Question about Emerson (025806803716) Wine Cooler
Emerson wine cooler /ER2352
I have a problem with my wine cooler maintaining it's tempature. I have already cleaned the filer on the backsine. what other suggection do you have ?
Brad
  • 7 more comments
  • hmcdonald Aug 26, 2008
    i have the same problem. Unplugged it ( thinking of defrost) and cleaned the back. Still problem exists
  • Anonymous Sep 07, 2008
    Same here...the fan doesn't seem to kick on and off. Wine does not stay cool anymore. What to do?
  • msallin Nov 13, 2008
    My wine cooler not cooling..fans run...green and red light on
    help
  • melmad35 Dec 09, 2008
    Same problem...worked well for ahile, and now maintains 68 degree temp, and will not move.
    WHAT'S THE SOLUTION???
  • Anonymous Dec 18, 2008
    i have the same problem i am not reading any solutions?
  • kmfk15 Dec 26, 2008
    I can't get mine to go below 53 degrees. No manual or warrenty in box. What is the right temp for wine?
  • weemsbo1 Dec 27, 2008
    emerson cooler won't get below 62 degrees...what's up with that?
  • tkkg Dec 27, 2008
    my cooler will not go below 66 degrees now, 5 bottles of wine ruined.
  • Anonymous Jan 14, 2009
    I have the same problem as well..Won't go under 53 deg...Also leaking what looks to be water condensate..
  • 3 Answers
I had a similar problem and just solved it.
My cooler was leaking and had trouble keeping the proper temperature.
It was also making a buzzing sound which is what lead me to my solution.
BTW - The liquid that was leaking was condensation, probably because the unit was not holding a constant temperature.
Unplug the unit first - no need to get electrocuted.
These units use peltier cooling- essentially a large heat sink with three fans attached.
Click here for more info regarding peltier cooling.
The peltier unit is not repairable, but the fans are; which was what my problem was.
There are three fans on this unit, one on the inside and two on the outside.
Follow these steps to remove them.
  1. Remove the rear cover. It is held on with ten screws. This exposes the two exterior fans and the peltier heat sink
  2. The heat sink is held on with four screws - remove them and pull the heat sink out. The third fan is on a short wire lead, so be careful when removing the heat sink from the body of the cooler.
  3. The two exterior fans are connected to a control panel, the electrical connection is easy to disconnect.
  4. Once all of the wires have been disconnected, you can remove the fans from the heat sink.
  5. The fans are screwed to a mounting plate, which is screwed to the heat sink
  6. You must remove the mounting plate first to expose the screws that hold the fan to the mounting plate. The fans are typical computer case cooling fans
  7. I only needed one fan, but replaced all three because I didn't want to do this job again.
  8. I purchased my fans from Newark.com the prices were better than what I found at the computer websites. Also, these fans are much better than the original and will hopefully last much longer than the three I got from the old ones.
  9. You need one of these and two of these. The total with shipping was around $30
  10. You will need to splice the old electrical connection sockets onto the new fans using wire crimpers or solder them on.
  11. Attach the components in reverse order and power on the unit.
  12. These fnas may move more air than the originals, because the unit seemed to cool much quicker than I remember.
  13. Total time for repair is about 45 minutes
Hope this helps and Good Luck
Posted on Jan 16, 2009
  • luzer1966 Jan 16, 2009
    *** Regarding my solution ***
    You need two of these fans and one of these.
    Sorry for any confusion.
I have the same problem and so do others who gave feedback on Amazon. Any ideas out there?
Posted on Oct 26, 2008
I have the same problem as well. In addition, it seems to be leaking something too, even with un-opened wine bottles. I've been tring to find what the warranty is???
Posted on Oct 11, 2008
I have not been able to find any solutions online and apparently neither has anyone else. Clearly the Emerson FR48 wine cooler is a piece of $#!%. It appears the power supply on these is flaky. I can hear...
check the fam to make sure it spins freely ,, a little wd-40 could help, If the power supply is straining to make the fan move, you will hear that whining sound as its over loading
May 29, 2011 | Emerson (025806803716) Wine Cooler
As I can improve the yield of refrigeration of the digging, it is already difficult to maintain the indicated temperature
Here is the breakdown on this machine by temperature - it only works optimally in a room that is 68-70 degrees, which is a little on the cold side:
to actually reach 7 degrees Celsius, the room temp must be 68 degrees Farenheit or below
to reach 9 C, room must be 70 F or below
to reach 11 C, room must be 72 F or below
ETC...
all problems with this wine cellar will be aggravated during the summer months
Jul 22, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Need user manual for Emerson Wine Cooler FR23RD
HI. i couldn't find the FR23RD but, i have been told that this manual covers your model. It basically covers FR24SL threw FR24RD. Your model is also covered in this edition. Click to review your manual.
Please rate and god bless.
Mar 22, 2009 | Emerson Refrigerators
Emerson (025806803716) Wine Cooler Logo
1,334 people viewed this question
Top Emerson Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Emerson Furniture Expert? Answer questions, earn points and help others
