Question about Hamat 3-2865PC Everest Pull-Out Kitchen Faucet with 45 Degree Lever Handle...
Where can I get a replacement hose 1.5 meter long?
  • 436 Answers
Contact Hamat
Techincal Support or Warranty
Parts
Call 1-866-52-HAMAT - option 6 or extension 1242
Hours: Monday - Friday - 8:30 AM to 5:30 PM est.
email: support@hamatusa.com
Posted on Mar 24, 2011
Whirlpool adp 4404/5. Green light flashes 7 times !! Any idea ?
F7 - Flow-meter failure
Symptom: water inlet valve (WV1) is switched on and the water indicator (WI) is on (level reached).
Could be:
1. Water tap closed during water inlet
2. Water inlet hose blocked
3. Water inlet valve (WV1) defective
4. Flow-meter (FM) sends too few / much pulses (less than 10 imp.in 10 sec.)
Flow-meter counts wrong (or the sump is full in less than 30 sec. Causation: Hose felt down and slipped the disc of the valve. The effect is a displacement of the valve tappet).
5. Aquastop defective
6. Flow-meter defective
Dado
Jul 26, 2015 | Whirlpool Dishwashers
Will not agitate already replaced the dogs no luck
No agitation?
first use a multi meter and check ur water pressure switch? that is what sends the machine the message to start wash cycle?
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well.
Or take the original hose tube and plug one end and blow into it AT the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ?
Sometimes they get busted open or a pin hole and release air causing the water switch diaphragm to not open.
Another test u can make with a multi meter is by testing the prongs individually.
# 15,16,17 (don't worry to much bout the numbers IF U GET THEM WRONG) place ur meter prongs on both out side prongs or connectors of the switch.
(where the wire plugs into) take note of weather it shows OHMS or infinity ( open or close circuit) ? Now place the meter on the left outside and the middle prong, take note agin what it shows. Now place meter prong on the right outside and the middle prong. Agin take note what reading u get. ( you should actually get a reading of infinity in 1 and a reading of continuity or ohms in the other 2? Now the tricky part. Agin place a small tube or hose into the switch and blow into it, using the meter do the same test agin on all prongs. But now keep the pressure on the switch when u blow into it, in other words use ur tongue on one end of tube to not allow air to escape. When u test it agin now one of the prongs that once read infinity should now show continuity or ohms, and 1 of the other prongs that read ohms should now read infinity or open.
If both check ok then next CHECK the motor coupler (a bad couplercan be checked by looking under the machine and taking note if there is a black residue on floor, look at coupler located between the motor and tranny, and see if it is broken up or missing any parts? Try to turn shaft by hand and notice if it does not engage tub? )
or belt if belt driven. Check for loose, broken or worn belt .
Then check the door switch with a multi meter for continuity OHMS when door closed and infinity when door is opened , and if there is a little movement on wash cycle in 1 direction only then check the cam dogs in agitator.
Mar 24, 2015 | Washing Machines
I have a Maytag mah2400 and the bleach and fabric softener dispensers are not working. Is there a solenoid or what initiates the intake?
Hello;
My name is Peter. I am a retired field service appliance technician.
There is a solenoid valve on the larger pump.
1.) Unplug your unit.
2.) On the back of the top cover are two screws. Remove them.
3.) Pull the cover back about 1/2" and lift the cover off.
4.) Looking down behind the dispenser you will see several components:
a.) Three black rubber hoses connected to two water valves.
Substitution Part Number 34001210 - Cost: $43.00
You can probably take the hose to your local Home Depot or Lowes and find a match for considerable less, if replacement is needed.
1.) Remove the hose clamps and remove the hose.
2.) Try to blow through the hose - is it blocked?
3.) Can you run a coat hanger through it to clear?
b.) There are two water valves. Disconnect and clean. There is the larger one which has a solenoid valve.
On the bottom of the larger solenoid valve, disconnect the two wire connectors. With a multi-meter (If you do not have one they are only about $25.00, a good investment to check electrical components)
Set the meter on the lowest Ohms. Placing one meter lead on the one connector and the other meter lead on the other connector
you should get a reading of '0'. If not the solenoid is bad.
c.) Ok, lets not forget the sensor;
Part Number 34001209 - Cost: $49.00
This is in the same area. There is no way to check this sensor if it is bad. You replace it only if all of the above is operational components check out ok.
Dec 06, 2014 | Maytag MAH2400A Front Load Washer
Water level
CHECK WATER INLET VALVE AND WATER PRESSURE SWITCH WITH A METER.
( If No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well.
Mar 12, 2014 | Estate ETW4400XQ Top Load Washer
Washing machine fills up but does nothing else
Feb 24, 2014 | Estate Washing Machines
On Duet Front Loader- Error code F/H. Can see plenty of water coming in so I suspect pressure switch. Is this a common problem? I don't quite understand your pressure switch check procedure in your...
This error code F/H tells that no water entering the machine is detected during the fill step of the wash cycle. It can be due to siphoning, pressure switch not tripping or stuck in the empty position, or the water flow meter is not reading the correct water flow. Make sure that no water is draining out of the drain hose due to siphoning as water fills in and position the end of the hose to prevent such condition.
The pressure switch is stuck and not tripping if after 8 minutes the water flow meter has detected 10.5 gallons of water passing through it but the control has not detected the pressure switch trips. The water valves are then turned off and the error code is flashed. The error code is also flashed if after 30 seconds the water valves are turned on and no water is detected entering the machine due to sticking flow meter pinwheel or the flow meter is not positioned properly.
