Question about Optics
Meade model 4501 - missing 1 threaded shaft and mounting cap screws on the diagional mirror assembly where can i find these parts
  • 3,186 Answers
Only meade will have these exact parts. Call them here:
http://www.meade.com/support/index.html
Posted on Mar 24, 2011
Where do i look threw on the meade 4501 telescope
There is a hole in the side with turn wheels to adjust focusing, that is where you should plug in your viewing lens.
Nov 05, 2017 | Meade Optics
Quisiera saber como armar mi telescopio meade modelo 4501 d=114mm f=910mm 1/8 y como cambiar los lentes, gracias.
Todos los manuales de Meade se encuentran en este sitio web:
http://www.meade.com/manuals/index.html
Jan 16, 2011 | Meade 114NT/500 (36 x 114.3mm) Telescope
Meade ETX 80 telescope missing parts
You are missing a screw on cap for the rear port, and you need to buy several 1.25 inch eyepieces.
Scopestuff.com sells the rear port cap also you may be able to get one directly from Meade- http://www.meade.com/support/index.html
Several internet retailers sell 1.25 inch eyepieces.
Here is one:
http://www.agenaastro.com/
Feb 21, 2010 | Meade ETX-80AT (240 x 80mm) Telescope
My Meade Polaris 60EQ-D Telescope is missing the diagonal mirror.
Here is Meade's manual web page. Find your telescope on the page:
Aug 09, 2009 | Meade Polaris 60EQ-D (36 x 60mm) Telescope
Re-assembly of 99 Blazer mirror to windshield
This is a relatively easy task, the bulk of the work has been for you. The rear view mirror assembly simply slides onto that metal block that was glued to your windshield. Your mirror mount (the part that slides onto the metal bracket) may be cut differently or shaped different from the rest of that part. you simply need to line that up with the metal mount on your windshield. slide the mirror on and tighten down the set screw if you have one. I've listed the steps below
1. find the base mount for your mirror (this is the bottom of the mirror that sits on the windshield)
2. look for a cut out or flat part of the mirror base.
3. line the flat part of the mirror base with the metal mount bracket on the windshield.
4. slide the mirror onto the metal bracket (this may require you to wiggle while you slide the mirror onto the metal bracket).
5. tighten the set screw on the mirror base ( this is important because your mirror will vibrate off the bracket if you don't.
Note some mirrors slide from the bottom of metal mount bracket and some slide from the top. it sort of depends on the manufacturer and/or the way the bracket was installed.
Hope this helps
Aug 04, 2009 | 1998 GMC Jimmy
I have a meade 4501 telescope. It has an
See if a manual is listed on the Meade site Here:
That shows the power supply voltage.
Jul 12, 2009 | Meade Optics
Mounting info for Meade telescope 70 AZ ADR model 04054
Here is the mnanual for the telescope-- screw sizes may be listed inside-
However just carry it up to your local ACE hardware store and the friendly folks there will help you find the proper screw size-- (or any well stocked hardware store).
Good luck
Mar 16, 2009 | Meade Optics
Piece of felt covering mirror, is this suppose to be there?
Here is the manual for your telescope--
http://meade.com/manuals/TelescopeManuals/Reflectors/Meade%20114%20EQ-ASB%20manual.pdf
The mirror at the bottom should NOT be covered-- with felt? Unless this was something Meade did to protect the mirror from dust and dirt during shipping?
Mar 11, 2009 | Meade 114EQDH4 (36 x 114mm) Telescope
2004 Honda accord Sedan - Mirror, actuator and cap replacement
you can buy the whole mirror after market for about 70.00 dollars three bolts changes the mirror assembly its a pain to do it the other way i have changed alot of them if you can just get the mirror glass double stick the
new to the broken one
Dec 22, 2008 | 2004 Honda Accord
Optics Logo
57 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you an Optic Expert? Answer questions, earn points and help others
