better and return the cooling to normal....
\next
clean out your freezer...i bet it's full of 4 month old packs of something you'll never eat....this will let the freezer breathe and circulate air to the coil ...i bet it has 3 in of ice on it...yikes...your not alone...most people do this...\
get a freezer if your getting ready for the apocalypse and liberate some room.
good luck
May 18, 2009 | Jenn-Air Jenn Air Side by Side Counter...
Js42sefxda jenn air freezer dripping water from the top vent
Check that the drain tube for the defrosted water is not plugged. Someone on here just the other day had the same exact problem, and that was the problem they had.
Jan 28, 2009 | Jenn-Air JS42SEFXDA Stainless Steel Side...
Left ge stainless steel fridge and freezer door open acciently
youll need to unplug and defrost all the ice from hte back panel, leave unplugged for a min of 24, hours, then plug back in you should be fine. way too much ice has built up behind hte inner panel ,cutting of all air flow to both compartments.you did no real harm( other then losing your food
Nov 28, 2008 | GE Refrigerators
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JS42SEFXDA Stainless Steel Side by Side Refrigerator Logo
172 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
