Question about Electric Mobility Shoprider Electric Power Wheelchairs Scooters Trooper
My dad has a Buttermere L Scooter. When I turn the key it shows as fully charged however when you push the lever in to 'go' it just bleeps all the time...can you help
5 Suggested Answers
  • 7 Answers
SOURCE: After a period of use the Scooter turns itself off.
sounds like it might be a bad throttle pod, or the brake is overheating. If you can pull the rear shroud off and drive it for a while you can check to see if the brake is overheating. Be careful when checking it because if it is really hot it will burn your fingers. The throttle pod can be checked with an ohm meter but i'm not sure off the top of my head what reading you should get. let me know if you would go that far and i'll get it for you.
Posted on Mar 10, 2009
SOURCE: pride victory Scooter battery charged won't run
Its probably too late to give my opinion, but here goes anyway.
I had a similar problem with my mothers scooter and it turned out to be a faulty connection on the wires leading to the motor. I simply pulled the plastic connection apart, cleaned and lubricated the contacts, refitted the connection and all was well.
Posted on May 13, 2009
  • 92 Answers
SOURCE: I have purchased new batteries for my mobility
The control seems to be the issue. I have rewired so many scooters. When you have power and it wont go, it is usually the control. If you cannot afford the part right away, you can rewire it or have it rewired direct
Posted on Apr 06, 2010
  • 177 Answers
SOURCE: 7 bleeps on my GO GO ELITE TRAVELLER SCOOTER
Hi. 7 beeps is fault code for a faulty speed potentiometer. Might also be a broken wire on the pot or a faulty connector. Most times, a new pot will fix the problem.
Good luck. Neil.
Posted on Jul 09, 2010
I have a elite mobility scooter why does it stop on me my battery are fully charged the lights go on but won't move
Hi check freewheel lever at the rear of scooter if U an push the scooter it's in freewheel :::::: push the lever lever the other way to lock it in gear .. Cheers
Nov 25, 2016 | Elite Health & Beauty
HOW DO I RECTIFY THE FAULT IN MY SCOOTER?
hi Laurie, the five bleeps is related to the brake , you need to check the connections between the axle and the frame and the connection to the brake...
Regarding a circuit diagram... Pride would never supply such a thing, it's propriety information.
Regards
Rob
Nov 03, 2015 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
My gogo ultra is showing fully charged and horn beeps, when i put key in it beeps fast 10 times and 5 beeps after
5 beeps usually means scooter is out of gear, but since the lever is in the drive position and the scooter gearbox/differential is engaged, it seems that the controller is not sensing the gear change. Possibly a faulty micro switch in the motor housing can be the cause of this, usually the micro switch is pressed down by the drive lever and if the switch is pressed down the motor controller knows the scooter is in gear.
Feb 11, 2015 | Pride Mobility Products GoGo Ultra X...
I have a Pride 4 wheel Go Go Elite Traveller Scooter. It generally works fine, but I will frequently get an 8 beep error code and it won't go after a stop. I merely turn the key off and then
BEEP CODE CONDITION SOLUTION
2 Battery voltage is too low to operate Charge the batteries fully until charger and
the scooter. any meters indicate completion.
3 Battery voltage is too high to operate Contact your authorized Pride Provider for
the scooter. assistance.
5 Solenoid brake trip. The manual freewheel Remove the key, then push the manual
lever may be in the freewheel position. freewheel lever to the drive position and
restart the scooter.
6 Throttle trip. The throttle control lever Release the throttle control lever completely,
may have been depressed while inserting then reinsert the key.
the key.
7 Throttle trip. Throttle potentiometer Contact your authorized Pride Provider for
fault or speed potentiometer fault. assistance.
8 The motor is disconnected. Contact your authorized Pride Provider for
assistance.
9 Possible controller trip. You may be Shut down your scooter for a minimum of
attempting to install the battery pack while several minutes to allow the controller to
the key is inserted or the motor controller cool. Or, try reinserting the key into the key
may be in overheat protective mode. switch.
What you may be doing is mis-counting the beeps and it may be 9 beeps or its 8 and you have a bad connection between the motor and the switch? Good luck!
Jan 19, 2015 | Pride Health & Beauty
Why does it beep five times when key is turned on and controls won't work
hi, the 5 bleeps are related to the brake,,, located at the rear of the scooter located on the side of the motor, attached to that is the free wheel lever,, in drive mode ,, check that the microswitch is working correctly, check the wire( connectors etc ) from the brake to the controller ,
www.facebook.com/gewizrepairs
Aug 07, 2014 | Pride Mobility Products GoGo Elite...
Altea 4 mobility scooter battery problem
hi, the battery's sound okay, have you made sure the scooter not in free wheel mode ? check the lever attached to the side of the brake ,,,
Check the wiring going to the axle .. At worse the controller has called it a day...at best a loose connection,,, controllers are repairable..
Regards
Rob
www.gewizrepairs.co.uk
Apr 20, 2014 | Pride Mobility Products Health & Beauty
Battery shows fully charged and the horn beeps but it won't move.
I have the same problem in mine.. But the beep is continous. Mine is a fortress 2000 AT. anybody knows what's the trouble on this one?
Jan 12, 2013 | Electric Mobility Health & Beauty
5 beeps when turn on key
5 Bleeps -> The manual freewheel lever is in the(forward) freewheel position.Remove the key from the keyswitch, then push the manualfreewheel lever to the drive(rearward) position and restart yourTravel Scooter.
I strongly advise you to check the freewheel lever microswitch located on the side of the motor, also check the connection from the axle connection to the actual body were it comes apart. keep me updated please. regards GeWiz.
Dec 04, 2012 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Hogh - low speed switch is incorrectly wired , but i dont know how it should be wired - Pride Hurricane scooter
Hi, I take it been taken then, do you get a error codes ?
see below
DIAGNOSTIC FLASH CODES
The diagnostic flash codes for your scooter are designed to help you perform basic troubleshooting quickly and
easily. A diagnostic flash code will flash from the status LED in the event one of the conditions listed below
develops.
NOTE: Your scooter will not run unless the flash code condition is resolved and the scooter has been
turned off, then turned back on.
Any electromechanical device occasionally requires some troubleshooting. However, most of the problems that
may arise can usually be solved with a bit of thought and common sense. Many of these problems occur because
the batteries are not fully charged or because the batteries are worn down and can no longer hold a charge.
FLASH CODE CONDITION SOLUTION
! (1) Battery charge is low. Charge batteries as soon as possible.
! ! (2)
Batteries are too low to operate the
scooter.
Charge batteries.
! ! ! (3)
The scooter’s battery voltage is too
high to operate the scooter, or the
charger is still connected to charger
port.
Unplug charger and/or turn key off, then
back on again.
! ! ! ! (4) Current limit time out.
Turn the scooter off for a few minutes,
then turn your scooter back on.
! ! ! ! ! (5)
Remove the key from the key switch,
then push the manual freewheel lever to
the (rear) drive position, and restart your
scooter.
! ! ! ! ! ! (6)
Throttle control lever not at center
position at start up.
Return the throttle control lever to center
position, turn scooter off, then back on.
! ! ! ! ! ! ! (7) Speed pot error.
Contact your authorised Pride Dealer for
assistance.
! ! ! ! ! ! ! ! (8) Motor volts error.
assistance.
! ! ! ! ! ! ! ! ! (9) Other internal errors.
Regards
GeWiz.
Oct 20, 2009 | Pride Hurricane 4 Wheel Personal Mobility...
Electric Mobility Shoprider Electric Power Wheelchairs Scooters Trooper Logo
113 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
