Question about Dryers
Dryer will not tumble i feel heat and see the heating element glowing
  • 822 Answers
If you can hear the motor...........then the belt has snapped.......
cheers
Posted on Mar 24, 2011
Should the heater element in a tumble dryer actually glow red?
If your dryer is electric, then yes. The metal coils in the dryers element are energized with electricity with causes them to heat and when metal gets hot, it will glow.
Jun 03, 2012 | Dryers
The dryer tumbles but it is not getting hoy-- is there a fuse to replace or is the heat element shot
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Apr 16, 2011 | Dryers
My indesit is70c tumble dryer is just blowing cold air,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 07, 2010 | Indesit Dryers
Tumble dryer does not produce hot air on hot mode, do I need a new heater element?
heatman101
Sep 02, 2010 | Zanussi Dryers
Duet Dryer not heating Tumbles but does not heat.
I would suspect a heating element on this model first. Unplug UNIT remove three screws at bottom of toe kick panel and remove unplug heating element check for continuity at terninals of heating element it will be the first two you will see in front
Hope this fixes your concern
Aug 13, 2010 | Whirlpool GEW9250 Electric Dryer
My hoover tumble dryer Hnc175 wont heat up,is still working as normal, just no heat, i have cleaned out the filters and still not working
Heating elements can fail. These are relatively easy and economical to replace. The heating element is not necessarily the culprit if your tumble dryer does not get hot, however. There are thermal overload cutouts fitted to many machines. If they fail, the current will not be passed to the heating element. Replacement is again, fairly straightforward.
Tumble dryers will often have thermostats fitted. A heater control one, and an exhaust thermostat. The first keeps the temperature correct. The second, as its name suggests, monitors the temperature of the exhaust (in case the airflow in the machine is impeded) Once again, replacement is not too much of a problem.
http://www.repairclinic.com/Dryer-Troubleshooting
Please look, at the link above, it will show you how to perform troubleshooting. procedures and repair.
If you feel you don't want to do it yourself, please call a Hoover Tech, and get it looked at. Ask for a "Quote" for the repair, so you get an idea of whats what.
Apr 08, 2010 | Dryers
My dryr tumbles but does not dry
Gas dryer? First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.  If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Electric dryer? Temperature sensor has failed or heating element has burned out.
May 30, 2009 | Whirlpool Dryers
Dryer runs but doesn't dry clothes.
hi,check to see if element gets hot,run dryer for 5mins. open door and look at back of dryer.you should see a red glow.or you should feel heat.if not the element needs replaced.and make sure the tumble is tumblering. a dryer can sound like its running,but nothing is really happen.
May 29, 2009 | Dryers
Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Jan 21, 2009 | Dryers
Dryers Logo
Top Dryers Experts
