Question about Clarion CZ209 Car CD USB MP3 Player
The battery in my valkswagen died and when it was charged back up my raido stoped working what do i do?
    Scholar:
  • 146 Answers
You will need to find the security code for radio and put put that in for radio to start working again
if it is factory radio most car makers put a sticker in glove box that only has some numbers on it and no other info - that is usually the radio unlock code
if it is aftermarket radio it might be stuck into the owners manual - which will also tell you procedure for putting that code into radio
only other thing i could think of is that a fuse for radio has blown
good luck
Posted on Mar 24, 2011
96 Lincoln towncar raido buttons have back light but do not work also the display on raido stoped working and no sound
  1. Press and hold the OFF button for a few seconds. NOTE: On some models, this will toggle the display on and off.
  2. Check to see if your car stereo has a dimmer setting, which can disable the display. If the car audio system does have this setting, try adjusting it to the different dimmer settings. Sometimes the dimmer setting is on the left side of the steering wheel where the lights are.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
May 27, 2016 | 1996 Lincoln Town Car
Battery died, charged it took it for a drive half way back home dashboard lights went out heater also went out van almost died, when we finally stoped to park turned it off then decided to try again and...
Take your battery in for testing after charging it. Then, to avoid pulling the Alternator for nothing, drive to a local Autozone, Advance, or Oeilys and ask them to check your charging system on the Van.
Consider taking an extra battery if you have one to fit, so you can get back home after the test. Run the van with the charger connected until you get good heat, then reduce the blower fan speed to minimum. Then disconnect charger.
If you are still stuck on the road, jumpstart the van until it is warm, using the jump car to charge the battery so you can go home and try again. Just leave the battery jumpers connected to the struggling van battery a few minutes so the old battery has a chance to charge.
Jan 19, 2012 | 2000 Ford Windstar
Put a new battery in my 96 cbr 600 last month its been fine .. yesterday did a few wheelies n the key came out finally wen i stoped the bike died n battery was dead ... could it b a stator or rectifier ?...
chare the battery back up and get a volt meter, the battery should read 12v or a little higher, when you start the bike the voltage should rise to around 14v, if it doesnt rise it is not charging and the reg or stator needs checking
Jun 01, 2011 | 1996 Honda CBR 600 F(3)T
After fitting new battery on my fjr 1300 Drove a long journey stoped and it would not start as if the battery was dead. left it for a while and it started with loads of power in the battery any thoughts...
Have your charging system looked at, first do a simple multimeter test, get a multimeter, switch it on to Volts, start bike and see what it reads, put multimeter prongs directly on battery, very simple, if its below 12V you have a charging problem. If your battery is new and your charging system is faulty the bike will start and go, but when you switch it off the battery will be dead because it has not been charging. When you let a dead battery sit for a while it will charge itself a little, enough to start the bike up. Have you ever had a flat torch or mobile phone, it will die when battery is flat but when you try and switch them on again after a little while, they will work a little and die again, same with bikes, cars etc. All the best, Forever Two Wheels :)
Mar 28, 2011 | 2002 Yamaha FJR 1300
Battery has stoped working and has swelled in
This is because the life of battery is finished.This occurs due to prolonged charging.
Please replace the battery.DONOT charge anymore there may cause explosion of the battery.
Thanx
Jul 27, 2010 | GPX PDL805 Portable DVD Player
My 2002 silverado spdomiter stoped working when i installed a new raido what do I do to make it work again i supose it has somthing to do with the extra wires I did not use for the new raido?
I doubt any of the wires coming from the new radio would control your speedometer. A more probable cause is a broken wire going to the speedometer/instrument cluster or a loose plug at the back side of the cluster. Did you remove the instrument cluster to gain access to the radio? If so, is the plug seated securely into the back of the instrument cluster. It's very tight working behind the dash and easy to accidentally break a wire loose.
Jan 12, 2010 | 2004 Chevrolet Silverado 2500HD
Reset pin code on raido
tuen radio off...hold #1 and #6 on preset buttons...tuen radio back on an alphanumeric number will display theere should be 8 digits and 2 numbers...you will need to call acura and give them these numbers and they should give you a lock code to enter hope this helps
May 31, 2009 | 1999 Acura CL
Computer stoped working
If you're certain that the battery is fully charged, then there could be an issue with your hard drive, or possibly motherboard.
Has the laptop ever been wet, or outdoors overnight?
See if you can boot from your disk drive by inserting your operating system disk in the drive when you turn it on.
Also double check that the outlet you're using is actually supplying power, I have bad outlets in some parts of my house where my laptop won't charge up.
Hope that helps, keep me posted
Dec 11, 2008 | Acer Aspire 3680 Laptop
Is it my battery?
well this is what you should try ,,jump the car get it running
then when its warmed up take the positive lead of the battery
if the car stops the alternator is gone (thats what charges the battery) if the car runs its fine
and if u have put another new battery in it and the alternator is fine look for any broken wires earths or positives that could be making it drain so quick
and make sure your battery levels are full
hope this helps
Jul 02, 2008 | 2001 Mercury Cougar
Clarion CZ209 Car CD  USB MP3 Player Logo
98 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