The flow meter is position sensitive. The pinwheel must be installed vertically. Any canter to it may cause the wheel to stick. Many times the F/H error code pops up only when HOT water passes through the flow meter. The hot water may be softening the hoses on either side of the meter, causing the flow meter to canter. Stuck or cantered pinwheel affects the flow meter's ability to read water flow accurately. Disconnect the hoses from the flow meter then blow air into the inlet to free a possible stuck pinwheel. Replace the flow meter if the pinwheel is totally stuck and cannot be freed.
Check the pressure hose for possible kinks or air leaks if the flow meter pinwheel is positioned vertically and turning freely. Kinks and air leaks in the pressure hose prevents pressure built up in the pressure switch dome and the pressure switch cannot trip. Check the pressure hose including its connections to the pressure switch and the bottom of the tub. Blow air into the pressure hose to clear possible clogs or kinks and check it for air leaks. Also blow air into the pressure switch dome to free a possible pressure switch contacts welded or stuck in the empty position. You should hear the pressure switch clicks if it is tripping. Replace the pressure switch if not tripping and the pressure hose has no kinks or air leaks.
Jun 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Cleaner comes to the sides and top of pool, and won't stay on the bottom.
Cleaner won't leave or rim of edge of pool. Use Pool Pulse to lower flow. Utilize return flow to move cleaner. Adjust hose weight.
POOL PULSE (metering flow)
The Pool Pulse is a flow meter that measures the volume of water flowing through your Zodiac cleaner. It must be used to properly set the flow and can be used as a diagnostic tool when the cleaner isn't running properly. This piece should have been provided with your original box, but if you have lost or discarded the pool pulse flow meter, then you will need to purchase another one either online, or at your local swimming pool retailer. For the following steps (using 2 people is recommended; one poolside and the other at the plumbing manifold.) Vacuum and skimmer valves are located at your plumbing manifold. • Remove the cleaner head. • Attach the Pool Pulse to the end of the hose and keep it under water. • Turn on the filtration system. • For pools with one skimmer, flow is automatically regulated by the Flowkeeper Valve. Insure the blue indicator of the Pool Pulse is in the ideal range (when viewed from the side). • For pools with two or more skimmers, leave the selected skimmer open and slowly close the other skimmer(s) until the blue indicator of the Pool Pulse moves into the ideal range (when viewed from the side). • For pools with a wall vacuum fitting, leave the wall vacuum fitting fully open and slowly close the skimmer valve until the blue indicator of the Pool Pulse moves into the ideal range (when viewed from the side). • Keeping the hose under water, remove the Pool Pulse. Submerge the cleaner head, and when the bubbles stop coming from the extension pipe, attach the hose end. Your installation is now complete.
REGULATING RETURNS Divert the pool return inlets downward - Your Zodiac Automatic Pool Cleaner must move randomly throughout the pool and water circulating at the surface will influence the hose and limit coverage. • To adjust the return inlet: loosen the lock ring and redirect the eyeball downward, then retighten the lock ring. If the eyeball is difficult to adjust, insert a screwdriver inside the eyeball and gently adjust downward. • If the return inlets cannot be pointed downward, then you MUST install Zodiac return line diverters. They are available online or through you local retailer.
Adjusting weight on cleaner: FOLLOW THE GUIDELINES BELOW FOR YOUR SPECIFIC CLEANER MODEL. (Model number is stated on the cover of the manual that came with your cleaner) MODEL# W83251 - Hose weight is not required for this model cleaner in most pools. As a troubleshooting technique to improve coverage or prevent the cleaner from climbing the walls excessively, snap (1) hose weight onto the first hose section, one meter from the cleaner head. MODEL# W03000 - Snap (1) hose weight onto the middle of the first hose section, 1/2 meter from the cleaner head. MODEL# W83215 & W83216 - Snap (2) hose weights onto the middle of the second hose section, 1 1/2 meters from the cleaner head.
If you are still experiencing issues with your cleaner, you have a full 1 year warranty on the cleaner and Zodiac is happy to help you with the ownership! They can be contacted at: 1-888-786-779
Sure hope this takes care of that issue for you, and I look forward to your feedback! Thanks for allowing us to help you out!
Brian Morris, The Ugly Pool Guy www.WeFixUglyPools.com
Dec 10, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Gas meter is fluctuating from to full -meter shows more than 1/4 and vehicle is shutting down/stalling fro gas.
for the car pulling to the left make sure ur alingment is withing spec, then u check caliper and brake hose.make sure hose is not kinking or caliper piston not getting stuck. as for the fuel check ur nidle on dash if fine ur hanger is bad. i thing urs is a fuel pump ***,(pump and hanger)
Sep 11, 2008 | 2000 Chevrolet Astro
Whirlpool washer awm 6163
ckd for drain hose to low ..top needs to be 30-38 ins from floor also needs to be loose fitting in drain pipe to prevent siphoning ..if neither is the case ckd fill hoses for obstruction in screens last ch flow meter ..remove top round object left side with small hose from fill valve 1 side other side to detergent dispenser may try tapping it while it fills if works ok replace flowmeter
Sep 09, 2008 | Whirlpool Washing Machines
Getting a fh code on my duet front loader washing machine
suspect flow meter remove top left side small round object with 1 hose in 1 hose out small wiring plug attached small turbine inside spins as water enters machine small switch pickup rotation and sends info to control bd hard to verify with meter but most likely suspect..swith itself is usually problem it tends to stick in open or closed position
Jul 15, 2008 | Whirlpool Washing Machines
Hamat 3-2865PC Everest Pull-Out Kitchen Faucet with 45 Degree Lever Handle... Logo
189 people viewed this question
Top Hamat Plumbing Experts
Colin Stickland
Colin Stickland
ray gallant
Daryl Gleaton
Are you a Hamat Plumbing Expert? Answer questions, earn points and help others
